**Official** Samsung 4K UN55F9000, UN65F9000, and UN85S9 Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #1981 of 2483 Old 10-05-2014, 04:32 AM
BillMilosz's Avatar
NetFlix in 4K
Your NetFlix plan has to include 4K, I think this costs more.
See http://help.netflix.com/en/node/13444
BillMilosz is offline
post #1982 of 2483 Old 10-05-2014, 04:38 AM
Liked: 1
Yes, thank you sir! I was only on the 2 screen HD plan.
TheMonarch is offline
post #1983 of 2483 Old 10-05-2014, 05:23 AM
Martinuz's Avatar
Quoted: 58 Post(s)
you also have new box?
Martinuz is offline
post #1984 of 2483 Old 10-05-2014, 03:02 PM
pettern's Avatar
Quoted: 95 Post(s)
Liked: 38
Originally Posted by Fredrik Lundholm View Post
In fact I am disappointed with F9000 as a 1080p monitor for computer.
Fonts does not look perfect and I can see multi colored upsampling artifacts around letters.
Rename the input to PC to disable the processing that does this.
pettern is offline
post #1985 of 2483 Old 10-06-2014, 07:00 AM
Liked: 1
@Martinuz (sorry my post count isn't high enough yet to post with quotes...I'm a noob).
Yeah...after calling Netflix I found out that I need the Samsung Evolution Kit (SEK-2500U) in order to receive 4k content on my 2013 UN65F9000. Not sure I'm ready to drop $400 on the Evo Kit with so little 4k content currently available. I'll probably wait till the next season of House of Cards before making the investment. Thanks for the help though.
post #1986 of 2483 Old 10-06-2014, 08:59 PM
dannybee's Avatar
Quoted: 241 Post(s)
Liked: 125
Has anyone seen or heard of the upcoming samsung amazon app for streaming 4k.
dannybee is online now
post #1987 of 2483 Old 10-07-2014, 05:56 AM
Liked: 1
Interesting, I tried HDM1 and HDM2 inputs, renamed them to PC but I could not affect the issue.
Is there a particular setting I can try?
Fredrik Lundholm is offline
post #1988 of 2483 Old 10-08-2014, 10:18 AM
Martinuz's Avatar
Quoted: 58 Post(s)
it's not only netflix 4k, it's also better in handeling all material, faster processor for apps, websites etc etc. It's more. If you live in the us, you will get more 4k. Still need to re-configurate to get the us netflix
Martinuz is offline
post #1989 of 2483 Old 10-08-2014, 03:20 PM
Liked: 0
Flickering and motion problems
Hi Im new & hope you can help me. My 55f9000 flickers very briefly sometimes (quite often actually) after a scene change and sometimes has to think for a second about screen brightness before stabilizing. Motion is very juddery on certain pans and sometimes there is a halo all around fast moving people in a scene. Tried every setting known to man to get rid of this and rang Samsung who after weeks of hounding got repair company to call me. The guy said no point coming to see the TV as they know what the problem is and ordered me a new screen. Well screen fitted today and problem is still there. Just a thought but I think the problems all began after updating firmware on the original one connect box. Anyone else suffered these problems
jakethepeg is offline
post #1990 of 2483 Old 10-12-2014, 10:27 PM
John5mith's Avatar
Quoted: 17 Post(s)
I definitely get the compression Halo's I use apple TV and a PC. Perfect condition for this is if you have a reasonably central and small object moving across a landscape. I can also emulate when I move the mouse cursor over a grid pattern when connected to the PC. This is when running native 4k resolution. I would be very interested in a solution.
I have just purchase the SEK 2500U so will see if that makes a difference.
John5mith is offline
post #1991 of 2483 Old 10-12-2014, 11:42 PM
Martinuz's Avatar
Quoted: 58 Post(s)
sometimes I really think, the old box was at least as good in motion handling.
Martinuz is offline
post #1992 of 2483 Old 10-14-2014, 09:20 AM
VRWRX's Avatar
By this do you mean that the new box is significantly better at motion handling?
My only issue with the old box is some momentary juddering when watching live sports. I hesitate to upgrade because everything else works perfectly and the picture is great. I worry about picture and sound issues with the new box.
VRWRX is offline
post #1993 of 2483 Old 10-14-2014, 09:29 PM
Quoted: 14 Post(s)
Liked: 1
Does 200hz improve motion handling? or is this just a gimmick on LG tvs?
achandab is offline
post #1994 of 2483 Old 10-19-2014, 03:32 AM
wolfavs's Avatar
Originally Posted by wolfavs View Post
Network issues with cabled network connection
I just got the Euro version of this TV, UE65F9005. Great picture and sound even though it really can´t handle 4K media in an easy way.
My problem is that cabled network connection doesn´t work. Wireless is OK but since I have 1000Mb/s fiber connection to internet I really want the best speed possible also through the TV.
When I connect the network cable I can select cable in the network setup meny. The TV also gets an internet connection (DHCP assign etc). Within a couple of seconds I get the message ”Network cable disconnected.” on top of the screen together with an OK-button. If I don´t do anything the message disappears after a few seconds. The same message then appears every couple of minutes.
My home network is pretty extensive with the following setup: fiber internet -> Apple Airport Extreme router (the latest tower model) -> D-link 8-port Gigabit switch DGS-1008D -> D-link 8-port Gigabit switch DGS-1008D -> Samsung UE65F9005.
The switch is indicating a Gigabit connection to the TV. I tried to change network cable, change switch port and also connected directly to the router (bypassing the two switches in-between) with no success. The TV has had the same problem with all firmware versions 1XXX to 2006.0. I have used the more-or-less identical network setup with a least 4 previous Samsungs without ANY problems. The last TV I used with exactly the identical setup was a PS64D8005, worked perfectly.
I would appreciate any ideas about this problem.
Apart from this the TV is great and I really would like to avoid changing the whole TV and risk getting a panel other problems. It´s also a hassle to pack and return etc etc. I ordered in-house Samsung service but these guys are basically clueless. The technicians says the have to change the ”motherboard” inside the screen together with the connection box. I don´t believe this, because that would mean that the announced Evolution Kit connection box couldn´t be user installed. ”jwegger” s tests earlier in the thread also confirms that the connection box is NOT hard-paired to a specific screen…
Samsung tech are waiting for parts so they haven´t been here yet. I would of course just prefer to change the connection box myself. The problem is that I have heard about two other people with the same strange problem and in those cases they couldn´t solve it even after an exchange of the whole TV-set.
Just want to do a final report on this issue:
After installing the new SEK-2500 Evo box the cabled network issue is fixed. So it seems that it was something in the network interface hardware on the old SEK-1000 box that caused the problem. In this case I am a quite happy Samsung customer since I got the new Evo box for free. It took a while but the local Samsung support did well in the end. The TV is still great and the new box adds a lot of other good features.
sikclown likes this.
wolfavs is offline
post #1995 of 2483 Old 10-23-2014, 09:25 AM
roller11's Avatar
Quoted: 645 Post(s)
Liked: 101
Has anyone in this forum tested their f9000 for chroma 444 at 4K/24Hz? 4K/60 Hz?
roller11 is offline
post #1996 of 2483 Old 10-23-2014, 09:28 AM
sikclown's Avatar
Quoted: 1509 Post(s)
Liked: 754
I haven't had a chance to get to that. My PC is connected to my UN55HU8550 through my GTX 970. I haven't really tested it on my HU8550 as I have been out of town but I should have some time in the next few weeks to test. Probably not going to lug my PC downstairs to test on my f9000 though.
LG OLED 65C7P, Denon AVR-X7200WA, Apple TV, Oppo UDP-203, PS4, Xbox One
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000, Denon x4200w, Apple TV, Panny BDT460, HTPC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #1997 of 2483 Old 10-23-2014, 10:15 AM
roller11's Avatar
Quoted: 645 Post(s)
Liked: 101
Thanks for the response sikclown.
No need for a HDMI 2.0 video card, do you have any desktop computer connected to the f9000? This quick test could result in a fix for the samsung chroma 444 issue.
roller11 is offline
post #1998 of 2483 Old 10-23-2014, 10:17 AM
sikclown's Avatar
Liked: 754
You need an HDMI 2.0 card to do 4k@60hz with full 4:4:4 chroma. Nope I only have the one PC upstairs. I use my tablet for everything else and basically Remote Desktop anytime I need to get on my PC.
sikclown is offline
post #1999 of 2483 Old 10-23-2014, 10:21 AM
roller11's Avatar
Quoted: 645 Post(s)
Liked: 101
Right, I need a 4K /24Hz test which any HDMI1.4 card can do. Hopefully someone will respond from this or the sek2500u group.
roller11 is offline
post #2000 of 2483 Old 10-28-2014, 07:02 PM
pphx459's Avatar
Liked: 0
Has anyone tried the new 1180 firmware, can't find much info about it
pphx459 is offline
post #2001 of 2483 Old 10-28-2014, 07:53 PM
sikclown's Avatar
Liked: 754
I installed it, haven't noticed anything new. Probably just bug fixes.
sikclown is offline
post #2002 of 2483 Old 10-29-2014, 12:44 AM
Martinuz's Avatar
Quoted: 58 Post(s)
is there a direct link? and what coontinent?
DonCzar likes this.
Martinuz is offline
post #2003 of 2483 Old 10-29-2014, 12:50 AM
wolfavs's Avatar
I have access to a MacBook Pro 15 Retina (Late 2013) and can connect through HDMI. What do you want to try exactly?
wolfavs is offline
post #2004 of 2483 Old 11-01-2014, 10:49 PM
RTdigital's Avatar
Liked: 0
Since this last update I'm noticing very poor motion artifacts. That "halo" is really bad now. Worst are panning left to right. Think I'm going pull out evo kit and put in old one see if it goes away.
RTdigital is offline
post #2005 of 2483 Old 11-02-2014, 04:28 PM
John5mith's Avatar
Quoted: 17 Post(s)
I have un55f9000 and SEK-2500U/xy and an Nvidia 750Ti.
I can get the original One connect to take UHD@30hz but I have not tries 24Hz or been able to set or test 4:4:4. If you give me a little guidance I would be happy to test. My plan was to get a 970 next so if i can help you get it working it should help me too
post #2006 of 2483 Old 11-11-2014, 06:10 PM
Quoted: 34 Post(s)
Liked: 2
Bluetooth headphones
Does anybody know a way to get bluetooth headphones working with this tv, and without audio lag?
chandlogan is offline
post #2007 of 2483 Old 11-12-2014, 05:00 PM
sikclown's Avatar
Liked: 754
I don't know if anyone has mentioned it but the latest 9000 firmware (1191) not only adds MGO 4K (very limited selection) but also adds a Downloaded section to the 2nd UHD Drive. Not sure where we download them from but it looks like the drive will allow us to add content via download.
sikclown is offline
post #2008 of 2483 Old 11-18-2014, 09:38 PM
John5mith's Avatar
Quoted: 17 Post(s)
Which region are you in?
post #2009 of 2483 Old 11-18-2014, 09:55 PM
John5mith's Avatar
Quoted: 17 Post(s)
Latest update is I got a replacement sek2500 and the issue persists the eve kit will not display even 1080p from my PC running the NVIDIA card.
That was super disappointing but what is even worse is I am now getting the run around in the support process.
What I would like to know is do you guys/gals think I should be given a new TV + One connect that works with my PC?
Basically the only reason I purchase this TV was because samsung was saying that they would upgrade the one connect box in the future and that would run UHD@6Hz full chroma. Now I have all the kit and it doesn't.
You might argue that the Screen that I purchased is working as advertised to the original spec? I think it doesn't because the original marketing was "buy this tv cos its future proof and will run UHD@60Hz on HDMI 2.0 down the track"
Would love to hear your thoughts.
post #2010 of 2483 Old 11-19-2014, 09:05 AM
sikclown's Avatar
Liked: 754
US
sikclown is offline
Reply LCD Flat Panel Displays
Samsung Un55f9000 55 Inch 4k Ultra Hd Led Hdtv , Samsung Un65f9000 65 Inch 4k Ultra Led Hdtv
