Wanted - Recommendation for a Presentation TV/Monitor to be video'd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-06-2014, 09:51 AM - Thread Starter
RandNotAyn's Avatar
I'm going to make a number of web videos want to use a TV, on a table next to me, to show PowerPoint-ish slides.
Most every slide will be simple text and/or static image on a blue background or such (a typical slide layout would be something like the Departure/Arrival screen at the airport ... big text... or perhaps something like the menu screen of a cable service... I want sharp edges ... it's not movies.)
I'd like 46-50". HDMI (I'll be using an iPad Air to navigate through the slides ... mirroring.)
Video, Nikon D3200, will be 8-12 feet away.
So the question is:
- Do any specs matter for this application? ... refresh rate, pixel density? ... or is any LED monitor going to be plenty good enough and I'll be ok buying a cheap one.
I'm also told plasma is far heavier ... and that LED is better than LCD, even with backlight?
Thank you,
Randy
RandNotAyn is offline
Reply LCD Flat Panel Displays
