Official Sony XBR-55X850A / XBR-65X850A Owner's Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 05-13-2014, 04:51 PM
JoshuaCarter14's Avatar
Thank you! i will give this a try, However does anyone have any other opinions on what the brown spot is? or was digimat spot on with his assumption? No pun intended.
JoshuaCarter14 is offline
Old 05-13-2014, 05:13 PM
This is what it pulls up?
Old 05-13-2014, 05:32 PM
Carlos_E's Avatar
Quoted: 1282 Post(s)
Liked: 1215
Yes. Turn the TV off and try the code again. It should show the number of hours in the bottom left corner. Did you scroll away from the first screen it displayed after hitting the code?
Sony XBR-75X940C, two XBR-65X930C, Sony XBR-65X900B, two Sony FMP-X10 4K Media Players, four Sony SWF-BR100 Wireless Subwoofers.
Carlos_E is offline
Old 05-13-2014, 06:59 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
Josh, did you press volume up or volume down during the sequence? Vol+ takes you to the screen you've pictured, Vol- should go to the check screen.
Geoff D is offline
Old 05-13-2014, 07:32 PM
OK so 172 hours? But that seems kinda low to have what digi mentioned.
Old 05-13-2014, 07:35 PM
Old 05-13-2014, 08:48 PM
Carlos_E's Avatar
Liked: 1215
Originally Posted by JoshuaCarter14 View Post
does anyone else have this issue? ignore the red hue, The brown spot though drives me nuts and its visible to some extent in every image or source being displayed
Mine does not look like that. I would call Sony for a replacement.
Carlos_E is offline
Old 05-14-2014, 08:58 AM
Well they told me they won't repair it but they will send me a replacement so I guess I can't be to bummed lol, thanks for all the help guys
Old 05-14-2014, 09:28 AM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
No it's the third group of numbers, so 186 hours. But 172 is close enough. biggrin.gif
Sometimes a fault is just fault, perhaps something went wrong with the application of the diffuser.
Incidentally, the screen uses an AUO UD3Y650LN0101 panel, but there doesn't seem to be much more information on the internets than that.
Geoff D is offline
Old 05-14-2014, 10:11 AM
Brian Trompke's Avatar
Quick question im looking into, does this have HDMI 2.0 now? Or is that only the newer B model. Im looking to upgrade my current Sony LED to for a 4k, and im leaning towards the A, unless it does not have HDMI 2.0.
Brian Trompke is offline
Old 05-14-2014, 10:25 AM
Mattopotamus's Avatar
Quoted: 1512 Post(s)
Liked: 1145
All of the ports are HDMI 2.0. Only one is HDCP 2.2, which means any 4k streaming device would need to go into port 4. Most of the things I am reading points to the A being better than the newer B series. The B series seems to have dropped some Picture Quality features to keep price down.
Mattopotamus is offline
Old 05-14-2014, 10:56 AM
Carlos_E's Avatar
Liked: 1215
Were they clear if the replacement is a refurb? Or is it new?
Carlos_E is offline
Old 05-14-2014, 10:58 AM
Carlos_E's Avatar
Liked: 1215
Are you referring to the X850B or X900B? The X850B is not out yet and has not been reviewed. The X900B is out and getting glowing reviews.
Carlos_E is offline
Old 05-14-2014, 11:05 AM
Liked: 1145
The 900b. All of the reviews I have seen and post from users on this forum who own it state it is missing some features the previous A model had. Basically, the A model was priced so high b.c some of the screen features they added. They are not in this years model b.c they were trying to keep price down and make for of an entry level model.
Old 05-14-2014, 11:12 AM
Carlos_E's Avatar
Liked: 1215
I read the posts and they were not true. All speculation by X900A owners I feel justifying sticking with their X900A purchase. Posts made before the X900B even shipped.
The only thing the X900B is missing is passive 3D. No one in the X900B thread as said they prefer the X900A. (Besides for 3D.)
Both of the reviews below said the X900B is an improvement over he X900A. And yes, I ordered the 65X900B. It's delivering tonight. smile.gif
http://www.hdtvtest.co.uk/news/kd55x9005b-201405123771.htm
http://www.trustedreviews.com/sony-kdl-65x9005b_TV_review
Carlos_E is offline
Old 05-14-2014, 11:24 AM
Liked: 1145
Thanks for posting that! I stand corrected...great reviews.
Old 05-14-2014, 11:26 AM
vinodk's Avatar
Quoted: 84 Post(s)
Liked: 33
900B seems to be a good TV but certainly 850B seems to be downgrade compared to 850A to meet a certain price point. After looking at the features I decided to go with 850A instead of 850B. This is after getting frusturated with issues with 2 Samsung F9000 panels.
Vinod
vinodk is offline
Old 05-14-2014, 11:31 AM
Carlos_E's Avatar
Liked: 1215
I bought 2 4K sets. The 65X900B and the 55X850A. I went with the 850A for the same reasons. By specs, the 850B did not look as promising.
Carlos_E is offline
Old 05-14-2014, 11:38 AM
Liked: 1145
Well there is a huge price difference between the 65X900b and the 55X850a, maybe that had a play on your decision? Did you just feel like the 900b was not worth 2x the price?
Old 05-14-2014, 12:15 PM
digimat's Avatar
Quoted: 73 Post(s)
Liked: 222
If the 850b had the same specs as the 850a I would have gotten that set... the 850a is an awesome all rounder.
digimat is offline
Old 05-14-2014, 01:08 PM
Carlos_E likes this.
Old 05-14-2014, 01:21 PM
swspiers's Avatar
Just took delivery on the 55X850A.
swspiers is offline
Old 05-14-2014, 01:30 PM
Carlos_E's Avatar
Liked: 1215
My decision for the 2nd was between the 55X850A and the 55X850B. I did not think the features in the X850B were worth the increase in price over the X850A considering the 55" is a secondary bedroom TV. Also thought they removed features to reduce the X850B price.
Carlos_E is offline
Old 05-14-2014, 01:53 PM
I see that the HDMI 2.0 is listed as a free upgrade on Sony's website. If I purchase the TV from a retailer like Best Buy, will I need to go through Sony for this upgrade, or how does that work?
Old 05-14-2014, 02:22 PM
Ace of Space's Avatar
Quoted: 25 Post(s)
The software update to enable HDMI 2.0 came out last December and may already be installed, depending on when your TV was manufactured. Otherwise it's an easy software update using the TV's built in wired, or wireless, internet capabilities.
Sometimes I think my brain has a mind of its own.
Ace of Space is offline
Old 05-14-2014, 02:28 PM
Quoted: 25 Post(s)
I'm wondering if the panel used for the 65X850A is 10-bit, like the ones used in the 65X900A and 55W900A. The panel that's being used is AUO UD3Y650LN0101. I did a google search and there wasn't much information to be found. Not that it matters, just curious. Anyone have any insight?
Old 05-14-2014, 03:05 PM
Liked: 1145
Ballin!
Old 05-15-2014, 09:16 AM
crg5698's Avatar
Is there a price watcher thread? thinking about buying the XBR-55X850A and wanted to get the best price.
crg5698 is offline
Old 05-15-2014, 09:19 AM
swspiers's Avatar
Got my 55X850A delivered, installed and running last night. I did a very quick calibration with the Spears and Munsil disc. I did not have a lot of time to play with it, but I did stream 'Madmen' from Amazon Prime with my Oppo BDP-103/Roku stick. Even the wife was in awe of the picture.
So far, very impressed with the design and function of this set!
swspiers is offline
Old 05-15-2014, 10:25 AM
digimat's Avatar
Quoted: 73 Post(s)
Liked: 222
Fairly certain it is the exact same type of panel used in the 900W, not sure if it's 10-bit but I'm assume it is.
digimat is offline
kd-55x8504a , kd-65x8504a , Sony , Sony Xbr55x850a 55 Inch 4k Ultra Hd 3d Led , Sony Xbr65x850a 65 Inch 4k Ultra Hd 3d Led
