Samsung Smart TV reset? - AVS Forum | Home Theater Discussions And Reviews
Old 10-01-2013, 01:23 PM - Thread Starter
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
On the 2013 Samsung Smart Tvs is resetting through the service menu the only true way to wipe everything to the new just unboxed state? I know there is a master reset inside the onscreen menu system but it says it keeps your network info.
snorge is offline
Old 10-01-2013, 05:23 PM
GPtimes2's Avatar
See if this is different than what you found in the menu.
http://www.samsung.com/us/support/howtoguide/N0000058/12117/142707
GPtimes2 is offline
Old 10-02-2013, 01:51 PM - Thread Starter
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
Yes that is what I saw in the onscreen menu. I wrote my post from work so couldn't remember the exact section it was under. So what is the difference between that an the service menu reset?
snorge is offline
