OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 4651Likes
post #3151 of 21981 Old 07-18-2014, 10:24 AM
Liked: 0
Gentlemen,
I recently received my 55 inch HU8550 from Amazon. I have been reading the forums since November and couldnt wait any longer for the Vizio p series. Thanks to all you folks for informing my decision.
Two questions:
1. Anyone else have trouble pairing their directv remote (the new style that comes with the genie and wireless boxes) with their Samsung HU8550? I can't seem to get it to pair. Alternatively, will the Samsung remote pair with the genie? I don't feel like using two remotes.
2. I'm sure there are calibration settings somewhere within this thread but I have been unsuccessful in wading through all the pages. Can someone who has them pm me or post a link for me? I like the vibrant colors of dynamic mode, but i can't stand any juddering....it was my one fear about this tv coming from plasma....i had it plugged in for 30 minutes and sure enough the scroll on the bottom of ESPN juddered....aarggh
Last but not least, it's true....always go with the bigger screen where tou can...kicking myself for not getting the 60 inch
JacksonBiggs is offline
post #3152 of 21981 Old 07-18-2014, 10:35 AM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
Originally Posted by screen78inch View Post
Hi, I purchased the Samsung 78inch(Europe version) screen which I got nearly weeks ago, im concerned that it was damaged in transit, I think there is considerable backlight bleeding. Does anyone have anything similar? Cheers
Try setting smart LED to standard or high. Looks like it is set to off.
doctorwizz is offline
post #3153 of 21981 Old 07-18-2014, 10:37 AM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
Originally Posted by JacksonBiggs View Post
Gentlemen,
Two questions:
That ticker won't judder if you set auto motion plus to custom,
Blur-10
Judder-5
post #3154 of 21981 Old 07-18-2014, 10:44 AM
tontondavid's Avatar
Quoted: 90 Post(s)
Liked: 26
Originally Posted by Hisma View Post
That's really bad. BUT, there was another user here that had clouding just as bad as you, and he got rid of almost all of it by the buffing technique.
I think it was @tontondavid .
Do you have pictures?
tontondavid is offline
post #3155 of 21981 Old 07-18-2014, 10:45 AM
Quoted: 12 Post(s)
Liked: 0
Cheers for the replies, the smart LED setting is on standard , would putting it on high make a difference?
screen78inch is offline
post #3156 of 21981 Old 07-18-2014, 10:46 AM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 206
I don't understand the question. Perhaps I was wrong? I know someone else here had clouding that looked just as bad as that picture, and they got rid of almost all of it by buffing. I thought it was you, but it might have been someone else. Let me see if I can do a quick search...
Hisma is online now
post #3157 of 21981 Old 07-18-2014, 10:46 AM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
It should. It would make the screen darker.
post #3158 of 21981 Old 07-18-2014, 10:48 AM
Quoted: 12 Post(s)
Liked: 0
Here is the pic
Name:	backlight bleed.jpg
post #3159 of 21981 Old 07-18-2014, 10:49 AM
Quoted: 90 Post(s)
Liked: 26
I did have pretty bad clouding as well. I was just asking if that person had pictures so we could see.
The buffering did help a lot but it was a challenge getting rid of them.
post #3160 of 21981 Old 07-18-2014, 10:50 AM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 206
ahh gotcha
Hisma is online now
post #3161 of 21981 Old 07-18-2014, 10:54 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Take a soft microfiber cloth and start rubbing in circles, pressing gently. Use this exact scene. The clouding will disapear.
vddobrev is offline
post #3162 of 21981 Old 07-18-2014, 10:56 AM
Quoted: 12 Post(s)
Liked: 0
I will try the high setting tonight when it’s dark outside, I have large windows that will make it difficult to judge any improvement. Do you think this screen might warrant a return? also any ideas what the best calibrated setting would be for this set?
post #3163 of 21981 Old 07-18-2014, 11:13 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
Originally Posted by vddobrev View Post
Custom seems OK, but the other 2 are terrible, it should not be like this. I haven't followed your problem, but have you tried to remove the receiver from the link, i.e. plug blu ray directly in the TV? Check blu ray player settings like resolution, refresh rate set it to 24p...
I ruled out the AVR being the problem by testing the TV by using the built in Netflix app. I flipped through things until I found a similar setup (dark object moving over light background). A good example is a scene in S02E02 of house of cards. A guy is walking through a news room and the ghosting is just as bad.
The vids I posted don't really give you the full impact its much worse in real life.
TV: Samsung 75HU8550 / SEK-3500U/ZA
AVR: Onkyo TX-NR636
Speakers: KEF T205
Devices: Xbox One S, Nvidia Shield TV, Wii U, Cable Box, NES Classic (coming Soon)
PC: Intel Core i5-4670K, 8GB GTX 1070, 500GB Samsung EVO SSD, 16GB DDR3
Phrawst is offline
post #3164 of 21981 Old 07-18-2014, 11:17 AM
Quoted: 90 Post(s)
Liked: 26
Here is the pic
Wow, mine was the same in two corners but not all like you.
If you use the rubbing technique then be patient because it may take you a while. You may have to repeat the process several times.
The key is to do it slowly and not to fast.
Good luck.
post #3165 of 21981 Old 07-18-2014, 11:41 AM
Quoted: 12 Post(s)
Liked: 0
Cheers I will give it a go, however Im a bit apprehensive, first of all I will contact Samsung as I don’t want to void the warrantee. I’m thinking that the screen got damage when it was lifted up to my 1st floor apartment, the delivery men seemed to apply pressure when going up my winding staircase. Could that create clouding such as mine?
post #3166 of 21981 Old 07-18-2014, 11:59 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
I would return it then, I had the European hu7500 and now hu8500, I haven't seen anything as bad.
vddobrev is offline
post #3167 of 21981 Old 07-18-2014, 12:05 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Yes, this would be the primary reason misaligning the glass during transportation, but try rubbing. Then if no result, use warranty or return it.
vddobrev is offline
post #3168 of 21981 Old 07-18-2014, 12:16 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 206
buffing won't void the warranty. In fact, the whole idea was spawned by a recent TV interviewer whom contacted samsung about his excessive clouding, and samsung support suggested he try the buffing technique. Since that review, a number of AVSers here have tried it, with very good results.
Returning TVs is such a hassle, I would try buffing first to see if it helps enough, and if you're not satisfied then return it.
Hisma is online now
post #3169 of 21981 Old 07-18-2014, 12:28 PM
Quoted: 12 Post(s)
Liked: 0
agreed a big hassle to return it, thanks for the help, i will give the buffing a go.
post #3170 of 21981 Old 07-18-2014, 01:01 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Here is the pic
Junk it ☺,make Samsung send someone out to buff it , ☺ or make them give you another one or buy something else!
The question is if buffing would work in this case would it be a permanent fix ?
tubetwister is offline
post #3171 of 21981 Old 07-18-2014, 01:20 PM
Hisma's Avatar
Quoted: 525 Post(s)
Liked: 206
yes, buffing is a permanent fix.
But it also may not be a bad idea to have samsung do it for you, if you'r nervous about it. You did pay good money for the set after all.
tubetwister likes this.
Hisma is online now
post #3172 of 21981 Old 07-18-2014, 01:49 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2038 Post(s)
Liked: 2205
Under normal conditions I do not think the way a unit is carried will cause issues like this. Ya never know for sure though do ya......... Let us know if the buffing helps out.......
Cleveland Plasma is offline
post #3173 of 21981 Old 07-18-2014, 01:52 PM
Roberyu's Avatar
Quoted: 18 Post(s)
Liked: 24
I watch the same scene on my 75" 8550, and it's fine. I'm using the 10/5 motion settings. Perhaps your set is defective.
Roberyu is offline
post #3174 of 21981 Old 07-18-2014, 02:24 PM
baddceo's Avatar
Quoted: 38 Post(s)
Originally Posted by porsche948 View Post
i hear the comment about not being able to stop watching this tv; i too have been taking way too long past my normal my bedtime to re-watch my favorite movies. LOTR extended blu-ray has been a real treat on this monster 75" 8550 on the wall.
couple things, for some reason i decided to name my cable tv input as PC type and now that i realize that there is no reason to have that input named that i can't change it. When i select the source and hold the enter button on the smart remote it only lets me choose edit name which changes the particular naming of my cable service but NOT the input type. I was only able to select this when the input was first set up and i verified this by trying to name an unused hdmi port which had the default ----- for a name. Only then when i selected edit name it let me choose what input type was to be on that input. Other than doing a complete wipe reset of the tv i don't see how i can change the type of input on my cable input from PC to a more appropriate input to get some of my PQ settings back. Thoughts?
Also, just wondering if anyone knows what setting is ultimately the main one responsible for tweaking out the flickering flashlight effect of the balck background when there are white credits on a black screen at the end of a movie. It doesn't bother me that much since when a movie is actually in playback there is enough variation that i can't see any of this, but i am just wondering if anyone knows exactly which PQ setting directly tunes this to soften this effect or accentuate it. Truth is i can live with it since i didn't buy the tv for watching credits.
Last question, everyone cites you need about 20Mbit/s connection to stream 4k but this seems to be a general statement; does anyone have any true info on the status of the download rate on their router while they are streaming 4k through their tv? Are you truly using a full 2.5 Megabytes / second download rate?
Depends on competing priorities at your router. a 1 hour 4k show is probably over 10gig. Guessing it might be larger. I could b way off.
baddceo is offline
post #3175 of 21981 Old 07-18-2014, 02:38 PM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
Starting to think so. I'll have to get in touch with Samsung. Sigh. So much work getting this thing up on the wall. This is the 2nd time I'll have to replace it the first one was totally screwed with a giant band of flickering pixels down the middle.
Ugh.
AVR: Onkyo TX-NR636
Speakers: KEF T205
Phrawst is offline
post #3176 of 21981 Old 07-18-2014, 03:09 PM
JayBizniss's Avatar
Quoted: 67 Post(s)
Posted this in the Sony thread as well.. Curious to everyone's opinion...
Went into Best Buy today set on a the Samsung 8550 and these slick employees got me in front of the 65x850B and damn was I impressed.. They put on the avengers Blu ray on both the 850b and the hu8550 and the colors were much more vibrant on the 850b.. Seemed smoother as well.. I wonder if it's cuz they didn't have the settings right on the samsung or what... They also told me that the sonys handle sports way better than the samsungs? Is this true? I say 90% of my tv viewing is sports.
JayBizniss is offline
post #3177 of 21981 Old 07-18-2014, 03:51 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Here is the pic
You need to play with all 3 dark settings. You have smart led off. That much is clear.
Mrorange303 is offline
post #3178 of 21981 Old 07-18-2014, 03:55 PM
Liked: 355
Depends on how you set up both at home. The sony has awesome motion. But the sammy in no way has less color. At all.
Thats just the settings.
These sets have identical 4k pictures.
Its the other resolutions that matter.
Again motion is great on the sony.
The sammy can have a more punchy picture. You just have to choose to make it that way.
The sony may appear sharper for sports. So that may be the deciding factor there.
post #3179 of 21981 Old 07-18-2014, 03:56 PM
porsche948's Avatar
Quoted: 18 Post(s)
thanks
well at just over 10 gigs that's in the neighborhood of about 2.5 meg/s needed which is a 20 Mbit connection. good to know.
guess i have trully been looking at 1080p streamed signals that the tv then upconverts to pseudo 4k looks; makes sense, but even then it looks remarkable at the upconversion
1080i over cable box doesn't look anywhere near as crazy amazing as the upconverted bluray 1080p or streaming 1080p. wonder why there is so much of a variance there, hard to believe it would all be because of silly archaic cable companies screwing us over with interlaced but that seems to be what makes the most sense.
porsche948 is offline
post #3180 of 21981 Old 07-18-2014, 03:58 PM
JayBizniss's Avatar
Quoted: 67 Post(s)
Is it possible to get the samsung smooth for sports?
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
