LG LN5400 (540V) question - turn off the 120hz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-07-2013, 06:27 AM - Thread Starter
xzibit2013's Avatar
"120Hz can't be turned off. This can make movies seem too real, what is known as the soap opera effect. It bothers most people and with most 120Hz TVs this can be turned off. With this TV it can not. "
Its real? Can i off it without renaming to pc?
Please reply anyone
xzibit2013 is offline
post #2 of 11 Old 11-07-2013, 07:43 AM - Thread Starter
xzibit2013's Avatar
Dont ignore me
post #3 of 11 Old 11-07-2013, 08:10 AM
8mile13's Avatar
Quoted: 1479 Post(s)
Liked: 825
-> Tru Motion Off ( Motion Interpolation - Motion Smoothing)
http://en.wikipedia.org/wiki/Motion_interpolation
and Turn off all Motion Smoothing options: check out which options are making motion more smooth.
Here are some LN5400 settings, as you can see lots of stuff is turned off
http://reviews.lcdtvbuyingguide.com/lg-lcd-tv/lg-ln5400-picture-settings.html
120Hz has two elements refresh rate and motion interpolation
http://www.rtings.com/info/what-is-the-refresh-rate
xzibit2013 likes this.
8mile13 is offline
post #4 of 11 Old 11-07-2013, 12:05 PM - Thread Starter
xzibit2013's Avatar
The problem this TV don't have this function in the menus like others!!! Read the reviews frown.gif
post #5 of 11 Old 11-07-2013, 12:09 PM - Thread Starter
xzibit2013's Avatar
Omg thanks you so much, so i can turn it off via menus? Thanks you sooooo much for the info!!!
post #6 of 11 Old 11-07-2013, 12:44 PM - Thread Starter
xzibit2013's Avatar
So, this tv is good and soap opera effect can be turned off?
post #7 of 11 Old 11-07-2013, 02:02 PM
8mile13's Avatar
Liked: 825
If your TV is the LXXN5400 there should be a TRU MOTION option (on/off, low, mid, high etc..) in the PICTURE OPTIONS mode. When this option is turned off SOE (soap opera effect) should be gone for the most part.
8mile13 is offline
post #8 of 11 Old 11-07-2013, 03:04 PM - Thread Starter
xzibit2013's Avatar
how understand "gone for the most part"?? not at all?!
post #9 of 11 Old 11-07-2013, 05:35 PM
8mile13's Avatar
Liked: 825
On my 100Hz LED option Film Mode1 (something like LG Real Cinema i think) does some (just a bit) Motion Smoothing. I have a choice between Film Mode 1 and Film Mode 2, they basically do the same thing - make movies look the way they should look - Film Mode 1 does that with a bit of motion smoothing, Film Mode 2 without any extra motion smoothing. So when i turn off MotionFlow ( Tru Motion) on my TV and not use Film Mode 1 picture motion looks natural.
SOE you will only get when Tru Motion is turned on (Lots of motion smoothing).
8mile13 is offline
post #10 of 11 Old 11-08-2013, 04:31 AM - Thread Starter
xzibit2013's Avatar
You even don't know how you help me, i will get this TV!!! Thanks you...
post #11 of 11 Old 03-09-2014, 12:16 PM
yeahman45's Avatar
I am planning to buy this tv. Can someone confirm that the true motion soap opera effect can be turned off... thx
yeahman45 is offline
Reply LCD Flat Panel Displays
Lg Electronics 55ln5400 55 Inch Led Lcd Hdtv With Smart Share
