E551d-A0 and M3D550KDE help asap please - AVS Forum | Home Theater Discussions And Reviews
Old 10-09-2013, 09:45 AM - Thread Starter
Jeffj8's Avatar
Hi, all been searching on new toys, not good at this tech stuff, can i ask for help comparing these two,vizio models, best buy 4 buck please on fixed income poor man here...the e551d-a0 is open box model full warenty etc cost 570 the m3d550kde is refurn at 599,, is there big deffrence in thses models any help please need asap thinking buying soon only few left in store...---------------------------VIZIO M3D550KDE 55" 1080p 120Hz LED HDTV:
  • 55" LED panel
    With a 1920 x 1080 Full HD resolution
  • True 16:9 aspect ratio
    View your movies as the director intended
  • Built-in digital tuner
    Watch digital broadcasts, including HDTV programs where available
  • HDMI Inputs: 4
    Enjoy a superior HD experience with HDMI, the one cable audio/video solution
  • 54.64" screen measured diagonally from corner to corner
  • Wall mountable
    VESA standard 400mm x 400mm
  • Theater 3D
    Get amazing 3D picture
Display Menu Language: English, French, Spanish
Additional Features: Ambient light sensor (ALS)
Display Format: 1080p (FullHD)
Resolution: 1920 x 1080
Viewing Angle: 178 degrees
Viewing Angle (Vertical): 178 degrees
Brightness: 360 cd/m2
Color Depth: 16.7 million colors
TV Tuner
Stereo Reception System: MTS
Secondary Audio Program (SAP): Yes
Remote Control
Type: Remote control
Features: QWERTY dual-sided
Audio System
Surround Mode: Yes
Sound Effects: SRS TruSurround HD, SRS StudioSound
Output Power / Total: 20 Watt
Additional Features: SRS TruVolume
Speaker(s): 2 x main channel speaker - built-in - 10 Watt
Connections
Connector Type: 1 x composite video / component video input ( RCA phono x 3 ) - bottom ¦ 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - side ¦ 1 x network ( RJ-45 ) - bottom ¦ 4 x HDMI ( 19 pin HDMI Type A ) - side ¦ 2 x USB 2.0 ( 4 pin USB Type A ) - side ¦ 1 x SPDIF output ( TOSLINK ) - side ¦ 1 x audio output ( mini-phone stereo 3.5 mm ) - side
Jeffj8 is offline
Old 10-09-2013, 10:40 AM
indept's Avatar
Quoted: 84 Post(s)
Liked: 92
I had a 550KDE which I returned, motion blur was terrible. Watching a tv show or movie was ok but any fast motion especially with sports was unacceptable. I had a E551D and it was great except that the 3D had a "jagged" picture so that tv was bad because every other Vizio 3D I've seen is fine, so I'd go with that one, just check it out real we'll when you get it.
indept is offline
