Help with TV for Sunroom. Vizio out, Sharp, LG...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-04-2013, 10:37 AM - Thread Starter
BigZAJ's Avatar
I am looking for a bright, cheap and non-smart 60" TV for my parents sunroom. This has glass walls, ceiling and they want a TV so my Dad can watch football in the there. I tried a Vizio E601 but it was way too dim (and reflective), even at max bright with sensors off. I am currently considering a Sharp LC-60LE550 or LG 60LN5400.
Can anyone provide guidance on this?
BigZAJ is offline
post #2 of 3 Old 10-04-2013, 04:21 PM
GPtimes2's Avatar
If the vizio was way to dim, you may not find a tv to work satifactory in that space. If you have to improvise, you may have to inset one in some type of box ( at the expense of looks). Or you might try the sharp 60" 857 model with what they call their super-bright panel. But it runs about $500 more than the 550 model. I have the 80" 857 in a bright room with a lot of glass (including sky lights) and it does very well considering. Try and find a store that will let you drag one over to the windows and see what you think ( I know thats a long shot).smile.gif
GPtimes2 is offline
post #3 of 3 Old 10-04-2013, 05:04 PM
myoda's Avatar
Liked: 57
The LG has the picture wizard function that makes it easy to get a good picture out of the box.
http://www.lg.com/us/tvs/lg-60LN5400-led-tv
Personally, I think the Sharp has a better designed frame and slightly higher performing panel, once calibrated.
http://www.sharpusa.com/ForHome/HomeEntertainment/LCDTV/Models/LC60LE650U.aspx
Show Dad some football love - bump up to 70 inches for $300 more at wal-mart:
That is a crazy price for a large panel.
LC70LE640U
In stores only
$1248.00
http://www.walmart.com/ip/Sharp-70-Class-LED-1080p-120Hz-HDTV-3.5-ultra-slim-LC70LE640U/20452169
Here is a review of the 60 inch 640 - the LG might have a reflective screen - the Sharp, a matte finish.
http://reviews.cnet.com/flat-panel-tvs/sharp-lc-70le640u/4505-6482_7-35123265.html
myoda is offline
Reply LCD Flat Panel Displays
