Samsung UHD xx F9000 , xx F9xxx How to play 4K video from USB - AVS Forum
post #1 of 85 Old 10-17-2013, 12:06 PM - Thread Starter
GeorgeFromCrete's Avatar
http://www.avsforum.com/t/1479650/samsung-4k-anticipation-thread-un55f9000-un65f9000-and-un85s9-discusion/540#post_23845979
http://www.avsforum.com/t/1479650/samsung-4k-anticipation-thread-un55f9000-un65f9000-and-un85s9-discusion/540#post_23847267
This procedures probably is for all UHD TV 's.
You can try and tell us.
GeorgeFromCrete is offline
post #2 of 85 Old 10-17-2013, 09:22 PM
JSteel's Avatar
Quoted: 17 Post(s)
Liked: 42
George, see my post in the other thread. I need to know more information on how you got them to play at the same time as the info you have given me does not help. Shots of what you are selecting in the MediaFlow program and how you labeling the files would be helpful. Thanks!
JSteel is offline
post #3 of 85 Old 10-17-2013, 10:48 PM - Thread Starter
OK here the full instruction step by step:
Step 1
Open MEDIAFLOW with these settings:
Step 2
Input the QFHD movie:
Step 3
Make these changes:
Step 4
Push encode 4 files!
Step 5
After the encoding (the time depends from the power of your CPU) put the 4 files in a sub-folder in the root of a USB stick
Step 6
Rename the files
as:
UHD_demo_a_.mp4sub
UHD_demo_b_.mp4sub
UHD_demo_c_.mp4sub
UHD_demo_d_.mp4sub
by this sequel :
*_TL_*.* first top left then as UHD_demo_a_.mp4sub
*_BL_*.* second bottom left as UHD_demo_b_.mp4sub
*_TR_*.* thιrd top right as UHD_demo_c_.mp4sub
*_BR_*.* fourth bottom right as UHD_demo_a_.mp4sub
It works even in mp4 and mpg format!!!
It works even if the 4 HD 1080p files are not the same MB!!!
It works even from a portable HD!!!!!
Step 7
Put the USB stick or the portable HD in the USB of ONE CONNECT of F9000 (doesn' t matter in which of two port)
and from VIDEO section load the UHD_demo_a_.mp4sub
A VOILA !!!
Important PS
As i wrote before,
The only problem is that the program is unregistered and the each output file has their logo. The final view of the QFHD file has 4 logos.
By the way you can load each file alone and see quarter of film.
If you want to see the full QFHD file you load the UHD_demo_a_.mp4sub!!!
PS 2
As i wrote before,
You will see that i played the UHD demos (the format is QFHD) for SONY, LG and SAMSUNG on my f9000 without any problem.
And there are more.
There is a trick that SAMSUNG , SONY and probably all the others have made waiting for H.265(hevc) and HDMI 2.0 appear.
The QFHD format is 4 X HD 1080p
So they cut the 3840 x 2160 panel by 4 (1920 x 1080) and they put each HD 1080p part in the corner and they make the QFHD resolution (4k for commercial)
This mean that if you take a HD movie 1080p and copy the same movie 4 times and rename the four identical files like i wrote before you will see QFHD resolution (UHD) resolution by seeing the same movie the same time *4
I will write down more.
Now, i am looking for a different program to cut the QFHD file.
The write term for the present 4k or UHD SAMSUNG TV is SAMSUNG 4K UHDTV (2160p) TV .
All the others are for commercial.
The different is less than 3% but are not 4K native TVs.
PS 3
The QFHD resolution is Width : 3 840 pixels X Height : 2 160 pixels Display aspect ratio : 1.78:1 (16:9) Pixels : 8,294,400
The 4K resolution is Width : 4 096 pixels X Height : 2 160 pixels Display aspect ratio : 1.90:1 (256:135) Pixels : 8,847,360
post #4 of 85 Old 10-18-2013, 03:40 AM - Thread Starter
Now I am trying with Pavtube Video Converter and After Effects CC and I think it will work!!!
The trick is to crop the 4K movie to 4 equal HD 1080p parts , rename them as I wrote before and put them in a USB stick in a sub - folder to the USB port.
Probably all the video programs that can handle 4K resolution and can crop the video file to 4 equal HD 1080p parts works!!!!!!!
post #5 of 85 Old 10-19-2013, 08:34 AM - Thread Starter
Good afternoon, OK with Pavtube Video Converter it works.
I will be in front of my tv in a couple of days for more information.
Good try (not luck , because it finally work the USB) to all of you!!
post #6 of 85 Old 10-22-2013, 12:53 AM - Thread Starter
Good morning
With Pavtube Video Converter step by step as i promise you :
Step 1
Load the 4K file 4 times to make the procedure in the same time.
(You can do the conversion one in a time)
BE CAREFUL , the resolution of the clip or the movie must be 3840X2160
Step 2
Choose the right format and the output folder.
Then press EDIT SELECTED TASK for each file
Step 3
Choose CROP select AND click to switch to advanced mode
Step 4
For the first file make these changes (1920x1080).
Step 5
Then press Go to settings section.
Step 6
In setting section make the changes you want (for audio and others to output smaller file) and then OK
Step 7
The same for file two
Step 8
The same for file three
Step 9
The same for file four
As you see and understand , each crop windows makes the file you need for F9000
So, using the logic of this procedure you can use any video editing program that can handle 4K resolution
Step 10
After these changes press CONVERT
Step 11
And wait the finish of conversion
(The time depend from the power of your CPU and the memory)
Step 12
At the end you have to rename the files as i wrote in previous post for SAMSUNG F9000
AND enjoy your SAMSUNG TV with 4K resolution
P.S. The row must be exactly the same:
TOP LEFT > BOTTOM LEFT > TOR RIGHT > BOTTOM RIGHT
P.S. 2 Again, sorry for my English.
mitico303 likes this.
post #7 of 85 Old 10-29-2013, 03:34 AM - Thread Starter
post #8 of 85 Old 10-29-2013, 03:50 AM
irkuck's Avatar
Quoted: 25 Post(s)
Liked: 60
You may wish to contribute to this thread if you have relevant information.
irkuck
irkuck is online now
post #9 of 85 Old 11-15-2013, 09:29 AM
Smokedog Stover's Avatar
I tried to download these files but they are un-available?
Smokedog Stover is offline
post #10 of 85 Old 11-15-2013, 11:27 AM - Thread Starter
Hi,
I am still trying.
Four times tried and they suspended my account.
I will inform you by the thread.!
Sorry!!!!
post #11 of 85 Old 11-25-2013, 08:38 PM
DanielNTX's Avatar
Can you make a torrent of the files or upload them to Mega.co.nz?
DanielNTX is offline
post #13 of 85 Old 11-27-2013, 03:45 PM
DanielNTX's Avatar
Thanks... slow downloading... no torrent?
post #14 of 85 Old 11-27-2013, 06:09 PM
bfssed's Avatar
I will be in front of my tv in a couple of days for more informationttHh8k
bfssed is offline
post #15 of 85 Old 11-27-2013, 10:29 PM
UdoG's Avatar
Quoted: 26 Post(s)
Unfortunately no torrent available - if you want a faster download you have to register :-(
UdoG is online now
post #16 of 85 Old 12-05-2013, 11:21 AM
chrisadd's Avatar
Hey guys, here's a magnet link to a torrent of the Samsung UHD Demo files. Enjoy!
magnet:?xt=urn:btih:2d0915d3ea0a99a0fa03e4aaf07c991c7a02345d&dn=OFFICIAL+Samsung+UHD+Demo+Germany+2160p+4K&tr=udp%3A%2F%2Ftracker.open**********.com%3A80&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker.istole.it%3A6969&tr=udp%3A%2F%2Ftracker.ccc.de%3A80&tr=udp%3A%2F%2Fopen.demonii.com%3A1337
chrisadd is offline
post #17 of 85 Old 12-07-2013, 12:24 AM
NazPattison's Avatar
Quoted: 18 Post(s)
Liked: 24
Thanks Chris. Downloaded the torrent yesterday. First true 4K content I've been able to see on my Samsung.
FYI after dowoading drop each of the four sets of four vids into their own folder and the Samsung will recognize them fine.
Let me know if anyone finds a torrent for the 4k IMAX vids Samsung is sending out with UHD purchases. It's only valid for USA and I'm in Australia.
NazPattison is offline
post #18 of 85 Old 12-07-2013, 01:08 PM
chrisadd's Avatar
I'm in the US and I'm waiting for the IMAX movies to be shipped. Once they arrive, I'll see what I can do!
-- Chris
NazPattison likes this.
chrisadd is offline
post #19 of 85 Old 12-08-2013, 07:03 PM
upstate-avfan-da's Avatar
Thanks for posting this up, downloaded last night and this makes it way better to check out the 4k quality without using the crappy youtube 4k videos that won't load.
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #20 of 85 Old 12-09-2013, 08:27 PM
AccordTR's Avatar
Quoted: 18 Post(s)
How do you download from the link:
Samsung UHD 4K UN65F9000, Sharp LC46D64U,
Shaw HD PVR Gateway and Portals,
PS4 500gb launch edition,
Samsung BD-P3600, Sony BDP-S470,
Pioneer VSX-1026, Monster Power HDP 2550
Polk Audio 7.1- CS1, Monitor 70s, Monitor 60s, Monitor 40s, PSW505,
Blu-Ray collection- 572 and counting. See them here
AccordTR is offline
post #21 of 85 Old 12-10-2013, 04:04 AM
First you will need a bit torrent download program. You can get one from **********.com then just copy and paste that string of stuff into your URL bar. Hope that helps!
post #22 of 85 Old 12-10-2013, 06:38 AM
AccordTR's Avatar
Quoted: 18 Post(s)
Thanks! What is the ************* supposed to be, ie what is the blocked site name in the original magnet link?
AccordTR is offline
post #23 of 85 Old 12-10-2013, 06:43 AM
You know, I dont think that was there a cpl days ago? I dont know if ********** saves a history, I am at work so I cant check. If it does I can get you the full link I used.
post #24 of 85 Old 12-10-2013, 06:46 AM
AccordTR's Avatar
Quoted: 18 Post(s)
Thanks, seems this site blocks external links
AccordTR is offline
post #25 of 85 Old 12-10-2013, 06:49 PM
Quoted: 18 Post(s)
Liked: 24
I couldn't get the magnet link to work either but just whack "torrentz.eu" into Google then go to the site and search for "Samsung UHD Germany 4K" and you'll find plenty of torrents that work.
post #26 of 85 Old 12-11-2013, 04:23 AM
odeno's Avatar
Thanks for your work on this George.
I was able to use Mediaflow to get this method to work. However, I have tried Pavtube many times and can not get the files to play properly.
I do exactly as your tutorial shows carefully starting with top left, bottom left, top right and bottom right. Output is set to HD H264. I work with 4 file copies at once and rename output files accordingly. One thing I note is the Mediaflow produces 4 equally sized files while Pavtube produces files of different sizes?
When I try and play these on the TV (F9000) I get a little splutter of music but the screen is blank.
I also notice my TV does not display the .mp4sub files although obviously uses them. It does display the .mp4 files for play.
I would purchase the Mediaflow s/w if it wasn't so expensive.
any thoughts / troubleshooting tips you can offer?
many thanks,
odeno is offline
post #27 of 85 Old 01-07-2014, 03:07 AM
JBA512's Avatar
many thanks,
I was having the same problems and couldn't figure it out
I went back into pavtube to look closer at settings and i got mine to work by having the source and setting match up
Here is the standard settings for a HD H.264 in pavtube
Notice how some of the settings are different in the target column
Here i have changed as much as i can back to original settings
This seemed to make all the difference for me
odeno likes this.
JBA512 is offline
post #28 of 85 Old 01-08-2014, 02:01 AM
odeno's Avatar
Thanks for your reply.
Unfortunately I still have a problem - more specifically, the first quadrant - i.e. TL, the file with "_a_" - will not play on the TV. I've tried several files and with .mp4 / .s4ud extns but they will not play.
This is very strange as I can play these file on a PC fine within pavtube and using quicktime.
I can also play the other quadrants on the TV - i.e. _b_, _c_, _d_. I've used two different PCs with the same issue.
The only thing "different" about this first file is it is the first quadrant.I also tried creating this file by itself from original source (I normally create all 4 files at once) but to no avail.
Any thoughts anyone...?...I must be missing something simple yet subtle.
I also believe the US version of this S9 series - the UNXXF9000AF line up - can play native UHD files.
odeno is offline
post #29 of 85 Old 01-08-2014, 02:48 AM
JBA512's Avatar
Are you using a sub folder on a usb to plug into the tv?
My files wouldn't work through my NAS
JBA512 is offline
post #30 of 85 Old 01-08-2014, 02:56 AM
Clod74's Avatar
hello, I've also the same problems whit Pavtube, i try in each way, but it still don't work.
Halp me please.
Clod74 is offline
Reply LCD Flat Panel Displays
Samsung Un55f9000 55 Inch 4k Ultra Hd Led Hdtv
