New LG TV and Harmony remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-29-2013, 04:24 PM - Thread Starter
cadmanmeg's Avatar
Anyone know why my Harmony One and the software doesn't pick up or have the newer LG TV's able to add automatically to the remote functions? I have a LG 60LN5600 and it says it cannot find a similar device. Is there something special I have to do? With all the functionality on the remote for the TV, would rather not add all manually to the Logitech. Ideas please? Thanks much.
cadmanmeg is offline
post #2 of 6 Old 12-29-2013, 04:32 PM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
Have you called Logitech? Maybe they haven't added it to the database yet. I have an old Harmony 880 that works fine with my LG (even tho it's not brand new like yours).
Otto Pylot is online now
post #3 of 6 Old 01-03-2014, 02:55 AM - Thread Starter
cadmanmeg's Avatar
I haven't called them. Was hoping with all the folks on here, someone may know something. Can anyone add anything further? Would be much appreciated.
post #4 of 6 Old 01-03-2014, 06:49 AM
John4721's Avatar
Could try adding another, older LG TV to the remote as a temporary measure. Ideally one with a mostly similar feature set. The LG remotes I've used are -mostly- compatible with each other, so it might just get you up and running.
John4721 is offline
post #5 of 6 Old 01-03-2014, 07:36 AM
Rudy1's Avatar
Quoted: 966 Post(s)
Liked: 1280
I agree with John 4721...the easiest way to do it would be to find a TV that is similar to yours but from a previous year on the LG website (make sure it's the one specific to your country), and program the remote using those settings. You can always add functionality by using the remote's learning settings in the Harmony software.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is online now
post #6 of 6 Old 01-03-2014, 09:30 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi cadmanmeg, I was able to add 60LN5600 to my Harmony One.
JChin is offline
Reply LCD Flat Panel Displays
