Official 2014 Vizio Exxx-Bx Series owners thread - Page 119 - AVS | Home Theater Discussions And Reviews
post #3541 of 3557 Old 06-15-2015, 02:58 PM
Liked: 2
Originally Posted by MAC 851 View Post
I think you might be on to something here. I had mine on auto as well and turning it off really seems to make the picture look a lot better. I noticed that the picture looked too warm when I watched BD's compared to my satellite and now it looks great. Thanks for the tip.
No problem man. I have a few more days with it now and turning that setting from "auto" to "off" definitely fixed my issues with the TV. It now looks just as good as my old Toshiba and I am very thrilled with the picture quality. Can't believe that is what was driving me nuts for 3 months!
Wonder why my BDP would automatically use a higher setting if the TV couldn't handle it? Oh well.
StingingVelvet is online now
post #3542 of 3557 Old 06-15-2015, 06:36 PM
MAC 851's Avatar
I can't believe the difference it has made.The main reason I wanted gamma settings is because the picture even with C-net's 11 point gray scale still seemed too warm and washed out but now the image looks great and I can see why C-net scored it as high as they did. Every BDP I have is Sony and I always leave settings that have auto on auto. I'm now a little curious if I need to change my YCbCr/RGB settings from auto to YCbCr (4:2:2).
MAC 851 is offline
post #3543 of 3557 Old 06-16-2015, 05:43 PM
Justinss's Avatar
My E500i-B1 with firmware v1.60.10-018.0000 keeps "Searching for available updates" constantly for about an hour now. Why and how can I get it to stop?
Justinss is offline
post #3544 of 3557 Old 06-16-2015, 07:21 PM
Liked: 0
I'm getting the same message
Steponme is offline
post #3545 of 3557 Old 06-16-2015, 07:49 PM
toografik4u's Avatar
Same here. Just unplugged the ethernet cable. Never use the smart features anyway
toografik4u is offline
post #3546 of 3557 Old 06-16-2015, 08:10 PM
cuzed2's Avatar
Quoted: 49 Post(s)
Liked: 88
I am also getting the " trying to update " message on our 55" E series. Had to unplug the Ethernet cable, and do a power off reset to make the searching message go away ?????
cuzed2 is online now
post #3547 of 3557 Old 06-16-2015, 08:18 PM
gatorred's Avatar
Happened to me tonight as well. Turn off the smart interactivity features, I kept my ethernet cable connected and turned the smart features off in the reset and admin menu and the searching stopped. The internet still works when you press the V button.
gatorred is offline
post #3548 of 3557 Old 06-16-2015, 10:03 PM
olyteddy's Avatar
Quoted: 364 Post(s)
Liked: 517
Yeah, I had to disconnect the network too to get rid of that Yahoo! update thing. Oh well, I have an HTPC connected so no need for the apps...
olyteddy is online now
post #3549 of 3557 Old 06-16-2015, 11:35 PM
jaymerkramer's Avatar
Found this on the M series forum and it worked for me at least until you turn your tv off and back on again. According to Vizio the issue is with Yahoo. I'm just leaving my network settings disabled on the TV until then.
" Vizio Facebook said:
We are experiencing an issue with our TV?s continually attempting to update the Yahoo bar. Please follow the steps to resolve this issue. 1. Go to WPS in the network Menu. 2. When it attempts to connect press cancel 3. Go back into your network and reconnect to your network This should resolve your issue."
jaymerkramer is offline
post #3550 of 3557 Old 06-17-2015, 07:31 AM
Liked: 2
Yeah my Sony is using 4:4:4 as well, when set to auto. The picture looks great now though so I'm not going to mess with it
post #3551 of 3557 Old 06-17-2015, 10:47 AM
Liked: 0
Continous Update issue
I have an E700i-B3 and had the same issue last night...I couldn't even get the menu to stay open long enough to try and disconnect the wifi. I ended up having to do a factory reset which seems to have solved the issue...I wish the update process could be manual, at least then we wouldn't have surprise issues like this.
Rainuck is offline
post #3552 of 3557 Old 06-17-2015, 05:21 PM
Basstrix's Avatar
Quoted: 47 Post(s)
Liked: 26
My 65" started doing this same thing this morning. I turned it off and not sure if it was done or not, but haven't had a chance to turn it back on again. One message showed it had located 24 updates to the included apps. I supposed it could take a significant amount of time to d/l all of them.
Vizio M652i-B2....................HCFR 3.3.1
Vizio E600i-B3.....................i1 Display Pro
Sharp LC-70C8470U............ControlCAL Elite X5 Edition v2
Onkyo TX-SR606.................AVSHD-709
PS-3
Homegrown HTPC
Basstrix is offline
post #3553 of 3557 Old 06-20-2015, 07:25 AM
MAC 851's Avatar
I just received the 1.60 update on my E42i-B0. Nice to finally have gamma settings. I was wondering if I should disregard my 11 point settings now that I am able to set gamma or leave them as they are.
MAC 851 is offline
post #3554 of 3557 Old 06-24-2015, 06:43 AM
Basstrix's Avatar
Quoted: 47 Post(s)
Liked: 26
Tuesday morning I turned on my set to find I'd received the 1.60 update. This is for the E600i-B3.
The full version is 1.60.10-020-0180. Can anyone tell me if this is a newer build than the original release of 1.60?
PS-3
Homegrown HTPC
Basstrix is offline
post #3555 of 3557 Old Yesterday, 05:12 PM
alaskajoel's Avatar
My e600i-b3 is now suffering the random shut down problems. Sometimes it'll go 3 hours, sometimes 15 minutes. Super frustrating. Vizio had no suggestions and jumped right to the option of having a tech come service it. Makes me think it's a known problem, but without a solution at the moment.
Still on v1.34 fwiw.
alaskajoel is offline
post #3556 of 3557 Unread Today, 04:50 PM
aclerok's Avatar
E700i-B3 firmware 1.60
Just thought I'd pass along that I received 1.60.10-020.0190 on my tv last night. Turned it on and it looked like crap. I recalibrated based on googer's setting from December and it looks good again now
Here's the post with settings for reference:
aclerok is offline
post #3557 of 3557 Unread Today, 07:17 PM
Liked: 2
My 60" updated today as well. Nice to have a gamma setting, I'll put it on 2.2 and then recalibrate again with Disney WOW. My whole issue was the HDMI deep color setting on my BD player though, the TV has looked amazing since I turned that off.
Reply LCD Flat Panel Displays
vizio e 600-b3 , Vizio E Series E401i A2 40 Inch 1080p 120hz Led Lit Internet Hdtv , vizio m series m602i-b3
Gear in this thread - E401i by PriceGrabber.com
