OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 4667Likes
post #4051 of 22048 Old 08-15-2014, 01:59 PM
aceiv's Avatar
Quoted: 31 Post(s)
Liked: 42
Volunteer?
Originally Posted by fishairflow View Post
I am getting the 65 inch 8550 delivered and would greatly appreciate any advice on how to check the screen for any defects within the first 30 day return period...
Hi,
I think it would be great if the community put together a quick checklist for newbies on banding and dead pixels (best way to get a full white screen), clouding (microfiber cloth solution), flash lighting and light bleed, Netflix issues, and maybe list a few of the issues that some have faced (screws too tight etc.)
It would need to be someone more knowledgeable than..."I am not a smart man"
Alex
aceiv is offline
post #4052 of 22048 Old 08-15-2014, 06:39 PM
Chad B's Avatar
Quoted: 539 Post(s)
Liked: 1296
Originally Posted by westa6969 View Post
ChadB
Thank you so much for taking the time for the review. However, I'm left sort of confused as to how this TV ranks comparatively with the others you've recently reviewed.
Could you offer up an objective and subjective rating.
I'm certain many may be wondering is the HU9000 incrementally better or equal or worse than the flat HU8500 or if you were buying how would you rank with . . .
Sony 900B/950B
LG 9800
LG OLED
Which panel would make you pull your wallet out if you had a budget for them all? I'm torn between the 75" 8500 vs. the HU9000 78" and not because of the curve but purely is there a difference maker between the two?
4K Feedback
3D Feedback
Love the review but left wondering how these LCD Flagships compare with your wealth of experience and keen eye? THX Chad!
It is awfully close in performance to the HU8550, with very similar panel contrast and color.
Compared to the Sony 900B, which I have calibrated a couple of and hope to write up a short report of soon, the Sony has much higher native panel contrast ratio than the HU9000/HU8550, but worse color.
The one I'd be most excited to pull out my wallet for would be the LG OLED.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #4053 of 22048 Old 08-15-2014, 06:55 PM
Chad B's Avatar
Quoted: 539 Post(s)
Liked: 1296
Originally Posted by jbug View Post
Thanks for the review Chad. It seems like it ended too soon though. Did you edit the tail end? I would also like to know how you ranked the 2014 sets that you recently reviewed. I take it you don't care for 3D as you didn't mention it. I would have liked to compare how bright the new sets are in 3D mode and which one was the brightest. Again, thanks for taking the time to calibrate & post.
I didn't edit the end; I had just spent a long time writing up the review, realized I had conveyed everything in my notes, and decided to call it a day.
My rankings page is up to date except for the HU9000. The link is in my signature.
I'm not a big fan of 3D, as I often get viewing fatigue from it. I do calibrate it for my customers if they are into it, though. I also still get preferences for some set's 3D performance over others, but I usually don't write about them.
To give you a very rough idea of brightness levels, the top plasmas generally get up to around 6.5 fL (Panny 60 series) to 7 or 8 fL (Sammy F8500). Front PJs often only do around 2 or 3 fL. The active 3D LED LCDs generally get up to around 10-17 fL. I just did a Sony 900B today that did 11.4 fL. Passive 3D models can go much brighter. Subjectively, they don't look that dim, but that's what they measure with the glasses turned on and the meter looking though the glasses.
Chad B is offline
post #4054 of 22048 Old 08-15-2014, 08:12 PM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Thought I'd be taking a step back when I broke the screen on my Panny st60 but this tv has been very impressive, see how it handles hockey season... I'm guessing that's when I'll miss the plasma but for tv, Netflix and movies I'm preferring the 8550 over the st60!
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #4055 of 22048 Old 08-15-2014, 10:09 PM
Quoted: 30 Post(s)
im interested in the 8550 but im a gamer and many reviews have the input lag high. Does anyone know if a firmware update has fixed this, if not my choices are the 6950 or the h8000
Bamaboi89 is offline
post #4056 of 22048 Old 08-15-2014, 10:48 PM
Quoted: 164 Post(s)
Is banding normal on the hu8550? Is there a way to fix the banding problem?
metzy25 is offline
post #4057 of 22048 Old 08-15-2014, 11:49 PM
UdoG's Avatar
Quoted: 111 Post(s)
2014 Shootout for Best HD and UHD 4K TV:
http://hdguru.com/2014-shootout-for-...nd/#more-14099
Samsung
UN105S9 curved panel 105-inch 21:9 aspect ratio back-lit LED LCD with local dimming . This is the most expensive model in the competition selling for $120,000
UN78HU9000 curved panel 78-inch edge-lit LED LCD with local dimming
UN85HU8550 flat panel 85-inch LED LCD back-lit with local dimming
Sony
XBR85X950B flat panel 85-inch LED LCD back-lit with local dimming
XBR79X900B flat panel 79-inch edge-it LED LCD with local dimming
Competing HDTV models are
Samsung
PN64F8500 flat panel plasma
KN55S9 curved panel OLED
LG
55EC9300 curved panel OLED
UdoG is offline
post #4058 of 22048 Old 08-16-2014, 07:58 AM
J_Enrikez's Avatar
Just picked up a Sammy HU9000.
anyone have a few links or calibration settings i can start out with before getting a professional to come out hear and set it up correctly for us.
Loving the set...dont be scared my friends...pull that trigger.
added the Oppo BDP103D fo BR and 4K up conversion from STB. so far so good.
Thanks in advance
J_Enrikez is offline
post #4059 of 22048 Old 08-16-2014, 07:59 AM
tontondavid's Avatar
Quoted: 90 Post(s)
Liked: 26
Thanks in advance
What size?
tontondavid is offline
post #4060 of 22048 Old 08-16-2014, 08:05 AM
J_Enrikez's Avatar
78" curved
post #4061 of 22048 Old 08-16-2014, 08:06 AM
Quoted: 90 Post(s)
Liked: 26
78" curved
Nice. Any clouding?
post #4062 of 22048 Old 08-16-2014, 08:09 AM
FirNaTine's Avatar
Originally Posted by viper14 View Post
for the UHD video pack those who received theres how were shipped? fedex,ups,etc.. and was a signature required?
Just got mine the other day. It was shipped UPS and left at the door, no signature required. If you live in a bad neighborhood they won't leave anything at the door I think.
FirNaTine is offline
post #4063 of 22048 Old 08-16-2014, 08:11 AM
J_Enrikez's Avatar
not that i see anything i would call clouding
manufacturer date is June 2014.
is it something is should look out for/ what would i notice...reference pic?
was that mfr date known to have issues?
Calibration settings anyone before i get Bjorns out here...in 2 weeks. sux.
post #4064 of 22048 Old 08-16-2014, 08:20 AM
Quoted: 90 Post(s)
Liked: 26
Actually you may not want to know how to look for it. If you don't see anything, just be happy and enjoy your set.
I had posted calibration of mine I think on page 38.
post #4065 of 22048 Old 08-16-2014, 08:27 AM
J_Enrikez's Avatar
Thanks man...appreciate your help.
good guys here.
je
post #4066 of 22048 Old 08-16-2014, 08:27 AM
Latinoheat's Avatar
Quoted: 1111 Post(s)
Liked: 883
If you can't see any flaws don't go looking for some because you will just find more and kick yourself why you did in the first place. I don't own this set but this is what I have found out from reading other members experiences.
thewayacts92 likes this.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #4067 of 22048 Old 08-16-2014, 08:31 AM
Latinoheat's Avatar
Liked: 883
Samsung
Sony
Samsung
LG
We will find out who's king of kings this year!
post #4068 of 22048 Old 08-16-2014, 09:13 AM
Liked: 0
I have a very simple question.
Yesterday my 8550 65 inch set arrived and it works great.
However, I find that the analog audio out via the stereo mini phone jack at the rear is NOT controlled by the volume adjustment on the 8550's remote. I wish to route the audio to my (nice) stereo system (vintage components). I'm OK with inserting a D to A converter in the output from the 8550's digital audio port but don't know if that port's output level is also fixed in level or if it will respond to the 8550's remote control.
Any advice ... my objective, if I wasn't clear above, is to get stereo audio from the 8550 which varies in amplitude as the volume buttons on the 8550's remote are used.
johnfalc is offline
post #4069 of 22048 Old 08-16-2014, 09:56 AM
J_Enrikez's Avatar
Found these from your post but from an older thread ..hope you dont mind posting them up. if you do i will gladly take them down.
Here are my settings:
Daytime viewing:
Picture mode: standard
Backlight: 14 (you can adjust if in a bright room)
Contrast: 75
Brightness: 51
Sharpness: 35
Color: 48
Tint: g46-r54
Dynamic contrast, black tone: off
Flesh tone: 0
Color space: custom
Red: R70, G0, B1
Green: R0, G57, B4
Blue: R0, G3, B69
Yellow: R49, G52, B2
Cyan: R0, G55, B64
Magenta: R69, G1, B53
White balance:
R offset -3
G offset 0
B offset 2
R gain -1
G gain 0
B gain -5
Gamma -2
Motion lighting off
Color tone: warm 2
Digital clean view, MPEG noise: off
HDMI black level: low
Auto motion: clear
Smart led: low
Cinema black: on
Wow, that was long.
Anyway, I'm still trying to fine tune my setting but that's what it is for daytime viewing. I'll post the nighttime ones once I get it calibrated for night.
Enjoy.
Thanks again. page 28 btw
ref: for HU9000 78"
post #4070 of 22048 Old 08-16-2014, 10:02 AM
Quoted: 90 Post(s)
Liked: 26
ref: for HU9000 78"
No I don't mind sharing.
post #4071 of 22048 Old 08-16-2014, 10:08 AM
thewayacts92's Avatar
Quoted: 96 Post(s)
Liked: 38
True! If you love, just love it and enjoy it!
thewayacts92 is offline
post #4072 of 22048 Old 08-16-2014, 10:25 AM
J_Enrikez's Avatar
one last question...is there ANY WAY to get YouTube app t0 play in HD. I see no settings for changing res to 1080p like on PC YouTube site.
je
post #4073 of 22048 Old 08-16-2014, 10:30 AM
Quoted: 12 Post(s)
Liked: 4
sweet! I should be getting the UHD movie pack on thursday! Any updates on wether we'll be able to download future movies with the free pack?
protopip3 is offline
post #4074 of 22048 Old 08-16-2014, 11:21 AM
rlb
rlb's Avatar
Quoted: 1750 Post(s)
Liked: 1421
Thanks in advance
Experiment before you make up your mind on the 103D for upconversion.
I have the F9000 w/2014 one connect box (same software as is on the UH9000). I also have the 103D (great player) that I used for Darbee and upconversion with the original one connect. With improved upconversion of the 2014 one connect, I now output "native" out of the 103D and do all upconversion in the one connect. However, you could easily prefer outputting 1080P and using Darbee at around something like HD 35. I personally would not output 2160P from the 103D because I believe the F9000 one connect does a better job upconverting from 1080P to 2160P.
Regarding running the STB into the 103D rear HDMI for upconversion and output to the TV. I personally don't think you get an improved upconversion/picture and running everything through the 103D (as a video processor) is a pain compared to running the STB for a "pass through" from the receiver to the HU9000. The 103D takes around 30 seconds to "boot up" and has numerous issues. Plus, assuming your receiver and STB are HDMI 1.3a (or higher), you get automatic lip sync running through the receiver. If you go direct to the HU9000 and use optical digital back to the receiver, you lose auto lip sync. If you use ARC for returning sound from the HU9000 to the receiver, you must deal with ARC "issues". Bottom line: It's so much easier to not use the 103D for STB upconversions; and I seriously doubt you will feel it provides better audio/video.
Asturini likes this.
rlb is online now
post #4075 of 22048 Old 08-16-2014, 11:50 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2457 Post(s)
Liked: 2724
Not without the 65EC9700 OLED in the mix. I would find it hard to believe this unit is not the king . Just not out just yet .
--- Also, the only true FALD set is the XBR-85X950B, the rest are primarily edge lit and a play on words with local dimming.
Cleveland Plasma is offline
post #4076 of 22048 Old 08-16-2014, 01:37 PM
Latinoheat's Avatar
Liked: 883
Ok, let me rephrase that, who will be king of kings for a few days until the EC9700 OLED comes out.
post #4077 of 22048 Old 08-16-2014, 03:09 PM
Liked: 0
Lights on corners
Guys,
Could you verify if yours HU8550 has the white lights at the corners, as these pictures when the room is in darkness:
Asbahl is offline
post #4078 of 22048 Old 08-16-2014, 03:44 PM
Quoted: 90 Post(s)
Liked: 26
Originally Posted by Asbahl View Post
Guys,
I had other issues with mine but this is very distracting.
post #4079 of 22048 Old 08-16-2014, 03:52 PM
doctorwizz's Avatar
Quoted: 735 Post(s)
Liked: 232
Guys,
Is that light leaking from the frame?
Mine is not like that.
doctorwizz is offline
post #4080 of 22048 Old 08-16-2014, 04:23 PM
toomanytvstosee's Avatar
Quoted: 153 Post(s)
Liked: 52
Cant wait to see the results of today's VE shootout
toomanytvstosee is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
