Is this a bad bleed? - AVS Forum | Home Theater Discussions And Reviews
Old 12-19-2013, 11:35 PM - Thread Starter
RustPuppet's Avatar
Hello, new member from South Africa here :)
So I've just bought a Samsung UA55F7500, and I've immediately picked up some noticeable spotlighting. I've trawled through threads here for a fix, but no amount of calibration or fiddling seems to completely remove it.
Would you guys consider this bad enough to warrant a return for a new unit? (Not the best picture from my iPhone in a darkened room, but the uneven lighting is still quite clear in the shot.)
Any help would be greatly appreciated.
RustPuppet is offline
Old 12-20-2013, 07:47 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4943 Post(s)
Liked: 8366
That's a pretty normal amount of flashlight effect for an edge-lit LCD. If you are coming from a plasma, that's what the problem actually is.
I took this shot when I was visiting CNET's TV testing facility, comparing screen uniformity on LED-lit LCD vs. plasma.
Mark Henninger
imagic is online now
Old 12-21-2013, 04:12 AM - Thread Starter
RustPuppet's Avatar
Thanks for the info, imagic. I've upgraded from an older Samsung LCD which had almost zero flashlighting, so I was surprised by how noticeable it is on the newer (and far more expensive) panel.
I'm going to fiddle with the calibration a bit more before I make a call to return it or not.
Samsung Un55f7500 55 Inch 3d Ultra Slim Smart Led Hdtv
