Sony's "local dimming" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-10-2013, 05:32 AM - Thread Starter
*UFO*'s Avatar
Quoted: 463 Post(s)
Liked: 360
Does anyone know how the local dimming works in sets like the w900a? They are edge lit sets but behave exactly like FALD sets. For example, if your have white letters in a black back ground, only the white letters will be illuminated. It will even have the blooming artifact of FALD sets. How are they achieving this effect using edge led's?
*UFO* is offline
post #2 of 2 Old 12-10-2013, 07:59 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4911 Post(s)
Liked: 8315
That's not the full story. It is impossible to imitate FALD with edgelit local dimming, which is more like pseudo-local dimming. The maoin difference is that in addition to blooming, edgelit sets also produce an artifact called flashlighting. The TV can still shut off a number of LEDs, which darkens the screen—however, if we use your example of white text, with edglit you'll also see faint shafts of light going from the text right to the edge of the screen.
Mark Henninger
imagic is offline
Reply LCD Flat Panel Displays
Sony Kdl 55w900a 55 Inch Led Hdtv
