$4000. budget for led lcd- can I get a good full array 50 to 60 set - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2013, 05:49 PM - Thread Starter
Henry Ferris's Avatar
The title pretty much says it all. Budget $4000.
Can I get a good full array in the 50 to 60 range from sony, sharp, Panasonic or Samsung.
The reason for these names is I only have one store to pick from. I live in northern BC.
I do not need 3d but if its all in the package so be it.
If the full array is not important for an outstanding pic I would consider an edge unit.
We live on a remote ranch and the tv is used by many family members at different times. It is usually on for 14 hours a day. Our last tv a sony xbr lasted 5 years. I am going to make the 3 hour drive to talk over options with the store owner tomorrow.
Thanks for any insights. Henry
Henry
Henry Ferris is offline
post #2 of 5 Old 11-13-2013, 07:47 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
The last full array LCD Sony made was the XBRHX950, if you can find one. 2013 models are not full array. Panasonic, Sharp and samsung don't have any unless you go 80" or 90" Sharp Aquos or you get lucky and find a Sharp Elite. Full array will give you better picture quality. If you can't find one I would look into the new Sony KDL-55W900a it is Sony's 2nd top of the line. The top of the line Sony, is the 4K but it's over your budget.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 5 Old 11-13-2013, 09:52 PM
MCaugusto's Avatar
Quoted: 322 Post(s)
Liked: 201
I agree with what the other posters mentioned; Try your best to get the Sony XBRHX950 either in 55" or 65" and you'll be getting essentially state-of-the-art performance as far as LCD screens are concerned according to the test report done by Home Theater Magazine in December 2012.
The reviewer gave the Sony XBRHX950 55" model a stellar review and even mentioned that side by side with a Panasonic plasma display in a darkened room the Sony exhibited better black level and low-level detail in dark grey scenes which became even more noticeable in bright, well lit room settings, a feat that is very/very unusual.
The review is available online.
MCaugusto is offline
post #4 of 5 Old 11-14-2013, 11:07 AM
SonyPhila's Avatar
If you're interested we can get the XBR55HX950 for you
SonyPhila is offline
post #5 of 5 Old 11-16-2013, 07:15 PM
twotonedkiller's Avatar
The sony w900a is a good bet i have one. Great pic quality just be wary of uniformity. Some have dark edges on white back ground.
twotonedkiller is offline
Reply LCD Flat Panel Displays
Sony Xbr 55hx950 Bravia Led Hdtv , Sony Kdl 55w900a 55 Inch Led Hdtv
