**Official** Samsung 4K UN55F9000, UN65F9000, and UN85S9 Thread - Page 73 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #2161 of 2478 Old 04-14-2015, 01:41 AM
Martinuz's Avatar
Quoted: 58 Post(s)
Originally Posted by muhriver View Post
Hallo.
I own a samsung f9000 with the EVO SEK2500U kit, i am having some trouble with toggling the picture sittings. i cant chance it from stadion, and go into the advanced picture settings.
can anybody help me?
in the settings option, there is a setting football mode with a on and off switch... football mode is probably also on your remote, lowest row.
Martinuz is offline
post #2162 of 2478 Old 04-18-2015, 08:46 AM
dannye's Avatar
Does anyone know if Amazon Prime UHD is working for the Samsung F9000 yet? I read somewhere that it was coming early this year.
dannye is offline
post #2163 of 2478 Old 04-18-2015, 08:57 AM
rlb
rlb's Avatar
Quoted: 1701 Post(s)
Liked: 1354
It definitely works if you have the SEK-2500U (2014 UHD Kit). I forget if the original one connect was capable of receiving the Netflix and Amazon 4K streaming.
rlb is offline
post #2164 of 2478 Old 04-18-2015, 08:59 AM
dannye's Avatar
Yes, I have the SEK-2500U and Netflix works fine in 4K, I just didn't know if there are any 4K titles on Amazon yet. Thanks
dannye is offline
post #2165 of 2478 Old 04-18-2015, 02:08 PM
rlb
rlb's Avatar
Liked: 1354
Yes, they have a UHD "icon" on the Amazon Prime home page. Probably more available than on Netflix. Maybe 6-7 original programming series or programs, 3-4 movies and some shorts. Also, they have quite a few "pay" movies. Altogether, 25 or so selections.
rlb is offline
post #2166 of 2478 Old 04-18-2015, 02:58 PM
dannye's Avatar
OK thanks, I'm not seeing any UHD titles on Amazon Prime with my F9000 and SEK-2500U... anyone else have the same problem?
dannye is offline
post #2167 of 2478 Old 04-18-2015, 04:43 PM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
They are all under a uhd section. Also go look for Amazon Originals. Most of them are available in 4k
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #2168 of 2478 Old 04-19-2015, 06:16 AM
dannye's Avatar
So if I search for "uhd", it shows me Transparent, Angels and Demons and Spider-Man 2, but they are still labelled as just HD. There are no titles actually listed with UHD. Are these working OK on your F9000?
dannye is offline
post #2169 of 2478 Old 04-19-2015, 06:35 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
I have UHD labels on top left corners of cover images. And a separate UHD banner on front page of Amazon app.
Do you have the latest app version? What region are you using? US? UK? DE?
Samsung UE65F9000ST + SEK-3500U/ZG (European firmware v1421.2)
Samsung UE78HU8500TX (European firmware v1290.2
poisike is online now
post #2170 of 2478 Old 04-19-2015, 06:43 AM
dannye's Avatar
It's the only version of the app I can see, Amazon Instant Video. There are definitely no UHD labels anywhere. Is it possible to delete those apps and re-install them?
dannye is offline
post #2171 of 2478 Old 04-19-2015, 06:56 AM
dannye's Avatar
Ah-ha, figured it out. I didn't realise you could update the apps... which I have now done and it's working. I can now see all the UHD titles in Amazon! Thanks for your help all.
rlb likes this.
dannye is offline
post #2172 of 2478 Old 04-20-2015, 01:00 PM
dannye's Avatar
I just saw there is a new software upgrade 1230. Does anyone know what it does?
dannye is offline
post #2173 of 2478 Old 04-20-2015, 03:04 PM
sikclown's Avatar
Liked: 691
I have had 1230 (US Firmware) for awhile on my set. No clue what it does, probably just bug fixes, but I haven't noticed any differences.
sikclown is offline
post #2174 of 2478 Old 04-21-2015, 01:35 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
I updated to European 1230.2 and can't see any problems.
Sent from my Nexus 6 using Tapatalk
post #2175 of 2478 Old 04-22-2015, 04:50 PM
ray0414's Avatar
Quoted: 9310 Post(s)
Liked: 7743
would it be possible for an F9000 owner that has the original OCB to post a picture of the software page on your tv please? settings: support-contact samsung, thanks!!
65KS9800 *new*. 65JS9500 4K HDR and lots of it!
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
Review of KS9800vsJS9500 w/side by side pix: http://www.avsforum.com/forum/166-lc...l#post45720113
ray0414 is online now
post #2176 of 2478 Old 04-30-2015, 08:07 PM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
So today my F9000 (w/ SEK 2500 OCB) decides that it will turn off by itself about 30 seconds after power up (it was also switching to HDMI4 from HDMI3). Anyone else have this issue? I'm out of warranty aside from BB Geek Squad protection plan (3rd party tech is coming out Monday). Tried a factory reset, was painful as the set up guide was interrupted by many automatic shut downs. Obviously it didn't take care of the issue.
If they replace the mainboard, how reliable is it? Wondering if I should look to the JS8500 now instead and retire the F9000 if they can't fix it. Although if they do fix it, not sure how long it'll last? Can't believe this TV didn't even make it more than 18 months.....
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #2177 of 2478 Old 04-30-2015, 08:20 PM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
It's caused by the software update Samsung just put out to all these TV's. Mine is broke too, same as yours. Samsung is supposedly working on a fix and hope to have it within 48 hours but how it will be updated remains a mystery because the TV won't stay on. Don't pay for service yet because there is no fix at this point.
atodzia is offline
post #2178 of 2478 Old 04-30-2015, 08:23 PM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
Warning - do not let Samsung update the software to the latest version. It will break your TV and cause it to power off after being on for 60 seconds. This is a USA software bug. Not sure about other countries. I have the F9000 TV with the SEK-2500U One Connect box.
atodzia is offline
post #2179 of 2478 Old 04-30-2015, 08:46 PM
sangnas's Avatar
Quoted: 17 Post(s)
did they tell you that a fix was comming out?
sangnas is offline
post #2180 of 2478 Old 04-30-2015, 08:58 PM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
They just responded a few minutes ago and told me my TV would have to be serviced in person to fix it. I can't believe it. All because of a software update they pushed out online to my TV.
atodzia is offline
post #2181 of 2478 Old 04-30-2015, 08:59 PM
ray0414's Avatar
Liked: 7743
i wonder if this could cause them to have to replace the tv??
post #2182 of 2478 Old 04-30-2015, 09:07 PM
atodzia's Avatar
Quoted: 150 Post(s)
Liked: 86
They just sent me another email saying they are paying for all parts and service for this fix. I have no idea what they have to do to fix this.
atodzia is offline
post #2183 of 2478 Old 05-01-2015, 01:49 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
What version number does this firmware have?
post #2184 of 2478 Old 05-01-2015, 03:50 AM
Quoted: 57 Post(s)
Out of warranty anyone? DO NOT pay for repair! Samsung is going to repair for free. Call them for arrangements
Bryscott is offline
post #2185 of 2478 Old 05-01-2015, 04:51 AM
Quoted: 83 Post(s)
Liked: 41
Odd though, there was no firmware update this week unless it was the one from a while ago. I'm not sure how it could be fixed other than service. I managed to do a reset, still was shutting off.
post #2186 of 2478 Old 05-01-2015, 08:06 AM
sikclown's Avatar
Liked: 691
Originally Posted by poisike View Post
what version number does this firmware have?
1240.2
poisike likes this.
sikclown is offline
post #2187 of 2478 Old 05-01-2015, 08:07 AM
sikclown's Avatar
Liked: 691
There was a firmware update yesterday that did it. My TV is screwed.
sikclown is offline
post #2188 of 2478 Old 05-01-2015, 08:20 AM
poisike's Avatar
Quoted: 325 Post(s)
Liked: 96
I'm glad they test on US people before releasing new firmware in EU ;-)
Unfortunately I'm afraid the same firmware will be released in Europe too, in a week or so... So everyone should disable automatic update.
post #2189 of 2478 Old 05-01-2015, 11:03 AM
sangnas's Avatar
Quoted: 17 Post(s)
Would anyone happen to have the firmware download link for the one prior to 1240.2
sangnas is offline
post #2190 of 2478 Old 05-01-2015, 11:59 AM
sikclown's Avatar
Liked: 691
I think it is up under the un65hu9000 but if your TV already updated to the current one then you are pretty much out of luck. No way to install the previous version over the newer version that I know of.
sikclown is offline
Reply LCD Flat Panel Displays
Samsung Un55f9000 55 Inch 4k Ultra Hd Led Hdtv , Samsung Un65f9000 65 Inch 4k Ultra Led Hdtv
