Samsung UN65FH6001FXZA?? I can't find anything! - Page 17 - AVS Forum | Home Theater Discussions And Reviews
post #481 of 491 Old 04-30-2014, 12:44 PM
raydawg2000's Avatar
Originally Posted by Bond 007 View Post
I have noticed it from time to time as well. I think its just a fault of the tv. You may be able to minimize it with settings but I doubt it will ever stop completely.
Yea, i had a feeling i would just have to deal with some of it but if i can at least reduce it that would be acceptable.  I just don't know what settings I should mess around with.  any ideas?
raydawg2000 is offline
post #482 of 491 Old 04-30-2014, 12:48 PM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
I calibrated mine with the Disney WOW disc and my settings are similar to many here. Someones in particular was very close but I cant remember who now.
Licence to Kill
Bond 007 is offline
post #483 of 491 Old 07-30-2014, 05:36 AM
cberasi's Avatar
Curiousity question.
I just moved; unplugged everything hooked up to my UN656001FXZA, moved it to the new location, and plugged it all back in (it was unplugged for maybe a day). For some reason the picture/calibration settings must have reset b/c they changed. I am not sure if they are back at the factory settings it started with b/c I don't remember those, I just know they weren't at what I had changed them to and had been using for the last 6 months before this move (luckily I saved these in an excel spreadsheet so I could switch them back easily after this).
I am mainly curious why this happened; no one was around to change them but me so it wasn't done manually. Does anyone know, does unplugging the power cord from the back of this unit for an extended amount of time reset the picture settings? I am using the same HDMI inputs, don't know what else it may have been.
cberasi is offline
post #484 of 491 Old 12-16-2014, 01:26 PM
j86
Liked: 0
Hey all new poster here but I've been reading around here for a while. I'm still kind of a newbie to this so please excuse my ignorance and probably poor description of my issue here.
I bought this TV last year like many did but I never really used It since I was single,and it was in my living room. But the other night I watched my first movie on it. Sinister with Ethan Hawke. If you have seen this movie you know about half of the scenes are at night and it's pretty dark. I noticed I'm getting a lot of blocky patches in the dark scenes where it almost looks like the tv can't decide how dark it wants that part of the screen to be. I scanned around some of the many pages of this thread and even put in some of the calibration settings and set the black to darkest. But none of this has helped fix the issue. What is the proper term for the issue I'm experiencing and has anyone else had this issue? Was it fixable? Thanks in advance
j86 is offline
post #485 of 491 Old 12-16-2014, 01:43 PM
thebignewt's Avatar
Quoted: 325 Post(s)
Liked: 92
I think what you describe is "crushed blacks". I don't remember what you do to fix it, but if copying some settings that others with your TV have used you could go to a "calibration" forum and ask how to fix that.
[/B] LG OLED65E6P TV, Yamaha AVR with Paradigm speakers, Cableone STB, Samsung BD player, Apple TV3.[/B]
thebignewt is offline
post #486 of 491 Old 12-16-2014, 02:12 PM
j86
Liked: 0
Thanks newt. I'll do some searching around for that term and look further into calibration. I just got the Disney WOW blu ray that I plan on playing around with too. Idk how much it will help but certainly worth a shot.
j86 is offline
post #487 of 491 Old 12-16-2014, 02:20 PM
thebignewt's Avatar
Quoted: 325 Post(s)
Liked: 92
I think that Disney WOW disc is a good thing for 10 point "greyscale" calibration which could help with blacks. That's the one with 10, 20, 30, 40 etc. It's not adjustable in all picture settings, but it is in Movie on all sets and Standard on mine.
post #488 of 491 Old 12-16-2014, 03:28 PM
Bond 007's Avatar
Liked: 2090
Not all sets. The 6001 has no grayscale adjustment in any mode.
Bond 007 is offline
post #489 of 491 Old 07-03-2015, 10:42 AM
Liked: 0
updated firmware now permanent soap opera effect
i updated the firmware on the un65fh6001 to 1004.0 as listed on Samsung's website. it removed the auto-motion setting leaving the TV in a permanent soap opera mode. Additionally the back-light adjustment doesn't work now. Subsequently i had to change the main-board. I was really looking forward to the update removing the hideous banding this TV displays but it just made things worse. Anyone else having similar issues with the update?
TCGS123 is offline
post #490 of 491 Old 07-04-2015, 10:33 PM
SideEffect34's Avatar
Oh yikes. Wasn't aware of an update. Are you able to remove the update and go back to default settings with auto-motion?
Samsung UN65FH6001FXZA 65" 1080p LED
Polk Audio TSi300, CSi A4, PSW 125, OWM3
Sony PS3, PS4
SideEffect34 is offline
post #491 of 491 Old 07-06-2015, 02:04 PM
Liked: 0
can't go back
No, there is no way to reverse the update once its done except by replacing the main-board. The TV doesn't work like a computer in this respect. i checked for updates frequently because i was hoping for a fix for the banding and the firmware update for the un65fh6001 has only been there for a couple of months. however according to the website it was created March 2013 which makes no sense. i'm not even sure the TV was available back then.
TCGS123 is offline
Reply LCD Flat Panel Displays
Samsung Series 65 Inch Class Led Hdtv Un65eh6000
