Couple of Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-10-2014, 02:20 PM - Thread Starter
nmoore125's Avatar
*** Budget
Really upwards of $3000 for the right set up. I do need to buy a new AV Receiver and a PS4. I could go a little more on the budget for the right deal but would prefer to stay below.
*** Seating Distance.
This will range from 10feet in the Recliner to 13 Feet on the couch
*** Size/Placement Limitations
Nothing that I could think of. This will go on my stand which is plenty big enough for everything on the market it appears
*** Uses and Sources
DirecTV Genie, Xbox One, Xbox 360, PS4. Also have Chromecast and occasionally pc. ( I have a very high end pc that I may occasionally try on the new tv but rarely if I do)
*** Room Lighting
I would consider it average. Not to dark not to light. If anything I would say more towards the lighter side mornings and darker side afternoons.
Here are some of my thoughts and I just seem to be creating myself a big vicious circle in my head. I really dont care for 3D but it seems the best picture quality tvs have 3d. I will do some video gaming. I flat out just want the best picture for the buck.
I really like the Sony KDL-55W900A that seems to be on sale right now but I am just afraid the 55 inches would be to small. I am upgrading from my 50inch sammy plasma now. Then the last 2 days I talked myself into getting either the Samsung 60 inch f8000 series or the Sony KDL 65W850A. I really love all the features from the Samsung but do I really need this? I dont think I probably do. I see both these sets are around the 2500 ish mark but can be bought at abeofmain or bigboxstore or a couple of other places for 1900.. Are these stores same to purchase from??? Why are they so much cheaper? Will Amazon or Best Buy match these places?? I think I would go with one of those larger tvs if I could get that price point.
That being said if I dont get that price I may just say screw the 3d and more expensive sets. Which leads to my next question.. Is there a tv without 3d that has as good a picture quality out there? What is the "best" non 3d tv.
Love this website and thanks for any responses.
nmoore125 is offline
post #2 of 2 Old 02-10-2014, 07:44 PM - Thread Starter
nmoore125's Avatar
Well Crap I would have swore I put this in the "help me choose" thread. I apologize. Mods you can move if you want. I hope I can still get a response or 2 even though its out of place.
Reply LCD Flat Panel Displays
Sony Kdl 55w900a 55 Inch Led Hdtv
