**Official** Samsung 4K UN55F9000, UN65F9000, and UN85S9 Thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #1801 of 2478 Old 07-06-2014, 06:08 PM
carbonwhiskey's Avatar
Quoted: 24 Post(s)
If anyone has the time, could you check the gap between the black bezel and the silver outer bezel on the right and left sides of the TV?
There seems to be a larger gap on the right side of my TV than the left. The left is very tight, almost touching, and the right has a 2mm gap. It's like panel gap misalignment on cars. Coincidentally, light bleed is worse on that side.
carbonwhiskey is offline
post #1802 of 2478 Old 07-06-2014, 07:47 PM
Dr.Shankenstein's Avatar
Quoted: 234 Post(s)
Liked: 142
Mine is tight at the top,but wider at the bottom I have light the shines against the chrome ribbon and along the bottom of the screen.
Check out my post on 1744 and 1748.
Dr.Shankenstein is online now
post #1803 of 2478 Old 07-06-2014, 09:29 PM
almagueram's Avatar
Here are some S4UD YouTube 4K videos to test...
Let me know how they work!
BIRDS OF PREY 4K ULTRA HD 60fps - YouTube
Aruba: 19 Miles of Happiness - 4K - YouTube
almagueram is offline
post #1804 of 2478 Old 07-06-2014, 09:54 PM
Quoted: 24 Post(s)
But how is left compared to right?
Mine is tight on top and there is a 2-3mm gap on the bottom. But the bottom looks to be a purposeful design, since the glow under the Samsung logo shines through it.
Left/Right seems to be build quality issues.
post #1805 of 2478 Old 07-07-2014, 05:14 AM
Quoted: 234 Post(s)
Liked: 142
Mine is definitely along the right/left bottom of the screen.
carbonwhiskey likes this.
post #1806 of 2478 Old 07-07-2014, 08:27 AM
safcsat's Avatar
Quoted: 33 Post(s)
Can I ask guys - what is the latest firmware I can use (and where from) on my TV?
I have the UA65F9000 - Its the UAE version, does this restrict me to UAE only? Assuming not as others are using non standard firmware..
*edit* currently on version: 2009
safcsat is offline
post #1807 of 2478 Old 07-07-2014, 11:26 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
No one is using non standard firmware, this is impossible. If you try to install wrong region firmware your TV won't accept it.
I have no idea what's the latest version available for your region, you should check on your local Samsung support website.
Samsung UE65F9000ST + SEK-3500U/ZG (European firmware v1421.2)
Samsung UE78HU8500TX (European firmware v1290.2
poisike is offline
post #1808 of 2478 Old 07-07-2014, 01:09 PM
Quoted: 24 Post(s)
Anyone noticing a non-even white on the screen? The sides look pinkish, and the middle has a yellow tinge to it. It is very subtle, but noticeable.
I've seen this on a lot of iPads as well, and I believe Samsung used to make iPad screens too.
post #1809 of 2478 Old 07-07-2014, 02:26 PM
Quoted: 234 Post(s)
Liked: 142
I have,but only on a pure white screen
post #1810 of 2478 Old 07-07-2014, 08:50 PM
Quoted: 234 Post(s)
Liked: 142
The Samsung technician from the local electronics repair shop called to get details on my issue with my set. She asked what the symptoms were if I could send pics and he would be able to get back quickly with an appointment set-up. She called back shortly after receiving pics to ask a few follow up question involving transport and delivery and the condition of the box.
I once again explained that there was no box that I had purchased open item. I said yes and once again she said she would get back to me shortly. After a short time she called back saying that Samsung would allow them to come out and inspect the display,but if physical damage or apparent tampering were seen the warranty would be void. While the retailer I purchased the TV from is a certified retailer,service center and refurbished display provider I still purchased a used TV.
I ended up returning the TV and will patiently wait for the holiday sales hit before attempting to pick up another.
post #1811 of 2478 Old 07-07-2014, 09:36 PM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
That is a shame because this is such a good TV but I think you have probably made the best choice. Even if they had fixed it free of charge you would likely always feel like something was wrong with it. At least I know I would. Maybe stay away from open boxes for awhile though
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #1812 of 2478 Old 07-07-2014, 10:35 PM
safcsat's Avatar
Quoted: 33 Post(s)
I thought people were downloading firmware from Korean Samsung support site - that was what made me ask.
Waste of time checking my local region, they have nothing, they are also still telling people in the shops (Samsung promise me they train the staff...) that this F9000 supports all 4K including netflix (as long as you use a VPN)
Been asking them when the SEK-2500U will be available and they have no idea what it is (Samsung UAE) and tell me that the set doesn't need it as it is already 4K......
safcsat is offline
post #1813 of 2478 Old 07-07-2014, 10:39 PM
sikclown's Avatar
Liked: 691
Here in the US we have been downloading the firmware early from the Korean website. US models and Korean models are the same as is their firmware. I can't speak for any other regions though.
sikclown is offline
post #1814 of 2478 Old 07-07-2014, 10:42 PM
safcsat's Avatar
Quoted: 33 Post(s)
Ah, so that would explain it.
Regretting buying this set now, especially here - the support is just non existent.
Probably not worth risking the Korean/US firmware, altho maybe it will work....expensive mistake though if it doesn't as assuming the TV could be bricked? Or is it just a case of it won't work and as long as I have a backup of the correct firmware I'm good to re-flash?
Also tempted to buy a SEK-2500U from elsewhere, as I don't see it appearing here anytime soon. Then again however the thing won't work unless the firmware for the region it's from works on my set?
safcsat is offline
post #1815 of 2478 Old 07-07-2014, 10:57 PM
sikclown's Avatar
Liked: 691
The US/Korean firmware would not even be able to be installed on your set with out some hacking and tweaking and even then probably not with good results. Where are you again?
sikclown is offline
post #1816 of 2478 Old 07-07-2014, 10:58 PM
safcsat's Avatar
Quoted: 33 Post(s)
Yeah good point, so they are region locked?
I'm in Abu Dhabi at the minute - so my model is UA65F9000.
safcsat is offline
post #1817 of 2478 Old 07-07-2014, 11:20 PM
sikclown's Avatar
Liked: 691
Wow , that model is completely gone from their support pages but it (likely) uses the same firmware as the UA85S9. I am basing that on the fact that the Un65f9000 and UN85S9 (US models) with the 2013 One Connects use the same firmware. Here is a link to that firmware but you would likely get this firmware from your TVs Software Update menu anyway.
http://www.samsung.com/sa_en/support...RXUM-downloads
As far as the 2014 UHD Kit for your region, I can only assume is is the SEK-2500U/AR based on your region code but it doesn't seem to exist.
safcsat likes this.
sikclown is offline
post #1818 of 2478 Old 07-07-2014, 11:22 PM
safcsat's Avatar
Quoted: 33 Post(s)
Haha yep, exactly! It's just vanished.
Good theory there however, I like it - just checked and the firmware available there is later than mine, I am on 2009.
Are the SEK-2500U kits region locked?
safcsat is offline
post #1819 of 2478 Old 07-07-2014, 11:30 PM
sikclown's Avatar
Liked: 691
I can't be positive on that one. I think so but don't quote me. At the very least you would probably not get full functionality out of it. What is your complete model #? UA65F9000AR and maybe a few more letters?
sikclown is offline
post #1820 of 2478 Old 07-07-2014, 11:56 PM
safcsat's Avatar
Quoted: 33 Post(s)
Knowing my luck I would buy it and it won't work so maybe best I hold off. Or find somewhere which will accept a return.
Full model is UA65F9000ARXZN
safcsat is offline
post #1821 of 2478 Old 07-08-2014, 12:02 AM
sikclown's Avatar
Liked: 691
Here is the link to your model's downloads (it may not load in a mobile browser) http://www.samsung.com/ae/support/mo...RXZN-downloads and it looks the same as the UA85S9 so that theory is correct. Doesn't help with an Evolution Kit though.
safcsat likes this.
sikclown is offline
post #1822 of 2478 Old 07-08-2014, 12:41 AM
safcsat's Avatar
Quoted: 33 Post(s)
Aha, perfect so it does confirm the UA85S9 theory, brilliant.
Will download that when I get home and install, thanks very much.
So tempted to just buy an evo kit and try it...but I've wasted enough money so far this year maybe should wait!!
safcsat is offline
post #1823 of 2478 Old 07-08-2014, 01:45 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
It seems these are not region locked. I have seen someone from Australia buying a US SEK-2500U and it worked on his Australian TV, but of course the built in tuner didn't work.
But you need to be able to make a backup before you can use the new SEK-2500U. As far as I remember, the firmware v2009 didn't have this option, so you can't install the SEK-2500U. If I remember correctly then you need firmware starting with 21xx.
poisike is offline
post #1824 of 2478 Old 07-08-2014, 01:51 AM
safcsat's Avatar
Quoted: 33 Post(s)
Ah, interesting! I think the Australian models are also UA* prefix...so could be onto a winner, except the firmware...unless other regions firmware works, the latest I can get seems to be 2010.1 - unless by some miracle this usb only firmware may then enable a more recent OTA...doubt it mind.
I may just buy it and see
safcsat is offline
post #1825 of 2478 Old 07-08-2014, 11:36 AM
sikclown's Avatar
Liked: 691
The are a UA prefix but the model ends in AM vs AR in your case. Have you installed the 2010.1 firmware to see if the UHD Evolution Kit backup is now in your TV menu?
sikclown is offline
post #1826 of 2478 Old 07-08-2014, 05:16 PM
Quoted: 234 Post(s)
Liked: 142
In a case of "that just doesn't happen" and the way my luck has gone with my purchase the Samsung technician emailed and called to tell me my TV had been ordered and would be delivered as soon as the repair center received it. I was contacted by email a short time later by the service center saying that my TV had been ordered and they would be out to replace mine upon receipt.
I emailed explaining that I had decided to return and wait for the holidays to buy an actual "new" model. She called moments later to ask if the return had been made already,since Samsung had authorized to replace the entire TV with a new in the box item. I asked,"they were sending a replacement screen"? She said no,they had authorized a full replacement due to the circumstances,doh!
That is my luck,but good on Samsung.
post #1827 of 2478 Old 07-08-2014, 05:25 PM
sikclown's Avatar
Liked: 691
Ohhhh....... I am speechless....
sikclown is offline
post #1828 of 2478 Old 07-08-2014, 05:35 PM
Quoted: 24 Post(s)
Wow. A Brand-new unit, or a refurb?
I've never heard of Samsung being so good with warranty issues. All I've read is horror stories.
That's awesome though, especially considering it was open-box.
I just bought a squaretrade 5 year warranty for mine.
post #1829 of 2478 Old 07-08-2014, 06:08 PM
Quoted: 234 Post(s)
Liked: 142
Either would have been great,but they called a day late.
post #1830 of 2478 Old 07-09-2014, 03:08 AM
denisoftus's Avatar
Quoted: 58 Post(s)
Does anyone know how to switch off screen dimming on empty picture. It is really irritating on some scenes sometimes.
denisoftus is offline
Reply LCD Flat Panel Displays
Samsung Un55f9000 55 Inch 4k Ultra Hd Led Hdtv , Samsung Un65f9000 65 Inch 4k Ultra Led Hdtv
