Need Recommendations! Samsung UN46EH5000 or Vizio M551D-A2R? - AVS Forum
post #1 of 2 Old 01-03-2014, 02:45 PM - Thread Starter
Dizzle1082's Avatar
(Wow, I haven't posted at AVS Forums in YEARS!) Anyways...
Hey everybody....I was wondering if some of you could impart your wisdom in helping me make a decision between buying the Samsung UN46EH5000 (~$550) or the Vizio M551D-A2R (~$1000) Which one do you guys find to have the overall better picture quality for both blu-ray playback and gaming? Seating distance from couch to tv position is 8.5 - 9 feet. I'm leaning toward the Vizio, because of the larger picture size and SmartTV capabilities, but overall, I want a tv with the best picture quality, cost isn't an issue. Any help is appreciated! Thanks!
Dizzle1082 is offline
post #2 of 2 Old 01-03-2014, 03:00 PM
hdnewbie21's Avatar
Liked: 38
46' to 55" is a big gap for a fair comparison between these 2. At your viewing distance, I'd say 50" is around the right size, however some may prefer going smaller, some may prefer bigger.
The M551D-A2R has great value, but with cost not an issue, I would go with higher end Sony or Samsung. They tend to do better with black levels and uniformity which I'd say is the biggest problem with LED's LCDs.
Yamaha RX-V673 | HSU HC-1 MK2 | HSU HB-1 MK2 - LR | Pioneer SP-BS22-SLR | BIC RtR-V44-2 (Presence)
hdnewbie21 is offline
Reply LCD Flat Panel Displays
Samsung Un46eh5000 Led Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv
Gear in this thread - Un46eh5000 by PriceGrabber.com
