Samsung LN52A650 - where is the game mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-09-2013, 07:16 PM - Thread Starter
amb1s1's Avatar
I'm having lag problem with this TV and I did some search and everybody say that game mode cut the lag, but I don't see it on the settings. Is this a setting that It can only be access using the controller? I hope no because it don't have the controller for this TV.
amb1s1 is offline
post #2 of 3 Old 12-09-2013, 10:08 PM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4953 Post(s)
Liked: 8378
On your TV, Game is an input source.
Mark Henninger
imagic is online now
post #3 of 3 Old 12-09-2013, 10:19 PM
wtfer's Avatar
Quoted: 147 Post(s)
Liked: 40
Game mode has terrible locked picture settings & the lag isn't the best possible it can get on the set.
Plug in the HDMI cable to the HDMI slot 2 in the TV & rename that input to 'PC'. That will give you the lowest amount of lag.
That or use a VGA cable, that has similar PC settings that automatically lower input lag & doesn't mess with the picture settings.
wtfer is offline
Reply LCD Flat Panel Displays
Samsung 52 Inch 650a Lcd Hdtv
