Help with my Sony KDL-32EX500 LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-10-2014, 10:53 AM - Thread Starter
dopax's Avatar
Greetings to all:
I would appreciate your help regarding some data that I need about this TV , equipped with the Bravia Engine 3 ; data that I need for proper configuration of soft I use with the HTPC that I've connected via HDMI to it , and I'm not able to find or confirm :
- These data are the range supported by this TV ( 16-235 or 0-255 ??? ) and bit depth of the display ( 8 or more ??? )
I don't know if this will do any good data but according with http://www.avsforum.com/t/1381724/of...ampling-thread , my TV supports 4:4:4
Thanks in advance
dopax is offline
post #2 of 2 Old 02-12-2014, 11:34 AM - Thread Starter
dopax's Avatar
~~nobody can help me?? ............. I have configured ATI catalyst full RGB 4:4:4 and 0-255 in dynamic range, also I have 0-255 in madVR as dynamic range but unconfirmed if my TV natively supports not know if this configuration is correct.
dopax is offline
Reply LCD Flat Panel Displays
