Sound bar for VIZIO M801d-a3 80inch TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-27-2013, 06:34 PM - Thread Starter
JoeMorrow7's Avatar
Looking for a recommendation for a sound bar for the 80 inch VIZIO I am buying soon. The TV will not be wall mounted. The sound bar will sit in front of the TV. So I need a sound bar that is low profile enough not to block the TV remote receiver, or one with an RF repeater on the back. I also want an HDMI connection. I am looking to spend no more than $350 for the sound bar. The longer the better for this TV.
Suggestions?
JoeMorrow7 is offline
post #2 of 4 Old 10-27-2013, 09:07 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
You should probably post this question in the sound bar section.
colour is offline
post #3 of 4 Old 11-09-2013, 11:48 AM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Get the Vizio 5.1 sound bar surround sound system. But with a TV this big you should go with a full surround sound speaker system, it will rock your house like a movie theater!
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
PlayNice is offline
post #4 of 4 Old 06-13-2014, 09:40 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Does the Vizio 5.1 sound bar block the Vizio 80" TV?
Resurrecting an old post here, but I am curious if anyone who does not wall mount their M801 has used the Vizio 5.1 sound bar on a entertainment center in front of the TV. You'd think they would design them to work together but on paper they don't seem to. The spec for the 80" suggests the stand only adds about 2.3" to the height. The bezel appears quite minimal. Yet the Vizio 5.1 sound bar measures almost 4" tall. Seems like it should end up blocking about 1.5" of the TV image. And that would suck.
Has anyone tried this setup? Can anyone please measure the real-world height between the surface of a entertainment center and the beginning of the viewable image on the 80"?
Thank you.
Citivas is offline
Reply LCD Flat Panel Displays
Vizio M801d A3 80 Inch 3d Led Hdtv
