Differences between Samsung 7100 series vs 8000 series? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-12-2013, 10:22 AM - Thread Starter
eddyxwb's Avatar
Quoted: 28 Post(s)
Guys,
It has been over five years and now I am in the market for TV on this Black Friday. I am considering getting 65" Samsung 7100 or 8000 models and I need help which is good for movies and sports. My budget is between 2 to 2500.
I would appreciated if you guys can point me to the right direction.
eddyxwb is offline
post #2 of 4 Old 11-12-2013, 10:30 AM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
I think the 8000 is >$2500?
Sent from my SCH-I605 using Tapatalk
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #3 of 4 Old 11-12-2013, 12:58 PM - Thread Starter
eddyxwb's Avatar
Quoted: 28 Post(s)
Thanks for the input. But what would you recommend if I say between 2k to 3500 is my budget? Would you consider something else? I have a 50" Panasonic 720p Plasma and I am way overdue for new one.
eddyxwb is offline
post #4 of 4 Old 11-12-2013, 02:58 PM
Quoted: 83 Post(s)
Liked: 41
I only really know Samsung, I would eye the F8000 definitely if I could afford it. It is the flagship set and from what I can tell is great quality with the microdimming ultimate instead of lesser microdimming solution.
Reply LCD Flat Panel Displays
Samsung Un46es7100 Led Hdtv , Samsung Un60es7100 Led Hdtv , Samsung Ue40f8000 , Samsung Un46es8000 Led Hdtv
