LG Tv Power Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-27-2013, 04:26 PM - Thread Starter
Justin5344's Avatar
Hi, I'm having problems with my LG LCD TV's power. I turned it off and went away for about 5-10 minutes and came back later. There was still power in the tv because the light was red. I pressed power and the red light went away but the blue light that's supposed to replace it never came. I tried putting the plug in a different outlet and that doesn't work either. I checked the plug and it is plugged in correctly. I even tried a different plug from a working tv and that didn't help either. Please Help.
Justin5344 is offline
post #2 of 2 Old 11-29-2013, 08:29 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
See my post here
http://www.avsforum.com/t/1491809/most-common-lcd-led-plasma-tv-repair
Just fixed a $500.00 LCD PC monitor $6.00 worth of capacitors . same symptom .
tubetwister is offline
Reply LCD Flat Panel Displays
