HDMI port not working on TV - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2014, 06:03 AM - Thread Starter
larryecook's Avatar
Hi my name Larry I have a flat screen TV that was made by Syntax-Brillian Corporation . It has the name Olevia Engraved on the front the model number is LCD HD Olevia 232-T12. It was working fine until recently. The HDMI port stopped working. When I plug my Playstation 3 into the HDMI port it says no signal. I've tried plugging the Playstation 3 into other HD TVs and it works fine. I did a little research on the Olevia website it suggested I up date the firmware. When I went to the website I could not find the firmware I was wonder if you could help me locate it or suggest something else to fix my TV?
larryecook is offline
Old 01-13-2014, 08:46 AM
Ratman's Avatar
Quoted: 1291 Post(s)
Liked: 1032
Olevia/Syntax-Brillian is out of business since around 2008.
First, I'd try unplugging the TV from wall power for a few minutes. While unplugged, connect the HDMI cable from the PS3 to the TV and then plug in the TV and power on.
If you want to take a big chance, here's a link I found. USE AT YOUR OWN RISK!
http://seoanalyses.com/download/olevia%20232%20t12%20firmware%20download
Ratman is online now
Old 03-04-2014, 04:18 PM - Thread Starter
larryecook's Avatar
That link doesn't work it's dead when I unplugged the TV and plugged the PS3  back in the screen turned black but nothing happend.
Old 03-05-2014, 06:26 AM
Ratman's Avatar
Liked: 1032
It worked on January 13.
Old 03-05-2014, 03:21 PM - Thread Starter
larryecook's Avatar
 Well I unplugged everything like you said. When I plugged everything back and turned my ps3 on the screen  was black.But it did not say no signal
Old 03-16-2014, 01:34 PM - Thread Starter
larryecook's Avatar
I found another post on this forum that had a download link that worked. But I'm not sure if the firmware is the correct firmware for my TV. The update came with instructions.The instructions say it's for 232 models. I have an   LCD HD Olevia 232-T12. Do you think it's right. Here is the post I'm referring to
http://www.avsforum.com/t/756206/olevia-32-2-series-lcd-hdtv-232v/1440
