total screen not showing up on UN60F7100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2014, 06:32 PM - Thread Starter
technobot's Avatar
Something odd started happening on my UN60F7100.  I think it just started. I am not sure if it is the TV or Suddenlink/PACE cable box.
I can't see the entire screen.  See the picture. The TNT is shopped off.  On many channels that overlay text/graphics, it seems to be truncated.
I have tried all Picture sizes.
See the TNT on bottom right is cut off.
technobot is offline
post #2 of 3 Old 02-19-2014, 08:18 PM
wtfer's Avatar
Quoted: 147 Post(s)
Liked: 40
Definitely looks like the zoom picture size option is enabled.
Did you try to see if this happens with blu-ray or DVD movies?
If itt doesn't then it's your cable box at fault.
wtfer is offline
post #3 of 3 Old 02-19-2014, 09:29 PM - Thread Starter
technobot's Avatar
Yes, my bad.  I unplugged the suddenlink pace STB and reconnected.  All is good now.  Should have tried that first.   Thanks.
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv
