Vizio P Series UHDTVs at CES 2014 - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 109Likes
post #511 of 918 Old 08-21-2014, 12:17 PM
Brewtus37's Avatar
Originally Posted by Ph8te View Post
4k,
more LDZ
Better Processing (24/48P)
HDCP 2.2
HDMI 2.0
better design (personal opinion I prefer the gunmetal grey)
HEVC H.265
"V6" 6 Core processor
Basically it should be a step up in almost every way. More so than the E to the M....No one knows how much difference to expect as there has been no production comparisons. Asking that type of question is like asking how will the 2015 compare to the 2014 sets If money is a main concern go with the M series, if not the P...
Fair enough. Thanks. Appreciate the input.
Brewtus37 is offline
post #512 of 918 Old 08-21-2014, 12:45 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2612
4k,
more LDZ
HDCP 2.2
HDMI 2.0
HEVC H.265
Ph8te has this pretty much spot-on. The P has a 960 action rate versus the 720 action rate of the M, so it should have better motion handling which may be the result of a brighter backlight.
In general, 4K on a 55" screen is somewhat of a waste unless you will be sitting very close to the screen, but the additional dimming zones and higher action rate should result in improved picture quality for some content.
The 55" M is now $850 and the 55" P has an MSRP of $1400, so the price difference is $550 or 65%. The 60" M is $1200 and the 65" M is $1500, so if you have space for a larger screen but are on a budget of under $1500, those might be other options to also consider...
Ph8te likes this.
fafrd is online now
post #513 of 918 Old 08-21-2014, 12:54 PM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3975
Originally Posted by fafrd View Post
Ph8te has this pretty much spot-on. The P has a 1200 action rate versus the 720 action rate of the M, so it should have better motion handling which may be the result of a brighter backlight.
R series has 1200, P series I believe is 960.
Sent from my Flip Phone using DOS
Ph8te is online now
post #514 of 918 Old 08-21-2014, 12:57 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2612
That's what I was thinking but not what my fingers typed - thanks for the catch - I fixed the original post.
Ph8te likes this.
fafrd is online now
post #515 of 918 Old 08-21-2014, 01:10 PM
CSonntag's Avatar
Quoted: 186 Post(s)
Liked: 65
I understand the R series will also have a 10-bit panel....
Take responsibility for your own actions...society is not here to look after you...
In other words, if you order coffee, expect it to be hot for christsake!
CSonntag is offline
post #516 of 918 Old 08-21-2014, 05:27 PM
Quoted: 833 Post(s)
Liked: 174
Originally Posted by sytech View Post
Dolby Vision blu-rays would need to be remastered with Dolby Vision WCG data. I think Sony and Toshiba use XY color data of current 1080p blurays to extrapolate a wider color gamut. I would guess since the Vizio can do DV it would be capable of WCG extrapolation as well.
Here is a Google translation of the Toshiba WCG restoration feature.
"By restoring a wide gamut restore database 6144 item using a color coordinate of the 64 axes consideration (limit of the material color) optimal color colors compressed to the gamut of the digital broadcasting, to the maximum color gamut of panel has expanded. In addition, I can now color reproduction vivid more natural, also corresponds to (ITU-R BT.2020) wide color gamut video input anew."
TY, so basically in Layman's terms it can process colors to make them look a little better than on a non HDR-ish tv? Just not quite as expanded color range as Dolby vision discs?
Aras_Volodka is offline
post #517 of 918 Old 08-21-2014, 05:36 PM
Rf13's Avatar
Quoted: 445 Post(s)
Liked: 247
this photo is a good example of hdr it adds back the colors and details that are usually lost. if a set has a better range of colors it can display things like fire etc. more realistically as if you were there in person.
https://www.flickr.com/photos/nathan...go/8437065062/
Rf13 is offline
post #518 of 918 Old 08-21-2014, 07:29 PM
Quoted: 833 Post(s)
Liked: 174
Thanks, I'm aware My question was regarding how the R series can handle ungraded (non-HDR) content. It appears as if it can assist with expanding the colors and contrast somewhat? Just not to such a great extent as graded content? My apologies for the derail again.
post #519 of 918 Old 08-21-2014, 07:31 PM
Quoted: 833 Post(s)
Liked: 174
Or (possibly my bad?) was the flickr comparison a precise example of the question?
post #520 of 918 Old 08-21-2014, 07:42 PM
Rf13's Avatar
Quoted: 445 Post(s)
Liked: 247
im not entirely sure from the website it would seem that it can do so, but from what i heard from the vizio cto interview it has to be remastered and will be available via streaming initially. heres the interview he mentions HDR around the 2:50 mark.
Rf13 is offline
post #521 of 918 Old 08-21-2014, 08:27 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2612
60" P now visible at Amazon (in addition to the 55" and the 70" which can be ordered): http://www.amazon.com/VIZIO-P552ui-B...ywords=Vizio+P
fafrd is online now
post #522 of 918 Old 08-21-2014, 09:07 PM
rwheelwright's Avatar
Quoted: 99 Post(s)
Liked: 33
I thought the 55 was supposed to sub 1000?
rwheelwright is offline
post #523 of 918 Old 08-21-2014, 09:17 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2612
50" is sub-$1000: http://www.vizio.com/news/vizio-anno...y-led-smart-tv
fafrd is online now
post #524 of 918 Old 08-22-2014, 06:15 AM
Quoted: 99 Post(s)
Liked: 33
Ahh, don't know how I messed that up. I thought the smallest size was 55". Man, I'm all confused! Hey, 50" is better because 55" would have really been to big for the bedroom. I'll take 50. Any ideas when the 50 comes out?
post #525 of 918 Old 08-22-2014, 07:37 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
I'll probably pick up a 50" P for testing and to replace an LG which calibrates poorly. It'll be in the Sun Room and will mostly be viewed under fairly bright conditions. The assumption is that the P will have similar calibration abilities as the M with 2 point Grayscale, 11 point Grayscale, and a full Color Management System for both the primary and secondary colors. My son has pre ordered a 70" P so I'll have something to compare it with, especially how well the local dimming works in the two sizes.
Ph8te likes this.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #526 of 918 Old 08-22-2014, 12:44 PM
Dr.Shankenstein's Avatar
Quoted: 234 Post(s)
Liked: 142
So far the 50" that has not been seen for pre-order. Most of the remaining sizes have appeared and are expected for delivery Sept./Oct.
Dr.Shankenstein is online now
post #527 of 918 Old 08-22-2014, 02:07 PM
Xevious's Avatar
Quoted: 40 Post(s)
Liked: 44
Been waiting for this one for a while mainly do to the 60hz 4k and 120hz @ 1080p which I really couldn't give up. I ordered the 70 inch from amazon. Can't wait!
Xevious is offline
post #528 of 918 Old 08-22-2014, 02:23 PM
solo88's Avatar
how many zones?
Is the 70 inch the only P series with 72 dimming zones?
According to the Amazon listings, the 55" and 60" have 64, but I'm wondering about the unlisted 65".
My midis bring all the Force to the yard; my midis are better than yours!
solo88 is offline
post #529 of 918 Old 08-22-2014, 02:37 PM
Rf13's Avatar
Quoted: 445 Post(s)
Liked: 247
The m65(32 zones) has slightly less zones than the m70(36 zones), but honestly it's anyone's guess what they will be until it appears.
solo88 likes this.
Rf13 is offline
post #530 of 918 Old 08-22-2014, 02:46 PM
Ph8te's Avatar
Liked: 3975
It's the same amount as the 55 and 60 (64
Zones)
Ph8te is online now
post #531 of 918 Old 08-22-2014, 04:41 PM
Quoted: 37 Post(s)
Liked: 8
Zones)
The Vizio website says the P-Series has "Up to 72 Zones", so I'd imagine the largest panel will have the most zones? If any of them have it, I'd expect the 70 to have 72.
No?
AhhYes is offline
post #532 of 918 Old 08-22-2014, 05:01 PM
Rf13's Avatar
Quoted: 445 Post(s)
Liked: 247
No?
what hes more than likely saying is that the 65" probaly has the same amount of zones as the 55 and 60
Rf13 is offline
post #533 of 918 Old 08-22-2014, 05:15 PM
Ph8te's Avatar
Liked: 3975
No?
That is correct 70=72, 65, 60, 55 and most likely 50 will be 64. Think double the previous model (m doubles E, p doubles m)
Rf13 likes this.
Ph8te is online now
post #534 of 918 Old 08-25-2014, 01:29 PM
Ph8te's Avatar
Liked: 3975
Ph8te is online now
post #535 of 918 Old 08-25-2014, 01:58 PM
aguptaweb's Avatar
Great find!
Great find, ph8te! I took a quick look through it and it looks like the only differences are in the connections diagram. (Not sure if we were expecting anything different, especially just for the quick start guide!)
aguptaweb is offline
post #536 of 918 Old 08-25-2014, 03:53 PM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
That video with the dual view of the program on the left and the local dimming in action on the right was interesting.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #537 of 918 Old 08-25-2014, 06:16 PM
darealist's Avatar
Quoted: 87 Post(s)
Liked: 29
Vizio still doesn't have integrated screen mirroring? Would be cool to pair it with fast 802.11 AC.
darealist is offline
post #538 of 918 Old 08-25-2014, 11:43 PM
Mikef5's Avatar
Quoted: 24 Post(s)
4k/30Hz, I hope this isn't true. If you look at the 70", on the Vizio site, the picture of the hdmi's says that's what it is.
Mikef5 is offline
post #539 of 918 Old 08-26-2014, 12:16 AM
Keenan's Avatar
Quoted: 2205 Post(s)
Liked: 1981
Thanks, I've seen that interview My question was regarding current standard (non-graded) blurays... like if you watch a regular 1080 p bluray on the vizeo reference series, will it look the same as if you watched it on a current 4k TV?
It should have one 4K@60Hz input, HDMI 5
Click the below link and then click again on the image.
http://ecx.images-amazon.com/images/I/A1QnnPvpakL.jpg
Ph8te likes this.
Keenan is online now
post #540 of 918 Old 08-26-2014, 11:05 AM
Ronzo3's Avatar
Quoted: 72 Post(s)
Liked: 77
Good find!
As the saying goes, "You can't fight Ph8te."
dancinbear likes this.
Ronzo3 is offline
Reply LCD Flat Panel Displays
Ces 2014
