Official Sony XBR-55X850A / XBR-65X850A Owner's Thread - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1231 of 1243 Old 12-08-2016, 08:42 AM
chillstatus's Avatar
Quoted: 26 Post(s)
Originally Posted by bavboym3 View Post
I cant find a way to get the the HDMI outputs on the settings to see if I can make it 4K for Xbox
Does the Xbox 4K require HDR? I was looking into the PS4 Pro, but it seems like in order to take advantage of the 4K I'd also need a set with HDR which this TV doesn't have.
chillstatus is offline
post #1232 of 1243 Old 12-08-2016, 08:58 AM
bavboym3's Avatar
Quoted: 24 Post(s)
Im guessing so. I can't seam to find an answer, and Sony wasnt much help either. The system plays amazing in the regular 1080p, and it may even up convert some things. Love to see what 4k gaming is like though
TV: LG OLED 65B6P
Receiver: AVR-891
Subwoofer: Sunfire HRS-10
Towers: PSB T6's
Center: PSB C5
Surrounds: BA Satellite Speakers
bavboym3 is offline
post #1233 of 1243 Old 12-08-2016, 09:06 AM
Quoted: 26 Post(s)
Unfortunately for us - it did not pay to become an early adopter of 4K. I'm glad I do get to use 4K for Netflix and Amazon Prime content via the Fire TV. Still love this TV though as we use it daily.
post #1234 of 1243 Old 12-09-2016, 12:01 PM
bavboym3's Avatar
Quoted: 24 Post(s)
I love it too. Im just would like to see it play the 4k through the Xbox 1S. I bet there is a way to do it
TV: LG OLED 65B6P
Receiver: AVR-891
Towers: PSB T6's
Center: PSB C5
bavboym3 is offline
post #1235 of 1243 Old 12-24-2016, 06:55 PM
Damon Cooper's Avatar
I have this TV and just picked up a PS4Pro and TiVo Bolt+ 4K and HDMI 2.0/HDCP 2.2 switcher to connect to TV HDMI port 4. Will report back
Damon Cooper is offline
post #1236 of 1243 Old 12-24-2016, 06:56 PM
I assume you guys have seen this FW update? https://esupport.sony.com/US/p/swu-d...os_group_id=18
post #1237 of 1243 Old 12-24-2016, 09:13 PM
nutshellml's Avatar
Quoted: 26 Post(s)
How is the Sony's "smart" features? DLNA or connecting it to computer / streaming / etc?
nutshellml is offline
post #1238 of 1243 Old 12-27-2016, 02:14 PM
Update: everything works great except (as expected) no HDR support.
Using HDMI4 on the TV, connecting PS4Pro and TiVO Bolt+ via an E-SDS 5-1 HDMI 2.0/DHCP 2.2 switch controller by Harmony Elite and Amazon Alexa.
Had a small issue with the TiVo Bolt+ having trouble getting a DHCP2.2 response from the TV from time to time but changed the Harmony startup order to put the TV last in the order and that seemed to solve it.
rsonnens likes this.
post #1239 of 1243 Old 01-06-2017, 02:54 PM
Quoted: 26 Post(s)
Does mean you can still play games in 4k but without HDR? Or do the 4K games require HDR and you only see them in upscaled 1080p?
post #1240 of 1243 Old 01-06-2017, 06:46 PM
Everything's fine and 4K, just no HDR
post #1241 of 1243 Old 05-07-2017, 09:52 PM
jamis0n's Avatar
Originally Posted by dknigs View Post
Can this set pass through HDMI audio 5.1 to an optical receiver? The installer told me it would, but all I'm able to select from my Xbox One is Stereo Uncompressed with this TV.
Did this ever get answered? Im wondering the same thing.
I have a pretty basic setup (for now), but due to cabling in the wall, I can't connect my cable box directly to my Sonos Playbar. Thus, I'd like to make this setup work:
CableBox ==[HDMI]==> XBR-65X850A ==[OPTICAL@5.1]==> Sonos Playbar
Will this setup work? Or will the Optical out become 2 channel and force me to buy an HDMI->Optical adapter
jamis0n is offline
post #1242 of 1243 Old 05-10-2017, 09:14 AM
jamis0n's Avatar
BUMP - Anybody have ideas on my above post?
I've found a used Sonos Playbar for a good price, but I wanna make sure I dont have to dump another $100+ in to make the TV->Sonos connection work.
Any insight is appreciated!
I've searched Google quite a bit with no luck.
jamis0n is offline
post #1243 of 1243 Old Today, 07:43 PM
Opusnbill7's Avatar
I don't think so. I had it configured that way in the past, but I don't think it was actual surround sound in retrospect. It certainly sounded a lot more "full" when I replaced the receiver and used it instead of routing the sound through the TV over optical.
I may be wrong, though, as my experience is only one data point.
Opusnbill7 is online now
Reply LCD Flat Panel Displays
kd-55x8504a , kd-65x8504a , Sony , Sony Xbr55x850a 55 Inch 4k Ultra Hd 3d Led , Sony Xbr65x850a 65 Inch 4k Ultra Hd 3d Led
