Brand with most soap opera effect? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 10-04-2013, 06:11 PM - Thread Starter
HelloHelloHello's Avatar
In the market for a new 55" around 1000$ and what I'd really like is the most soap opera effect possible
tlwiz1 likes this.
HelloHelloHello is offline
post #2 of 25 Old 10-04-2013, 06:20 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
That's a little subjective. I would go to your local B&M, pick out a few models that you are interested in, and play with the motion interpolation settings and see for yourself. They have different names depending on the mfr so you may have to ask the salesperson.
Otto Pylot is offline
post #3 of 25 Old 10-04-2013, 09:46 PM
gamingarena's Avatar
That would be Samsung!
HarvesterUT likes this.
gamingarena is offline
post #4 of 25 Old 10-04-2013, 10:51 PM
HarvesterUT's Avatar
Samsung has some really high settings for this "effect." My Sammy from 2008 can look ridiculous if I set it to high. I prefer "low."
HarvesterUT is offline
post #5 of 25 Old 10-05-2013, 01:19 AM
jdmvette's Avatar
why? most people hate that and turn it off.
jdmvette is offline
post #6 of 25 Old 10-05-2013, 01:33 AM - Thread Starter
John4721, Ballis and southern bell like this.
post #7 of 25 Old 10-05-2013, 03:59 AM
iBrad's Avatar
Me too.
Get a Samsung, it has the best most SOE tweakings options.
The (Auto) Motion Plus with 2 adjustments: Blur Reduction 0-10 and Judder Reduction 0-10 for fine tuning.
And there's also the option LED Motion backlight strobing for further reduction blurring.
iBrad is offline
post #8 of 25 Old 10-05-2013, 10:28 AM
Otto Pylot's Avatar
Liked: 853
Television viewing is a personal preference experience. There is no right or wrong.
post #9 of 25 Old 10-05-2013, 10:47 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Well, in spite of burn in, image retention, buzz, heat, fan noise, etc. most folks around here respond to every LCD post with 'Get a Plasma' too....rolleyes.gif
John4721 likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #10 of 25 Old 10-05-2013, 12:33 PM
Otto Pylot's Avatar
Liked: 853
post #11 of 25 Old 10-07-2013, 06:57 PM
Miller64's Avatar
If I get a 60f8000 which settings do I use to get the most of the soap opera effect?
Miller64 is offline
post #12 of 25 Old 10-07-2013, 09:04 PM
Otto Pylot's Avatar
Liked: 853
What ever your tv mfr calls motion interpolation. For example, on an LG it's called TruMotion. You could probably Google the information.
post #13 of 25 Old 10-08-2013, 04:03 AM
Miller64's Avatar
What settings on a Samsung 60F8000 would I change to make it look like the highest soap opera effect?
Miller64 is offline
post #14 of 25 Old 10-08-2013, 06:02 AM
Jeffer65's Avatar
I thought on some TVs you actualy can't turn if off.
Jeffer65
Jeffer65 is offline
post #15 of 25 Old 10-08-2013, 10:57 AM
xoned's Avatar
LGs TruMotion user de-judder setting can be set to 10 which really increases the SOE. For some reason they did away with the de-blur adjustment.
xoned is offline
post #16 of 25 Old 10-08-2013, 11:07 AM
Otto Pylot's Avatar
Liked: 853
On the newer models? My 2010 has individual judder and blur settings.
post #17 of 25 Old 10-08-2013, 11:12 AM
xoned's Avatar
No de-blur setting on the LA6900.
xoned is offline
post #18 of 25 Old 10-09-2013, 06:44 AM
Ballis's Avatar
Quoted: 76 Post(s)
Liked: 49
Samsung has pretty good soap opera. I love it aswell and Max out the settings.
Ballis is offline
post #19 of 25 Old 10-09-2013, 08:03 AM
OneStepAhead's Avatar
Quoted: 386 Post(s)
Liked: 230
Look for LED MotionPlus in advanced picture settings. Off is no effect, play around with the others. At least that's what it's called on my Samsung D8000. Maybe they renamed it due to customer backlash. Lot of reviews where people returned this TV because they couldn't figure out how to turn it off, or know that it could be turned off. It actually looks ok on some content, but for TV watching its just atrocious in my opinion.
Sony XBR-75Z9D + Samsung 78JS9500 + LG 65OLEDC6P + 55EC9300 + 55EA8800 OLED
Denon X5200W + Integral + Oppo BDP-103D
MartinLogan Motion 60XT/50XT/FX/FX2/4 + Seaton Submersive HP+
Denon X6300h + Oppo BDP-103D + Xbox One S
Monitor Audio Silver 10's + Silver Center + CP-CT380's + 2x HSU ULS-15 MK2
3.1 MartinLogan Motion 40/30 + Rhythmik FV15HP + Yamaha RX-A3000 + Oppo BDP-103D
OneStepAhead is offline
post #20 of 25 Old 10-09-2013, 09:40 AM
Otto Pylot's Avatar
Liked: 853
That's too bad.
post #21 of 25 Old 10-09-2013, 12:26 PM
FirstReflect's Avatar
Quoted: 51 Post(s)
Liked: 84
That's a common misconception. Unlike audio, there actually are very clear standards and calibration targets for video. There is a very well defined "right" and "wrong" in video. Having that industry-wide standard is the only way that TV and movies can be made. Otherwise, all of the color correction, detail, motion and director's intent would vary wildly depending on which TV was used during the production process!
Every display that was used to actually make the content was calibrated to the exact same industry standards. In other words, every display looked identical. If a display does not look identical to that industry standard, it is wrong -- no ifs, ands, or buts. As a result, the only thing that makes sense when you are watching at home is to also adhere to those same industry standards. That is what ISF and THX calibrators are for. They're not adjusting your TV "to taste", or just eyeballing the results.
If you want to deviate from the industry standards, yes, as a viewer, that is your prerogative. But there IS a right and wrong. If you're aware of that, and you decide that you want to be wrong, that's ok smile.gif
FirstReflect is offline
post #22 of 25 Old 10-09-2013, 01:57 PM
Miller64's Avatar
Do I go to Auto Motion Plus then Custom and set judder reduction to 10 and blur reduction to 10 ?
Miller64 is offline
post #23 of 25 Old 10-09-2013, 03:56 PM
Otto Pylot's Avatar
Liked: 853
We're discussing the SOE, not calibrating a tv to rec.709 standards.
post #24 of 25 Old 10-14-2013, 10:21 PM
southern bell's Avatar
I have a Samsung UN55FH6030 and am also a big fan of high MI/SOE... What do y'all recommend me put tthe Auto Motion Plus, judder, motion blur, and LCD motion settings on?
southern bell is offline
post #25 of 25 Old 10-18-2013, 01:08 PM
I finally got a pretty good SOE on mine today by messing around with the PO settings some more.  I posted my exact PO settings in my thread named "Tips for amping up MI" if you're interested :)
Let me know how they work for you if you try them out :o I have the Samsung UN55FH6030 btw.
Reply LCD Flat Panel Displays
