Getting Error While Trying to Connect to Netflix ? Tv model #UN46D6000SFXZA - AVS Forum | Home Theater Discussions And Reviews
Old 10-22-2013, 04:46 PM - Thread Starter
xintensex's Avatar
When I try to launch Netflix, it immediately loads an error message "Cannot connect to Netflix. Try again or visit.?
xintensex is offline
Old 10-24-2013, 01:07 AM - Thread Starter
xintensex's Avatar
Anyone ?? I ve tried Everything ? Factory Resets, hub resets, change dns to 8.8.8.8 and 8.8.4.4 tried wireless and Lan ??
Old 10-24-2013, 05:57 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Start > windows search >type "cmd" > at win syst 32 prompt type "ipconfig /flushdns" press enter
ofc you will be typing without quotation marks
response should be "dns cache flushed successfully".
Close dos/admin window then try to reconnect you may have corrupt dns cache this will fix that at least and if that was the prob (could be) it will fix it. Windows will re build the dns cache file .
tubetwister is offline
