New Sony 2014 HDTV Models - Page 6 - AVS Forum
post #151 of 159 Old 03-19-2014, 11:36 AM
tgm1024's Avatar
Quoted: 631 Post(s)
Liked: 925
Originally Posted by ttownaudio View Post
It is funny how early reviews of the 950b are luke warm
Originally Posted by fafrd View Post
Where have you seen any reviews of the 950B - I thought that set was not due to be available before August???
Both of you: please stop referring to the TV as a "950B".
Sony reuses a lot of their numbers and in order to identify the set, make sure to put in the model family prefix.  In this case a "W"....(I presume) you are discussing the W950B.
For instance, there are two 65" 950B's.  XBR-65X950B and KDL-65W950B.  They are dramatically different TVs.  And this conversation will go haywire if we're not careful.
rodtsasdt 111111report*
P-1 CUR ALLOC 20195.....5805M
HELLO GREGORY
tgm1024 is offline
post #152 of 159 Old 03-19-2014, 11:43 AM
jetjocky's Avatar
Liked: 27
Originally Posted by PureHazard View Post
That's not the only negative review.
http://www.digitalversus.com/tv-television/sony-bravia-kdl-55w955-p19445/test.html#full-review
Well now I am rethinking about an interim TV before going 4k. Thanks to all who replied for the info, nothing worse than making decisions in a vacuum. check6
jetjocky is online now
post #153 of 159 Old 03-19-2014, 11:48 AM
Covfam's Avatar
Liked: 43
if your thinking of an interim TV you should look at the sharp UQ series it's a better than 1080p high quality picture but not quite uhd, but it is cheaper than an uhd TV untill the Vizio P series is released
Covfam is offline
post #154 of 159 Old 03-19-2014, 12:25 PM
ttownaudio's Avatar
Check my post #127. Also check Pure Hazard's post #146
ttownaudio is offline
post #155 of 159 Old 03-19-2014, 02:00 PM
ttownaudio's Avatar
Sorry for the confusion. Point taken. My comments were regarding the Sony W-series.
post #156 of 159 Old 03-19-2014, 03:57 PM
tubetwister's Avatar
Location: Sacramento delta N. Cal. US Don't trust any air I can't see ☺
Quoted: 626 Post(s)
Liked: 380
I'm generally not a Fan of LG ips panels (at least most that I have seen ) although IMO the Sony KDL 50,60,70 R550A are pretty decent .
I have an LG 42LN5300 (LG ips panel ofc. ) in one bedroom and a Sony KDL 40R450A in my bedroom with a Samsung SPVA panel .
The LG has a better viewing angle and the Sony has an abysmal viewing angle but the Sony has a much better picture ( pretty good ) in all other respects
I have 2 other sets with SPVA / VA panels they both beat the LG picture wise also . OTOH the Sammie plasma rules the roost here with the Sony in 2nd place.
Hires Music formats ..............."Why does it sound like a CD ?" ............. can we make it louder "?
"The wireless music box has no commercial value. Who would pay for a message sent to nobody in particular?"
- David Sarnoff's associates at RCA the 1920's -
tubetwister is online now
post #157 of 159 Old 03-19-2014, 04:20 PM
tgm1024's Avatar
Quoted: 631 Post(s)
Liked: 925
How did you find out that your R450A had a Samsung SPVA panel?  displaysearch.com?
HELLO GREGORY
tgm1024 is offline
post #158 of 159 Old 03-19-2014, 04:41 PM
Quoted: 626 Post(s)
Liked: 380
The easy way I went into the service menu, it gives you the panel version # and manufacturer then I looked it up at panelook .com
post #159 of 159 Old 09-16-2014, 07:39 AM
brahby's Avatar
Quoted: 13 Post(s)
If I read correctly the 65W950B should be using the same manufacturer and type of panel as my 60R550A? So if the black levels on my R550A are acceptable to me then they should be from the W950B as well correct?
brahby is offline
Reply LCD Flat Panel Displays
Sony Kdl65w850a 65 Inch 3d Led Hdtv , Sony , Ces 2014
