Difference between Samsung UE40F5300 and UE40F5500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2013, 06:10 AM - Thread Starter
dmc4708's Avatar
Hi,
I am after some advice please, does anyone know the difference/benefits of the F5300 vs the F5500?
I have checked the product comparison feature on the Samsung website, however some sections of the F5500 are missing.
http://www.samsung.com/uk/consumer/tv-audio-video/television/productcompare?prda=UE40F5300AKXXU&prdb=UE40F5500AKXXU
From the information I took from Samsungs website, the only difference that I can see is that the F5500 has built in Wi-Fi and a swivel base - unless I am missing something.
I can get a good deal on a UE40F5300 at £380.  My question is, should I buy the F5300, or opt for the F5500 which is £480?
Built in Wi-Fi is not required as TV will be connected via ethernet cable, TV will also be wall mounted.
Any advice would be greatly appreciated.
TV will be used for watching movies, regular tv and some occasional gaming.
dmc4708 is offline
post #2 of 3 Old 10-03-2013, 06:55 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Probably both use the same panel and mainboard etc looks like one has WI-FI and one does not . It's not uncommon in a mfr product line to find 2 otherwise
identically functional sets with WI-FI being the only significant difference
tubetwister is offline
post #3 of 3 Old 10-04-2013, 01:17 PM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
I think the 5500 has a dual core cpu.
snorge is offline
Reply LCD Flat Panel Displays
Samsung Un40eh5300 40 Inch 1080p 60 Hz Led Hdtv , Samsung Un40f5500 40 Inch 1080p 60hz Slim Smart Led Hdtv
