LCD LED OPINION HELP - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 01:15 PM - Thread Starter
eggnog9fuk's Avatar
samsung 32" UN32D4005BDXZA
out of warranty
2 years of use
hi i have this problem on my tv screen. the display started to have a double vision and change in color (green and red) when i was playing with my ps3. it looked like it was 3d but my tv doesnt have 3d. so stupid me i opened up my tv and tried to fix it myself when i was screwing back the aluminum thing that protects the LCD panel i think i applied too much pressure. when i turned on my tv this is what i saw. i tried to massage the screen and tap it. it went from black to transparent dark blue. i checked the lcd panel and there are no cracks.but on the corner of the lcd panel there is like one small air bubble. i think i broke the seal or something. what do u guys think? is this still fixable? thank you in advance
eggnog9fuk is offline
Old 10-07-2013, 01:42 PM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
Cheaper to buy a new TV. Repair will require replacing the panel.
RollTide2011 is offline
Old 10-07-2013, 06:29 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
looks like moisture in the panel or impact ? anybody been cleaning it with spray ? cleaner big no no ! not repairable
tubetwister is offline
