Official 2014 Vizio Exxx-Bx Series owners thread - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #2881 of 3597 Old 10-13-2014, 11:03 AM
Googer's Avatar
Quoted: 306 Post(s)
Liked: 264
Originally Posted by suppaman View Post
That would be odd then, the 55" b2 was supposedly only an IPS panel in both the E and M series based on what I had read. Maybe it was wrong or Vizio has changed up panels in the 55?
As I said, I was expecting to find it was an IPS too but when I looked closely with my naked eye I thought the subpixels looked straight, which is when I pulled out the loupe to make sure I wasn't just seeing things. It'd be hard to mistake an IPS panel for a VA when you're staring at it from about an inch away at 20x magnification though (so effectively about 0.05" away).
Googer is offline
post #2882 of 3597 Old 10-13-2014, 03:11 PM
TyBauz's Avatar
Liked: 0
Originally Posted by iceblast View Post
The ribbing and blooming is from the Active LED Zones being On. If you just turn it Off, the E series looks great. The E600i-b3 is the best deal for the money.
I understand turning off the active LED zones will make the negative side effects go away, but I feel like my picture might not be as good as if the zones worked as advertized. If the M series works properly, it seems that the picture quality would be far superior with the 32 active LED zones compared to an E series with the active LED zones turned off. It's $320 more to upgrade. I'm just wondering if it is worth it.
TyBauz is offline
post #2883 of 3597 Old 10-13-2014, 09:35 PM
Liked: 0
Originally Posted by Googer View Post
I took a loupe to my E55 in the guest bedroom yesterday and it sure appeared to be a VA despite the claimed 178 degree viewing angle (I was expecting IPS given the M55 and P55 are IPS but the magnification makes it pretty clear what I was looking at - straight subpixels, no chevrons ). Also, this isn't confirmation for the 50 but the claimed 176 viewing angle highly implies VA...
I now own E50 and can confirm it is VA. I don't have magnifying glass though, but black levels are very good, definitely not IPS.
antarius55 is offline
post #2884 of 3597 Old 10-13-2014, 09:59 PM
iceblast's Avatar
Quoted: 204 Post(s)
Liked: 59
IMO, the difference between ALZ On and Off is very little on the E600i-b3, I really don't feel like I'm really missing out on anything. Sure, it would be nice if they had made ALZ work properly, but they didn't. But the tv is still nicer then most of the one's out there, and for less then $800 for a 60" that looks this good, is just plan awesome. I don't think $300 more for the M is worth it, for just a small improvement.
I sit in a dark room, and the blacks are great, and you can't even see the bezel.
Gigabyte G1.Sniper 3, 950watts, Intel 3770k, 32gb ram, 34tb, Sli Nvidia 480, THX Sound Card, Logitech THX z906 Speakers, E600i-b3, Yamaha v375, Cerwin Vega VS150, VS120, L7's, and Klipsch 2.2
iceblast is offline
post #2885 of 3597 Old 10-13-2014, 10:01 PM
unrly's Avatar
Originally Posted by unrly View Post
Yep. You're not alone. Myself and another user have had this issue. He got it figured out, see this post: http://www.avsforum.com/showthread.php?p=27988714.
Finally called Vizio again, they're sending out a tech for repair. I'll update on what they do.
unrly is offline
post #2886 of 3597 Old 10-13-2014, 10:15 PM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
Hello, just saw this forum and thought I'd chime in. I bought an E700i-B3 last month and I like it quite well. I like the Rtings link someone posted on this set, nice to see they think it is as good or better than the M series, thanks. I do have a few questions though.
1) I didn't even know the term "blooming" till I saw it a couple pages back and I haven't yet seen the "blooming" issue, is the general consensus that it is best to turn off active LED zones?
2) I like the built in color and gray scale images, but I want to try something more precise. I know I can buy a bluray, but I found these pics https://www.flickr.com/photos/wrwetz...57639660382103 (they are all 1920x1080) Can I just copy these to a thumb drive, bring them up on the TV and use them to adjust? I am mostly interested in getting the white and black levels correct. Also I like Black detail set at "low", but it bugs me that it is basically just changing the brightness that I just set up. Should I set the brightness and contrast with in on low or off?
Also, I saw someone asked about reds looking "beet red", yes I have noticed that to some degree, hoping calibrating it might help.
And lastly, the menu has a glitch, sometimes when I go into the preset video select screen, I can't change between selections properly. Every 1/2 second (or so) it reverts back to the setting you entered the screen on, has anyone else seen this?
Home Theater: Emotiva UMC-200, Citation 5.1 running Mirage M-3SIs, Harman Kardon signature 2.1 running Mirage M-CSI (center) & 4x BIC V-52 (surrounds), 2 x Velodyne ULD 15 Series II Sub & Amp, PS3, PS4, XBOX 1, 2x Adcom ACE-515, Vizio E-701B-3
2.0 setup: Acurus LS11, Citation 5.1, Mirage M3SIs, Onkyo DV-CP702 (CD transport), Schiit Modi Multibit DAC.
brad1138 is offline
post #2887 of 3597 Old 10-14-2014, 12:15 AM
Liked: 0
Sorry if this has been posted, but I don't have time to sift through 140 odd pages to find this; does anyone have picture settings for the 70in? I used settings from the M series by accident. Still looks great but wondering if it can look even better.
bg1188 is offline
post #2888 of 3597 Old 10-14-2014, 09:26 AM
SirDracula's Avatar
Quoted: 172 Post(s)
Sharpness question (E 60"): last night I watched Transformers AOE off Bluray using the stock Computer Mode which I find adequate. While it looked very good overall, I noticed that some scenes, usually closeups were very grainy (or noisy). Anyone else noticed the same? Is that normal? How do you deal with it? Set the sharpness to 0?
My bluray player outputs 24p and it then goes through a Denon AVR which should not be messing with it, but who knows what it really does in the process.
SirDracula is offline
post #2889 of 3597 Old 10-14-2014, 11:08 AM
suppaman's Avatar
Quoted: 17 Post(s)
I didn't have any issues with graininess when I watched that movie. I had issues with a horrible film that was way to long though.
brad1138 likes this.
suppaman is offline
post #2890 of 3597 Old 10-14-2014, 11:51 AM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
I have the E700i-B3, my settings are just what I like, I started from "Calibrated" and used the built in color bars & gray scale:
Auto Brightness - Off
Backlight - 80 (for when I want a brighter pic, I have it set at 90, night 60)
Brightness - 40
contrast - 65
Color - 42 + (still not sure on this, but definitely under 50)
tint - 0
Sharpness - 10 (again, not real sure whats best on this, from what I read, it really should be 0)
Advanced Pic
Black Detail - Low
Active LED Zones - On
Smooth Motion effect - Low
Motion Blur Reduction - Off
Reduce signal noise - Off
Reduce Black Noise - Off
The last 2 I couldn't see a difference with, so I turned them off. There really shouldn't be any "noise" in a digital picture.
On the color setting, I have always felt that colors on TVs are way more colorful than they should be, I usually back it down to be more realistic.
brad1138 is offline
post #2891 of 3597 Old 10-14-2014, 03:34 PM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
Last week my TV had an update message on the screen saying"policies" or something similar had been updated, and I had to select OK. Do these TVs automatically update software or firmware?
brad1138 is offline
post #2892 of 3597 Old 10-14-2014, 06:46 PM
one028's Avatar
do you have a better link to the post? it doesn't take me anywhere..
thanks..
I found that I have an issue when I had multiple HDMI sources powered on. However, my wife said she has had the issue when using Netflix. I don't use it so I can't confirm, but I need to call LG again. The guy on the phone told me that they'd send a tech out if a power cyclr/factory reset didn't work so that's my next step.
one028 is offline
post #2893 of 3597 Old 10-14-2014, 07:16 PM
Ph8te's Avatar
Quoted: 4544 Post(s)
Liked: 3976
Yes if connected to the internet all Vizios automatically update firmware and or software.
I'm lost in the blue nowhere.
Ph8te is offline
post #2894 of 3597 Old 10-14-2014, 07:17 PM
unrly's Avatar
thanks..
Sorry, apparently the Tapatalk link didn't work. Try this one Official 2014 Vizio Exxx-Bx Series owners thread
I called yesterday and they are having the techs call me soon to come out and fix it. Their turnaround time is pretty quick I think.
unrly is offline
post #2895 of 3597 Old 10-15-2014, 04:18 PM
Liked: 0
I am thinking of buying the E500-B1 model. I will primarily be using it to watch sports, in particular hockey. Does anyone have any information on motion blur for this TV? Is it a good TV for sports?
Baumerman77 is offline
post #2896 of 3597 Old 10-16-2014, 12:55 PM
garikfox's Avatar
Anyone using Component and Audio out ?
Every now and then I'll turn on the TV and theres no sound until I change the volume up or down then the sound comes in.
"Humans aren't the only species on Earth, We just act like it..."
garikfox is offline
post #2897 of 3597 Old 10-17-2014, 10:55 AM
suppaman's Avatar
Quoted: 17 Post(s)
I'm using HDMI and audio out with no issues.
Though I do want to ask you or anyone who is using audio out or optical out, if you engange the local dimming, when that happens do your speakers output a click?
I'm wondering if it's the TV doing it or if it's because I have a monster green power surge protector that when the TV is off shuts off the speakers/etc that are in certain plugs. I never paid attention to if it's my speakers just shutting off and on (would seem odd since the TV is still powered on, but its the backlight shutting off). I'm thinking it's the TV click sound and the speakers output it as well making them pop.
Really annoying right now because my personal preference depending on what I'm watching on the TV i sometimes like to occassionally use the FALD.
suppaman is offline
post #2898 of 3597 Old 10-17-2014, 04:29 PM
Liked: 0
Newbie and loving it
I'm a little new to the level of detail that you guys go into, so excuse me.
I have the Vizio E 60" and a friend of mine at work gave me his Spears and Munsil, which I plan on using tonight.
In terms of black levels, should I focus more on the brightness setting or backlight setting.
Sorry if I missed the answer to this question.
NStelmaschuk is offline
post #2899 of 3597 Old 10-17-2014, 11:01 PM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
Brightness. Contrast for white level. Backlight is more to do with how bright your room is, contrast/brightness should be set and do not change depending on day or night.
I turned the auto backlight off on my 70" and made a couple different presets. I have the backlight at 80 for daytime and 60 for night.
brad1138 is offline
post #2900 of 3597 Old 10-18-2014, 03:10 PM
SeanBuchanan1985's Avatar
hey everyone. I recently got the 70 inch and absolutely love it. I used cnet's pic settings and it looks amazing. The question I have is if there is a way to get firmware updates from vizio's site. i have the 50 inch version in my game room and it updated the other day when i turned it on but the 70 has never updated itself. in fact i ended up getting a roku 3 because the apps on the vizio like netflix never kept a connection. Just wondering if there is a way to make it check for an update or not. thanks in advance
SeanBuchanan1985 is offline
post #2901 of 3597 Old 10-18-2014, 03:20 PM
Ph8te's Avatar
Liked: 3976
There is no way to get the firmware other than wait for Vizio to push it out to your set.
Sent from an system/360
Ph8te is offline
post #2902 of 3597 Old 10-18-2014, 03:42 PM
ok great. thanks for the info!
post #2903 of 3597 Old 10-18-2014, 08:08 PM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
Which model 70 do you have and what Cnet settings?
brad1138 is offline
post #2904 of 3597 Old 10-19-2014, 03:20 PM
Liked: 0
Hi, I'm new to the forums here and recently just bought a 60" Vizio e600-b3. Mounted it the first day I bought it, had it for a couple weeks now and loving it, great bang for the buck. However, just last night something caught my eye. I'm not sure if it was there all along and I just missed it, or that it just popped up not too long ago. Along the middle-right side of my TV, there's what looks like a black smudge that runs from the edge to the middle of the screen.
imgur.com/4SYgYT0
imgur.com/s2Hd8DW
imgur.com/rJingJ6
(Sorry about not being able to post the links! I'm new!)
I haven't touched any of the settings other than hooking up the wifi to use the Smart TV apps. Is it possible that it could've been damaged when I wall mounted it and never noticed? Thanks for the help!
kitch907 is offline
post #2905 of 3597 Old 10-19-2014, 06:23 PM
SirDracula's Avatar
Quoted: 172 Post(s)
^^ Try turning off local dimming and see if it makes a difference. Also try Computer Mode under Picture.
post #2906 of 3597 Old 10-19-2014, 09:47 PM
pcguru83's Avatar
I created a thread earlier today about an issue I'm having with my E480i-B2 that I'd like to get some thoughts on. Looked around a bit for an "official" thread for these TV's, but didn't seem to find one. Of course it pops up right near the top shortly after I post. Here's the original post if anyone is curious.
In summary, started out having what I'd describe as very, very faint grey bars about 1" wide running vertically on the far left and right side of the screen. The right side is slightly more noticeable than the left. Tried adjusting backlighting, but no dice. I've also checked Active LED Zones and confirmed that is disabled with no change. It's really hard to see with a normal image on the screen, but definitely can be spotted on grayish backgrounds.
Decided to try my luck at another one, so picked up another this evening and figured I'd just return one or the other depending on what I found. This one seems much better with regards to the grey bars (virtually non-existent), but the new one seems to have some much more pronounced lighting uniformity issues, especially in the corners.
Any thoughts on what I should do now? I'm really not all about trying a third one (but will if it's perhaps worth another try), as I'm honestly really thrilled with the picture aside from these issues. If I decide to keep one or the other, which will be less noticeable in real-world use: dark corners or a faint grey rectangle on each side? My quick first impressions have me leaning towards the grey rectangle being less noticeable, but I'd be curious if anyone else has experienced any of these issues and what you ended up doing.
Name:	TV1 - Faint Grey Bars_01.jpg
ID:	320873   Click image for larger version
Name:	TV1 - Faint Grey Bars_02.jpg
ID:	320881   Click image for larger version
Name:	TV2 - Dark Corners_01.jpg
ID:	320897   Click image for larger version
Name:	TV2 - Dark Corners_02.jpg
pcguru83 is offline
post #2907 of 3597 Old 10-20-2014, 03:13 AM
mdog73's Avatar
I am thinking of buying the 60 inch for my front room which is pretty well lit. It will be replacing my Panasonic plasma which will go in my cavelike bedroom. I am assuming that these LCDs still perform well in well lit rooms, is that correct? Also, how does this do with sports and heavy action scenes? I have heard the picture is much better these days but I know in the past they had issues handling rapid movement on screen.
For those of you who have both a plasma and an lcd do you experience any issues when going back and forth, I figure the LCD will be much brighter in general, will I have to do some serious adjusting of the settings to make them comparable.
It seems like great bang for your buck, kind of hard to pass up when I need a second TV. Currently my tv for the bedroom is a crt and needs to go.
mdog73 is offline
post #2908 of 3597 Old 10-20-2014, 04:42 PM
RosevilleHT's Avatar
My remote crapped the bed on Friday. New batteries didn't help, also tried using my Wii-U as a "remote" and no dice. Chatting with Vizio support now to see what they can do.
*Edit: It's not the remote, it's lighting up when I look at it through a camera. Looks like they want a copy of my receipt before doing anything. Smells like a replacement TV. I hope they make good on this, it's my first experience with Vizio.
RosevilleHT is offline
post #2909 of 3597 Old 10-20-2014, 05:27 PM
Ph8te's Avatar
Liked: 3976
Have you tried turing off the power LED in advanced settings? If not try that and see if it helps.
Ph8te is offline
post #2910 of 3597 Old 10-20-2014, 05:31 PM
SirDracula's Avatar
Quoted: 172 Post(s)
Sorry, could you please expand on what the deal is with the power LED?
Reply LCD Flat Panel Displays
vizio e 600-b3 , Vizio E Series E401i A2 40 Inch 1080p 120hz Led Lit Internet Hdtv , vizio m series m602i-b3
