Commercial LED-Lit LCDs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-30-2013, 12:44 PM - Thread Starter
Ozymandis's Avatar
Quoted: 26 Post(s)
Liked: 41
This might be an unusual question, but I need some recommendations on commercial LCDs. I would like them to be LED-lit, and the slimmer the bezel, the better. They do need to support 4:4:4 chroma subsampling. I'm not very familiar with commercial displays anymore. There used to be many plasmas in that space, but for this project burn-in is a concern.
I appreciate any help you guys can give me.
Ozymandis is offline
post #2 of 4 Old 10-01-2013, 09:28 AM
sitlet's Avatar
Not sure about the specific specs you requested, but NEC and Marshall make some very good commercial displays. I would check them out first.
sitlet is offline
post #3 of 4 Old 10-01-2013, 11:05 AM - Thread Starter
Ozymandis's Avatar
Quoted: 26 Post(s)
Liked: 41
Thanks, I'll check out Marshall. I'm looking at the NEC X401S right now as well. It's tough finding reviews on these displays!
post #4 of 4 Old 10-02-2013, 09:30 AM
sitlet's Avatar
I should have said, as far as I know, Marshall mainly makes broadcast displays for TV trucks and studios. Most of them will only have HDSDI inputs. Although I do have one thats a couple years old that does also have composite inputs.
sitlet is offline
Reply LCD Flat Panel Displays
