Vizio E601i-A3 vs. E550i-B2 ... motion trails and edge lit vs. full array - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-19-2014, 05:34 PM - Thread Starter
Adam Bomb's Avatar
I am currently an unhappy owner of a Vizio E601i-A3 TV and am considering returning it and getting a E550i-B2. My main problem with this TV is motion trails in dark areas of the picture.. it's very noticeable in poorer quality video and video games. The store I purchased from now has the E550i-B2 in stock which boasts full array backlight with backlight scanning and local dimming.. My current TV is only edge-lit, could this be the cause of motion trails? I haven't been to the store yet to see if they have a display model set up... but with the bright video they display in the store I don't know if I would be able to detect it. Thanks for any input
Adam Bomb is offline
post #2 of 7 Old 02-19-2014, 07:33 PM
sytech's Avatar
Quoted: 1995 Post(s)
Liked: 1405
Even though there are only a few zones the full array should help with clouding/hot-spotting. The backlight scanning should help with motion and the local dimming should help with contrast. I would definitely go for it and since you state you are unhappy with your A3, what do you have to lose. You can always just get a refund if the B2 doesn't work out for you either.
DON'T ARGUE WITH ME. I AM NEVER WONG.
sytech is offline
post #3 of 7 Old 02-21-2014, 11:00 AM
drameddie's Avatar
Quoted: 23 Post(s)
I'd like to hear more about the Vizio E550i-B2. I'm debating on that or the M551d-A2R. I wonder if the improvements on the E550i-B2 makes it better than the M551d-a2r. If so, i don't mind not having 3D.
I own the Vizio M602i-B3.
drameddie is offline
post #4 of 7 Old 02-21-2014, 11:11 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2612
The effective refresh rate of both the Vizio E601i-A3 and the E550i-B2 is 120Hz, so I would not expect much difference in terms of motion blur between these two sets. For the best motion blur reduction, be sure you have frame interpolation activated.
As sytech stated in an earlier post, the FALD panel of the E550i-B2 should result in improved contrast and dark image performance over the E601i-A3.
You also might consider posting your dissatisfaction with motion trails on the E601i-A3 in the owners thread in case there are any owners that can give you insight on the best combination of settings to reduce/eliminate the problem...
-fafrd
fafrd is offline
post #5 of 7 Old 02-21-2014, 02:04 PM - Thread Starter
Adam Bomb's Avatar
I went ahead and returned the E601i and got the E550i-B2 and can't be happier. No motion trails at all, big difference
post #6 of 7 Old 02-21-2014, 02:18 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2612
Interesting - thanks for the feedback. Did you check whether any other E601i saw these motion trails as well?
At any rate, if you are happy with the E550i-B2 that's the important thing...
fafrd is offline
post #7 of 7 Old 02-21-2014, 02:55 PM - Thread Starter
Adam Bomb's Avatar
Yes, I had taken one back for that problem and got another identical replacement. It had the same problem
Reply LCD Flat Panel Displays
Vizio E601i A3 60 Inch Led Lcd Hdtv , Vizio E550i B2 55 Inch Smart Led Hdtv
