Official 2014 Vizio Exxx-Bx Series owners thread - Page 118 - AVS | Home Theater Discussions And Reviews
post #3511 of 3520 Old 04-21-2015, 01:53 PM
sdilley14's Avatar
Vizio e600i-b3 60"
For what it's worth, I owned this TV for 2 weeks and decided to return it and picked up the Samsung UN60H6350. MUCH happier with this set.
The picture quality on the Vizio was great, but the set had some issues - mainly it would randomly shut off on it's own. I called Vizio tech support and they didn't have much to offer - just tried a hard reset, that was about it.
There was also an issue with a blotchy spot about 2"x2" burnt into the bottom left hand part of the screen.
And as others have mentioned, the Smart features on the TV were pretty weak - slow, prone to crashes.
The menus and overall user interface on this TV seemed kinda...weak. Don't know how else to describe it
I also wasn't a fan of the fact that you had to point the remote directly at the sensor on the bottom left part of the screen for the remote to actually work. Very little range/obstruction tolerance.
The picture quality on the Samsung seems very comparable. And it blows the Vizio out of the water in terms of hardware build quality, Smart features, on screen user interface...pretty much everything. But obviously that is to be expected with the price difference.
sdilley14 is offline
post #3512 of 3520 Old 04-24-2015, 04:46 AM
ChrisMc73's Avatar
Quoted: 89 Post(s)
So Woot has the VIZIO E700i-B3 70" for $1079.99 right now and I'm considering it. I need a big TV for the living room. I just got a 50" 4k Vizio refurb and love it. The reviews on this E series are scaring me however. Is anyone happy with the VIZIO E700i-B3?
ChrisMc73 is offline
post #3513 of 3520 Old 04-24-2015, 11:32 AM
Liked: 1
I love it. All of my issues, and imo a pretty good percentage of the issues in this thread, relate to the last update prior to this most recent one Vizio released. I have no complaints after the latest update. No regrets.
rusty_shackleford is offline
post #3514 of 3520 Old 04-24-2015, 11:35 AM
ChrisMc73's Avatar
Quoted: 89 Post(s)
I missed out on the 70", it sold out quick. I could use a smaller one for my kids TV to play games on, but was hoping to get that big one! RATS!
post #3515 of 3520 Old 04-25-2015, 12:52 AM
MAC 851's Avatar
I have the E420i-B0 and am still trying to figure out if it's better to have the active led zones on or off. I know that many have said to turn them off however most of them were different sets. If I decide to turn them off would I need to change any other settings like increase my contrast. I ask because right now I'm using Cnet's settings and seen where Rtings's settings had a higher contrast with the ALZ off. I would use my WOW disc to check contrast however I seem to have misplaced it.
MAC 851 is online now
post #3516 of 3520 Old 04-25-2015, 01:30 PM
hikouka's Avatar
question, have an old laptop hooked up with hdmi for windows media center, display is set to 1920/1080 but it doesn't seem to fill the screen, is there a setting or something i'm missing? the computer recognizes the display as its proper model number in the display settings
Hey, I'm a firm believer in the philosophy of a ruling class
Especially since I rule.
hikouka is online now
post #3517 of 3520 Old Yesterday, 04:42 PM
Liked: 4
i have an e420i-b0 as well, & i think PQ is a little better overall w/ active LED switched off. when it's on there's definitely more depth and detail to some scenes, but in dim/dark scenes, or when the picture goes quickly from dim to bright, or vice versa, the TV displays a weird 'bloom' effect as the LED zones are visibly dimming/brightening to keep up. that problem, which arguably all local dimming TVs have to some extent, is probably compounded by the fact that the e420i-b0 has so few local dimming zones--just six (i think three in a left column & three in a right column).
another big deciding factor for me (which may/may not be an issue for you) is that local dimming on my set makes input lag markedly worse. so games at 60fps (call of duties, mario kart 8) are essentially unplayable when it's on.
so i keep LED off and bump contrast a little (though never as high as rtings says--77, right?). but also, it's your TV and so ultimately it's your choice as to how it should be calibrated.
(if you don't find WOW you can use AVS 709, which is here--
AVS HD 709 - Blu-ray & MP4 Calibration
--and which, if you can't burn it to a blu-ray or something, you can play on yr TV using the mp4 files & a thumb drive.)
famousguacamole is offline
post #3518 of 3520 Old Today, 09:50 AM
MAC 851's Avatar
Thanks for the advice. Could you share your settings as a starting point. I like to look at different settings when I calibrate so I can see if I'm in the same ballpark. Right now all I can find is Cnet and Rtings and one has led zones on and the other has a pretty high contrast.
post #3519 of 3520 Unread Today, 06:06 PM
Liked: 4
sure thing. though some of my settings are almost certainly different from what you'd want.
i used the 'calibrated' mode as a starting point.
first of all, on the 'advanced setting page,' i have:
- color temp - normal
- all of the fancy side-of-the-box-bullet-point settings (from 'black detail' down to 'reduce block noise') - off
- film mode - auto
& in the basic picture settings:
auto brightness - off
backlight - 100
brightness - 50
contrast - 60
color - 50
hue - 0
sharpness - 0
the backlight on my set is WAY high. it's because i have my TV next to a window. set yours depending on the lighting in yr home theater. i think 37 is right for a dark room. you might turn it up (50? 60?) if you're in a medium-bright room, etc.
the contrast is low-ish maybe. but much higher & on my set, details in brighter parts of the picture disappear. do yr own thing w/ it.
& in the 'professional settings' menu, i changed nothing. i don't have a colorimeter & when i tried anybody else's color tuning settings (rtings has some, i think), the picture seemed the same or worse.
keep in mind that, as a general rule, the factory default color tuning is probably better than tuner settings from somebody online.
(there is one nifty thing about the vizio 'color tuner' page, which is, by clicking on 'RED' or 'GREEN' or 'BLUE' at the top you can apply R G or B color filters to the whole screen. which, if you find that WOW disc & want to fine-tune color, will come in handy.)
post #3520 of 3520 Unread Today, 08:24 PM
MAC 851's Avatar
- film mode - auto
backlight - 100
brightness - 50
contrast - 60
color - 50
hue - 0
sharpness - 0
Thanks. After I turned off led zones I turned my contrast to 60 and had backlight at 50 in a dark room so we weren't that far off. I used C-Net's color tuner settings since many say the gamma wasn't right and C-Net's fixed it. I might reset the TV and just use the default settings. I plan on looking for the disk tomorrow. Thanks for the help.
Reply LCD Flat Panel Displays
vizio e 600-b3 , Vizio E Series E401i A2 40 Inch 1080p 120hz Led Lit Internet Hdtv , vizio m series m602i-b3
Gear in this thread - E401i by PriceGrabber.com
