Official 2014 Vizio Exxx-Bx Series owners thread - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #3571 of 3598 Old 12-23-2015, 09:58 PM
vid33nyc1's Avatar
11 pt white balance will save if you change the color temp to cool or comp before you turn off your tv.I just use any other saved pic setting that does not use normal.Works on my e600-b3.Latest update still does not fix this issue.
vid33nyc1 is offline
post #3572 of 3598 Old 12-29-2015, 03:09 PM
Quoted: 26 Post(s)
Liked: 2
Anyone else get a new firmware update? I already had 1.6 but I just got another 1.6 update out of nowhere. Can't see any new menu options but wondering if it changed something subtle.
StingingVelvet is offline
post #3573 of 3598 Old 12-31-2015, 10:59 AM
dkindig729's Avatar
Yes, I got that update last night (12/30), v1.60.10-028.0180.
I spoke with Vizio Tech Support several times in March about the 11-point white balance settings not saving and the end result of those conversations was that a firmware update was slated to fix that but there was no known ETA for the fix. Alas, that problem still exists. I still have two months left on my warranty and I might try and leverage something out of Vizio before that expires.
I haven't looked through the menus closely but I haven't noticed anything else yet. I've already done a factory reset and I'll be doing a complete recalibration for New Years Eve (what the heck, keeps me out of trouble, I enjoy myself, and it's cheap fun to boot). If I run across anything new or different I'll post again in this thread.
Originally Posted by vid33nyc1 View Post
11 pt white balance will save if you change the color temp to cool or comp before you turn off your tv. I just use any other saved pic setting that does not use normal. Works on my e600-b3. Latest update still does not fix this issue.
Will be trying this as well and will post results.
dkindig729 is offline
post #3574 of 3598 Old 01-08-2016, 09:22 PM
Quoted: 12 Post(s)
Liked: 0
I think I just got that update for my E550i-B2, yesterday or the day before. I just looked through the Menu and didn't notice any changes. I wish they would have a section on their website that showed all the updates!
TheIVJackal is online now
post #3575 of 3598 Old 01-10-2016, 05:57 AM
bel4_20's Avatar
I agree. Would be nice to see what they changed or added or fixed.
bel4_20 is offline
post #3576 of 3598 Old 01-10-2016, 09:22 AM
olyteddy's Avatar
Quoted: 526 Post(s)
Liked: 925
Anyone check their apps? I don't use them so I wouldn't know what they may have changed.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3577 of 3598 Old 01-10-2016, 02:23 PM
Quoted: 26 Post(s)
Liked: 2
I ended up just sticking with "normal" default color, but let me know if you come up with nice calibration settings. I still think "normal" is a bit too warm and muddy.
post #3578 of 3598 Old 01-11-2016, 10:06 AM
biglen's Avatar
Quoted: 102 Post(s)
My E700i-B3 has started doing this over the past few weeks. It's happened 3 times, and it lasts for a couple minutes, and then goes away. Anyone seen it before, or know what it could be?
biglen is offline
post #3579 of 3598 Old 01-11-2016, 09:39 PM
Quoted: 12 Post(s)
Liked: 0
I have seen that before on a previous TV I had. Took it all apart and it turned out to be the ribbon connections on the top of the TV. The connections had cracked or something and would "reconnect" once they heated up. Try tapping somewhat hard around that side of the TV, then maybe pinching it (not the screen, just the rim) to see if it goes away. In my case it was a Samsung and it couldn't really be repaired without a whole new panel. I semi-fixed my old Samsung by taking it apart and shoving some paper on top of the connection, between the cable and frame of the tv.
Good luck!
post #3580 of 3598 Old 01-12-2016, 03:37 PM
biglen's Avatar
Quoted: 102 Post(s)
I called Geek Squad because I have the extended warranty. I sent them a picture of the problem, and they are going to replace the TV. The tech said they don't make the model anymore, so they'll give me a compatible TV. Does anyone know which model they'll offer me? Would it be the M70-C3?
biglen is offline
post #3581 of 3598 Old 01-17-2016, 07:48 PM
dougleto's Avatar
Did anyone ever find any resolution to the problem of the TV freezing after a few minutes, not accepting any input from the remote except power off. I've had a E550i-B2 for ~1 year and it's been rock solid until tonight. Now it's freezing up after a couple of minutes being on. I've power cycled many times, I've tried 3 times pulling the power cord for ~1 minute and plugged it back in (I saw someone said they left it unplugged for 5, trying that now). I tried it with nothing but the power cord plugged in (no ethernet, no HDMI,etc.) and still had the problem. Tried another remote. Nothing. What on earth could have happened to the TV and does anyone have any ideas for what to try to fix it? I suppose I'll reset to defaults next if I'm able to get that far before it freezes up.
Update: I did a factory reset and it's still not fixed. It seems to have something to do with a network connection. When I'm connected via ethernet, it locks up. If I remove the cable and I'm not connected over Wifi, it works fine. So that's where I am right now, can't think of anything else to try.
dougleto is offline
post #3582 of 3598 Old 01-20-2016, 04:19 AM
clone1008's Avatar
Quoted: 25 Post(s)
Liked: 27
I am having a problem with my e550i-b2 that I don't see mentioned in here. When trying to calibrate this set the 11 point white balance doesn't work at all. I can get a fairly decent calibration with the 2 point but would really like to be able to utilize the 11 point. Any suggestions?
clone1008 is offline
post #3583 of 3598 Old 01-28-2016, 07:22 AM
DavidML3's Avatar
Quoted: 143 Post(s)
Liked: 61
I am seeing the E600i-B3B model being sold as refurbished from frys
If you had to do it again would any of you buy this tv?
DavidML3 is offline
post #3584 of 3598 Old 01-28-2016, 07:33 AM
dishdude1's Avatar
Quoted: 37 Post(s)
Liked: 32
How much is the refurb? Costco has the 2015 version of this TV E60-C3 for $699, 90 day return and free second year warranty. Costco also has the 4k D58u-d3 for $679. I have the E60-C3, love it.
dishdude1 is offline
post #3585 of 3598 Old 01-29-2016, 09:09 AM
Liked: 5
I had to replace the main board on mine found a new on e on ebay..Sorry don't have a link that was a while ago
kbhenze is offline
post #3586 of 3598 Old 03-14-2016, 02:20 PM
graison's Avatar
My E600 just got a firmware update to 1.90, anyone know what it does?
graison is offline
post #3587 of 3598 Old 03-18-2016, 04:10 PM
cbonilla's Avatar
Firmware update
Weill in my case it killed the ability of my E550i-B2 to talk to my Harman Kardon 1710 using CEc. Despite the fact that this occurred right after they pushed the update out, Vizio is insisting that I confirm the problem is not in my receiver. This means I have to find another CEC device ( TV ) to confirm that the problem is not in my receiver, before they'll push this up the line.
So that's how I'm spending my Saturday AM.
Anyone else have this problem?
cbonilla is offline
post #3588 of 3598 Old 03-19-2016, 07:20 AM
aclerok's Avatar
I'm not using CEC, but I am having issues. I've started getting No Signal on my TV, but will have audio coming fine through the receiver intermittently. Haven't pegged down an exact way to resolve it, but it seems switching inputs on the tv after my source is running will get the picture to show up then.
aclerok is offline
post #3589 of 3598 Old 03-19-2016, 12:11 PM
cbonilla's Avatar
TL;DR. my tv no longer supports CEC with my receiver and vizio is not going to anything about it
This weekend, as requested, I unplugged my receiver and took it to a friend's house with a Sony that supported CEC. CEC worked with his Sony but not my HK.
Just got off the phone with Vizio. Lots of apologies but no resolution is forthcoming. Or going to be. I recognize that I am one of a small subset that actually takes the time to connect the TV to an AVR receiver and an even smaller Subset that uses my specific receiver (Harmon kardon 1710) but the ability to use CEC was a reason that I brought this tv (E550i-B2).
They were very nice on the phone but the short version is I'm screwed and not happy.
The model of pushing out updates that can't be reversed is a broken model. It was all working well until they carried out the upgrade.
cbonilla is offline
post #3590 of 3598 Old 03-22-2016, 11:56 AM
cbonilla's Avatar
Update from Vizio
Over the weekend I discovered another problem. Since the firmware update I can no longer use the apps on my smart TV. Rather I can use them but sound doesn't reach my AVR (HK 1710). I figured out that if I disable CEC on my AVR and then re-enable it the Vizio will find my receiver and send the sound out. But it only lasts one power cycle before I have to do it again.
Told Vizio how disappointed I was. They offered to replace my TV with a recertified unit, same model #. If the problem recurs with the new unit they have said they will replace it with the next model. That next model is the only reason I'm going through the swap as once the new model gets the firmware upgrade I see no reason that the problem won't recur.
Onward and upward
CB
cbonilla is offline
post #3591 of 3598 Old 04-01-2016, 02:25 PM
cbonilla's Avatar
Update.
So far the new unit has been here for one day, has been through one firmware update ( but not to 1.9) and works fine. We'll see when we get to 1.9
cbonilla is offline
post #3592 of 3598 Old 04-13-2016, 09:03 AM
cbonilla's Avatar
Originally Posted by cbonilla View Post
Update.
Replacement TV going back to Vizio. As soon as it got updated to firmware 1.90 CEC stopped working with my Harmon Kardon AVR. New TV is due this afternoon, supposedly a new model that will not have this firmware
cbonilla is offline
post #3593 of 3598 Old 04-18-2016, 07:58 AM
cbonilla's Avatar
The never ending saga continues
I received the second replacement TV from Vizio. Unfortunately the sent another of the same model. It was already running firmware 1.9 so out of the box it wouldn't talk to my Harman Kardon 1710 using CEC
Talked to Vizio and they are sending a version of the next model. Hopefully third times a charm
CB
cbonilla is offline
post #3594 of 3598 Old 05-23-2016, 03:29 PM
cbonilla's Avatar
Sigh. No luck with the replacement E55-C2.
Same problem.
cbonilla is offline
post #3595 of 3598 Old 01-07-2017, 05:38 AM
doncaruana's Avatar
Hoping some folks are still watching this thread...
Have an e600ib3 I bought for my dad in 2014. Was working fine and my dad moved. Now he can't get on the internet with it - just says "Download: Not available"
It connects to the wireless router and I've even tried wiring it direct to the router, so no passphrase issues or anything. I even tried making it the DMZ machine in the router - no help. I've held the power button down and done a few factory resets - no change. Also set the DNS at 8.8.8.8/8.8.4.4 and that hasn't helped either.
He has comcast with a netgear C6300 cable modem/gateway (this is what we plugged into directly). The TV is on the network and I even see in the router logs attempts to go out, although I'm not sure if they ever made or anything came back.
He has firmware 2.0.13.0180 on it. Vizio support was of course useless.
Does anyone have any suggestions?
doncaruana is offline
post #3596 of 3598 Old 01-08-2017, 10:02 PM
seneschal's Avatar
Quoted: 35 Post(s)
I had the same problem. Apparently it's a DNS settings issue.
Check this out:
http://smallbusiness.chron.com/resol...zio-38190.html
seneschal is offline
post #3597 of 3598 Old 01-08-2017, 11:54 PM
doncaruana's Avatar
Check this out:
Forgot to mention we did that too. That doesn't help either.
post #3598 of 3598 Old Yesterday, 11:30 PM
Quoted: 12 Post(s)
Liked: 0
I'm curious, is anyone else having an issue where the TV does not respond to the remote for the first 10-seconds or so from start up? Really annoying to have to try and remember to turn the volume down at night so it's not blasting in the morning, I get up before my wife does
Please share if you have found a resolution! Thanks.
Reply LCD Flat Panel Displays
vizio e 600-b3 , Vizio E Series E401i A2 40 Inch 1080p 120hz Led Lit Internet Hdtv , vizio m series m602i-b3
