How does warranty replacement work through LG? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-29-2013, 11:25 PM - Thread Starter
HelloHelloHello's Avatar
I have an extended 3 year warranty on my 3 year old LG. Since they either probably can't get the panel for this old of a TV or it's too expensive to fix the different problems, they will likely replace it or give me a credit. Though I'm not sure what they will do, do you have any experience on what they will do? Credit? If so to where? Refurb replacement? If so, better or worse than mine (46LD550)?
HelloHelloHello is offline
Reply LCD Flat Panel Displays
Lg 46ld550 46 Inch 1080p 120 Hz Lcd Hdtv With Internet Applications
