**Official** Samsung 4K UN55F9000, UN65F9000, and UN85S9 Thread - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 93Likes
post #2371 of 2388 Unread 12-01-2015, 05:44 AM
FeeFi's Avatar
Did you get 4k through the RVU as I think that is the only reason to use it.
FeeFi is offline
post #2372 of 2388 Unread 12-13-2015, 02:00 PM
Dratai's Avatar
On my htpc I can choose between the resolutions 3840x2160 and 4096x2160. Which is the correct resolution for the un65F9005? I've been using 3840 until now but then got to thinking, why not 4096 if it's the maximum?
Dratai is offline
post #2373 of 2388 Unread 12-27-2015, 03:08 PM
atodzia's Avatar
Quoted: 131 Post(s)
Liked: 85
4K 60hz - how to turn Auto Motion off?
It appears that Samsung is setting the Auto Motion default for 4k 60hz HDMI input to Auto Motion On set at Standard. Does anyone know how to turn Auto Motion off or to Custom with a 60HZ input?
Samsung UN65F9000, SEK-3500
Oppo BDP-105D
atodzia is offline
post #2374 of 2388 Unread 01-06-2016, 08:25 PM
Liked: 0
Samsung UN65F9000 Help
New member here. Been a lurker for years now. I get a lot of great info from the site. So I had the power cycle problem with my 1.5 year old UN65F9000 that I've read so much about. Luckily I got the Square Trade Warranty through Costco (89 bucks, I recommend). Square trade tried to diagnose it over the phone and ordered a slew of parts for a service tech to switch out. Changed out the main board first which fixed the issue for all of 4 hours. Came back a couple days later and changed out a bunch of cables and the power board. Still could not get it working. Tech said he would get with Square Trade and order new Power Board. He thinks the original power board is bad as well as the replacement. I called Square Trade and told them enough is enough, quit throwing parts at my tv. They agreed to give me a new UN65JU7100 to replace mine. Also letting me keep my TV. So now I'm going to attempt to either let the service tech fix my original UN65F9000 or order a power board, FRC Board, or main board myself. Just want to get some ideas as to what board to replace first. My TV will turn on without the one connect plugged in but the screen is blue. No logos or anything. Remote does nothing. When TV powers on the Power Board has 2 clicks. I heard a high buzzing noise coming from the FRC board as well. Maybe not getting enough volts from the power board? If I plug in the one connect box the tv shuts down. It sounds to me like a power board issue but wanted to see if we had experts here offer their advice or someone with same symptoms. Main board and power board have been replaced. Thinking of replacing the FRC board ($50) since it is making a high pitch noise and the heat sinks are not getting warm like the other boards. Thanks a lot for the help.
CDR15 is offline
post #2375 of 2388 Unread 01-07-2016, 12:25 PM
narkotic's Avatar
Any thoughts on the latest firmware release? I've disabled auto updating as the last one bricked my TV.
I have the 65" 9000 series with SEK-2500u.
Is there anywhere to see release notes?
narkotic is offline
post #2376 of 2388 Unread 01-07-2016, 12:25 PM
narkotic's Avatar
narkotic is offline
post #2377 of 2388 Unread 01-07-2016, 08:07 PM
Liked: 0
Ive owned a un65f9000 for just over 2 years and now when on 3d mode i get a bad flicker on the left side of the screen. Anyone else having this issue? Is there a fix? Any help would be appreciated. Ive been in contact with Samsung but nobody is getting back to me.
orenbuchler is offline
post #2378 of 2388 Unread 01-08-2016, 07:00 AM
Liked: 0
Where are you finding parts? From everything I've read online seems a lot of Samsung tvs have power supply issues.
post #2379 of 2388 Unread 01-11-2016, 01:05 AM
Rishikesh100's Avatar
Anybody has seen the new one connect box (OCB) for samsung 2016 UHD sets? What are the improvements samsung made to the new OCB in comparision to those of 2015, the SEK-3500U? Are they compatible with f9000 series 2013 model TVs?
Rishikesh100 is offline
post #2380 of 2388 Unread 01-11-2016, 02:19 AM
poisike's Avatar
Quoted: 277 Post(s)
Liked: 79
According to CES there will not be a evolution kit this year. And I find strange that Samsung didn't even mention OCB for the KS series. It looks like there are no more evolution kits in the future.
On the positive side, Samsung said that last years models will get the new features with firmware update...
Samsung UE65F9000ST + SEK-3500U/ZG (European firmware v1421.2)
Samsung UE78HU8500TX (European firmware v1290.2
poisike is offline
post #2381 of 2388 Unread 01-13-2016, 03:45 PM
Liked: 0
Well after talking to Samsung multiple times and relizing they are worthless. I ordered a new power supply board from eBay. Installed it and now 3D is working. I'm so happy. I'm not one to just let something like this go. Anyway I'll be posting a video on YouTube showing before and after with parts.
post #2382 of 2388 Unread 01-23-2016, 01:03 PM
jcwilkerson's Avatar
Hello Everyone! I have been a long time AVS Forum "reader". I haven't been able to contribute much but have benefited greatly from all the experienced members over the years. I am needing the help of some of the members of this forum. I acquired a UN55F9000 from a friend for very little but there was only the display, power cord and remote. I wasn't given the One Connect box. I was able to find a SEK-2500U at Best Buy last night that was an OPEN BOX item for only $171.00. I thought it was a great deal and was excited to purchase and hook up to the display, only to find that it didn't work properly. After turning on the display and hooking up the SEK-2500U I just get the screen showing the display and One Connect box with arrows indicating I should hook up the two devices. I have no idea if the firmware has been updated and I am going to try to update the firmware via USB here shortly. I just wanted to see if anyone had any ideas as to why I am getting that screen or as to why the supposed "working" SEK-2500U I got from BB might not be working. I can assume a few things here: the display is bad (or One Connect connection), the cable or box I got that was "open box" is not working, or that maybe the firmware just needs to be updated. If anyone has any tricks I can try or any insight I would be much appreciated.
jcwilkerson is offline
post #2383 of 2388 Unread 01-23-2016, 02:08 PM
poisike's Avatar
Quoted: 277 Post(s)
Liked: 79
Problem is that the sek-2500u has not been set up, so your F9000 does not recognize it.
You need to make a backup on the original OCB to install the sek-2500u. Of course You can't do this because you don't have the original OCB.
Another possibility is to find another F9000 with OCB and use it to make a backup, then connect your sek-2500u and set it up. After that, it should work with your TV.
I have tried my sek-2500u with HU9000 and it works, so it may be possible to get it working if you can connect it to HU9000 and set it up.
It maybe also possible to set it up manually in extended service menu, but I'm not sure if you even can get there if its not set up.
poisike is offline
post #2384 of 2388 Unread 01-23-2016, 03:52 PM
Poisike, thank you for the information. I will research how to attempt getting into service mode to see if it's an option. Thanks again.
post #2385 of 2388 Unread 01-26-2016, 08:25 AM
upstate-avfan-da's Avatar
Quoted: 39 Post(s)
Liked: 26
What an ordeal.... I opened a service claim with BB on 11/5, the right side of my panel was not getting to the correct brightness in certain dark scenes so my tv looked like hell. Two LCD panel replacements and a FRC (or something like that) board the problem is fixed - it was the new board that fixed it. The board was the one in the middle of the the boards inside.
So after all this, my original panel would have been ok to keep, but the first and second replacements both have their issues, latest being clouding and a darkish dot. My service contractor needs to come back out then report as non repairable, then it will go to the replacement process.
What are the equivalent models for the UN55F9000 so I can make sure they are not downgrading me?
Feel bad for the tech since this job could've been much easier, new board and done. But they made him order a new panel to fix on the first go around.
upstate-avfan-da is offline
post #2386 of 2388 Unread 02-01-2016, 06:14 PM
CXENTE's Avatar
Quoted: 42 Post(s)
Liked: 30
My tv went black screen! It turns on but nothing is displayed? And even when I put back the original OneConnect box, nothing shows? And my tv is out warrenty 😒
CXENTE is online now
post #2387 of 2388 Unread 02-02-2016, 11:44 AM
lukianp's Avatar
Originally Posted by lukianp View Post
signing in from the uk here.
Firmware bricked my uef9000... It was my main computer monitor now have to use the gf's mac.. Sigh
Starting the process tomorrow as customer service is not available on sunday. Its out of warranty but they will fix or replace this for free!
So... here we go again....
www . youtube . com watch?v= En37grCtIjg
The update looks like its bricked the one connect box.. when will they learn!
lukianp is offline
post #2388 of 2388 Unread Today, 04:59 PM
CXENTE's Avatar
Quoted: 42 Post(s)
Liked: 30
HMM,.. Could this be what happened to mine?
Reply LCD Flat Panel Displays
Samsung Un55f9000 55 Inch 4k Ultra Hd Led Hdtv , Samsung Un65f9000 65 Inch 4k Ultra Led Hdtv
