No picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-26-2014, 03:53 PM - Thread Starter
Beecandy's Avatar
I have had this TV for a couple of years and have had no problems. One day I turned it on and there was no picture. I still have sound and the channels change, but no picture. Doe this TV have a picture tube like the old TV's used to have? If not, what is the problem?
Thanks for your help.
Bee
Beecandy is offline
post #2 of 3 Old 02-26-2014, 06:56 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 853
It would help if you gave us the make and model of the tv so we know what you're talking about.
Otto Pylot is online now
post #3 of 3 Old 02-27-2014, 10:26 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
The problem is it ain't working right but like Otto says without the make and model we can't tell anything .
If it is 2 yrs old It's probably safe to assume it is either a Plasma , CCFL /LCD or LED/LCD in any case the diagnosis and repair and especially the parts used will be different from one and other .
Some newer Sony models (and maybe some others) have a "pic off " (picture off) button on the remote that turns off the back light and thus the picture but leaves the sound on , if that's the case push that button while the set is on.
If not try pushing the picture mode pre set or similar button .
tubetwister is offline
Reply LCD Flat Panel Displays
