Panasonic TC-50LE64 / TC-L50E60 Audio Sync Issue - AVS Forum | Home Theater Discussions And Reviews
Old 10-26-2013, 01:59 PM - Thread Starter
theking84's Avatar
I just bought the Panasonic TC-50LE64 (same as TC-L50E60) yesterday and while I'm very impressed with the picture quality and the sleek deign there has been an issue with the audio. I have been running audio directly out of tv to a receiver and there is a delay with the audio causing everything to fall out of sync.
I have tried different settings, talked to Panasonic support (which was useless) and can't find a solution.
My previous tv did the exact same setup and there was never a delay with the audio.
Does anyone else know of a fix for this? I really don't want to return the tv but have been very frustrated with it.
theking84 is offline
Old 10-28-2013, 10:28 PM - Thread Starter
theking84's Avatar
Over 40 view but no comment of advice or help.
Has anyone found a solution for this issue? I've seen other discussion about this issue with other models but nobody has said if there is anything to solve it.
Old 10-29-2013, 01:03 PM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1276
With some TVs, audio sync issues can be minimized (or completely eliminated) by disabling all of the image processing features on the set. You should also experiment with the audio sync settings on your AV receiver if you have not done so already.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is offline
