OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 4661Likes
post #4441 of 22026 Old 08-26-2014, 07:39 AM
lvov7342's Avatar
Quoted: 39 Post(s)
Liked: 59
I was looking at the 50HU8550 & the pixel pitch is ridiculously tiny. Almost retina-like
lvov7342 is offline
post #4442 of 22026 Old 08-26-2014, 07:46 AM
hossta's Avatar
Quoted: 37 Post(s)
Hi guys
I don't know if anyone uses the voice commands on these TVs (I don't, except for 3D on/off which is much quicker than having to go through umpteen menus using the standard remote!), but my TV (HU9000) used to recognise free-format random commands like "find me something with Kristin Kreuk" with surprising precision, but recently it will not recognise anything other than pre-programmed commands like "3D on/off", "Volume up/down" etc. For anything else, you get the stupid "I failed to understand what you said"! response!
Does anyone know what could've caused this?
hossta is offline
post #4443 of 22026 Old 08-26-2014, 08:07 AM
Quoted: 22 Post(s)
I have the 75h8550 being delivered in 2 weeks and have a question I couldn't find anywhere: does this tv support external hard drives over 2TB? My current samsung only supports up to 2TB, but I've heard varying responses that 3TB are sometimes recognized.
Pjs06c is offline
post #4444 of 22026 Old 08-26-2014, 08:25 AM
getbigg21's Avatar
Quoted: 91 Post(s)
Originally Posted by Cleveland Plasma View Post
Depends on the viewing distance.......it may be worth it.
I'm about 10 feet away or so.
getbigg21 is offline
post #4445 of 22026 Old 08-26-2014, 08:30 AM
getbigg21's Avatar
Quoted: 91 Post(s)
Originally Posted by Mrorange303 View Post
Yes you will. Can't tou tell the difference on really small tv's with 1080p?
Same principle here the clarity will be nuts.
we have a 40 inch 1080p and a 50 inch 1080p. i can't really tell the different between 720 or 1080 on the 40 inch so that is why i ask.
post #4446 of 22026 Old 08-26-2014, 08:33 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2348 Post(s)
Liked: 2584
That would be a big fat no, on if it is worth it or not for 4K on a 55". Save your cash or go bigger, 65" minimum from that distance......
Cleveland Plasma is offline
post #4447 of 22026 Old 08-26-2014, 08:46 AM
pg_rider's Avatar
Quoted: 75 Post(s)
Liked: 33
Originally Posted by danielb6752 View Post
... I need a 90 degree adapter to use the rear-facing ARC-enabled HDMI input. Damn you, Samsung, for making this critical HDMI port rear-facing!
No kidding? The ARC input requires the HDMI cable to stick out perpendicular from the back of the TV? That sucks.... guess I'll be buying a 90° adapter as well before I buy the TV.
LSA One Monitors, LSA LCR Center, LSA On Wall surrounds, dual Hsu VTF-3 subs, Denon AVR-X4000, Adcom GFA-6000 amp, UTurn Orbit turntable, Samsung UN75HU8550
pg_rider is offline
post #4448 of 22026 Old 08-26-2014, 08:48 AM
Quoted: 22 Post(s)
Liked: 6
Calibration Service
Ok so I have my 100 hours in of viewing my 8550. I am taking everyone's advice and having my set professionally calibrated. Can anyone recommend a good calibration service in North New Jersey?
Amurphy is offline
post #4449 of 22026 Old 08-26-2014, 08:50 AM
danielb6752's Avatar
Quoted: 25 Post(s)
Liked: 30
Yeah - HD Guru's review of the 55" model has a picture of the rear of the TV. The manual also indirectly shows this as a flat HDMI jack, versus side-facing HDMI jacks for the other inputs (like MHL).
danielb6752 is offline
post #4450 of 22026 Old 08-26-2014, 08:51 AM
Doug Brown's Avatar
Is anyone else having problems accessing Netflix since the last software upgrade? My screen goes black and my remotes stop working. I have to turn the TV off and then back on again in order to get back to my cable TV channels. I reset the Smart Hub, but that didn't seem to help. Any ideas? I have a 75" 8550.
Doug Brown
Doug Brown is offline
post #4451 of 22026 Old 08-26-2014, 09:01 AM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
That's not what I mean. I mean like a 20" tv with 240hz 1080p.
It would look like that. If you ever seen one of those little tv's they can be freakishly good.
That being said you can see a difference on a 55" tv at 9' away with 20/20 vision.
That means slightly more crisp and better color.
10' away things sharply begin to change. You would need to go bigger as you go back. About 10" difference for every 5' away you move. I'd not sit more than 15' from a tv. Unless it's the 120".
At some point it's all the same. The. You get into projectors.
The color benefit would still be visible. 4k projectors too.
The 4k resolution stops 13 to 14' to me on my 65".
My eye sight is 20/15.
Mrorange303 is offline
post #4452 of 22026 Old 08-26-2014, 09:33 AM
hossta's Avatar
Quoted: 37 Post(s)
I had the same problem, it happens if you do not exit Netflix properly, i.e you have to click on "Exit Netf;lix", rather than just using the remote's exit button like with other apps. When it happens, the only way to fix it is doing a Factory Reset. Go to Support Menu -> Self Diagnosis -> Reset.
Once its fixed make sure you always exit Netflix properly.
hossta is offline
post #4453 of 22026 Old 08-26-2014, 09:35 AM
pg_rider's Avatar
Quoted: 75 Post(s)
Liked: 33
Wow, same for the Cat 5 connection... that sucks!
pg_rider is offline
post #4454 of 22026 Old 08-26-2014, 09:41 AM
getbigg21's Avatar
Quoted: 91 Post(s)
yeah that is what i was thinking. that's why i mentioned just a nice 1080p set. i was looking at the H8000 but also the H7150 peaked my interest.
post #4455 of 22026 Old 08-26-2014, 09:42 AM
getbigg21's Avatar
Quoted: 91 Post(s)
yeah so probably would be best with a 65 inch at that distance.
post #4456 of 22026 Old 08-26-2014, 10:17 AM
Quoted: 146 Post(s)
Like this
My clouding is pretty good, can't really see anything once the TV is doing is this.
I have a thin band about a foot from the left, that is only visible on dark grey scenes.
How do I reproduce this solid grey screen so I can confirm what I'm seeing?
yosM45 is offline
post #4457 of 22026 Old 08-26-2014, 10:22 AM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
I suspect if you contact Chad who did the reviews posted here he tours NJ on a recurring basis. Give it a try.
BTW, does anyone know if the 100 hour break-in is actually relevant for LCD screens? That's a legacy of plasma when it took a while for the plasma gases to settle. I'm not sure why it would technically matter for LCD but perhaps there's a reason I haven't heard of.
Amurphy likes this.
Citivas is offline
post #4458 of 22026 Old 08-26-2014, 10:34 AM
Toadus's Avatar
Quoted: 58 Post(s)
Hey guys
Quick question. I took the picture below in one of the setup menus, in this case, the Universal Remote Setup, as these menus have a dark'ish grey colour and help to show up any screen uniformity issues.
I took this picture in Movie mode, with most settings not far from their standard, and backlight on 11. I just want to know if this is fairly par for the course so to speak, or whether it's something I should be concerned with? Notice the top middle and bottom right areas which seem to be a fair amount brighter than anywhere else. Also, there's a faint horizontal bar running through the 'TV' word in the part of the sentence "Samsung TV remote." Also, slightly purple shade noticed on the right side.
What do you think?
Toadus is offline
post #4459 of 22026 Old 08-26-2014, 11:23 AM
Chris J's Avatar
Quoted: 72 Post(s)
Liked: 33
Do you guys remember VOOM? We need something for 4K streaming like Voom did for HD....
Chris J is offline
post #4460 of 22026 Old 08-26-2014, 01:02 PM
Liked: 355
I use youtube. Grey screen test. Red screen test. Etc.
yosM45 likes this.
post #4461 of 22026 Old 08-26-2014, 01:08 PM
Liked: 355
Originally Posted by Toadus View Post
Hey guys
What do you think?
Is just the menu design. My set has the exact same.pattern in the exact same spots. No issue at all.
post #4462 of 22026 Old 08-26-2014, 04:38 PM
rdewey's Avatar
Correct. I bought the 50 inch 8550 and it is a giant retina display if you sit close. Do not test this with 1080p material but get the demos linked earlier that were encoded in UHD. They are incredible. I don't have a 4K video card but when using this as a giant monitor at 1080p from my Mac Pro, you cannot see any pixel elements from 3 feet in front of the screen. In my view, if you sit close to the TV, the smaller the screen size the better for achieving a "retina display" effect.
rdewey is offline
post #4463 of 22026 Old 08-26-2014, 04:41 PM
rdewey's Avatar
FYI this is an incredible deal on a Samsung bluetooth sound bar that works great with this TV connected via Samsung's proprietary bluetooth format. I showed the ad at Fry's and they matched the price...
http://www.samsung.com/us/video/home-audio/HW-F355/ZA
rdewey is offline
post #4464 of 22026 Old 08-26-2014, 11:06 PM
Toadus's Avatar
Quoted: 58 Post(s)
OK, thanks a lot!
I just want to make sure I'm not being too picky that's all. I've been on plasma for the last 6 years, so possibly I've gotten used to the perfect screen uniformity they offer. These two areas of the screen that I mention do crop up outside of the test screen though. Most noticeably the far right side, not specifically the bottom part, the whole area on the right. It discolours a little, so you can see a change in flesh tones sometimes, or just a general increase in brightness with certain colours. The area towards the top sometimes causes a noticeable dirty screen effect. If this is all normal for this set then that's fine. But I just wanted to know because if it's not, then I'd like to do something about it.
Toadus is offline
post #4465 of 22026 Old 08-26-2014, 11:41 PM
Toadus's Avatar
Quoted: 58 Post(s)
I must add... It sounds like I'm really moaning about this TV. Just want to make it clear, I love this TV! Just trying to put to rest my only concerns
Toadus is offline
post #4466 of 22026 Old 08-27-2014, 04:15 AM
Stickman1975's Avatar
Quoted: 22 Post(s)
Originally Posted by SANdood View Post
FWIW, it comes with the required cable - if you want to install a USB3 extension cable, it would look like the one in your Example 1.
Thank you
Stickman1975 is offline
post #4467 of 22026 Old 08-27-2014, 08:03 AM
Industry Insider
Liked: 2584
I love a our Sharp 80" unit from 11FT
post #4468 of 22026 Old 08-27-2014, 08:13 AM
Liked: 355
Agreed. If you go 1080p go 80" q+.
post #4469 of 22026 Old 08-27-2014, 09:26 AM
getbigg21's Avatar
Quoted: 91 Post(s)
which one do you have?
post #4470 of 22026 Old 08-27-2014, 09:43 AM
bcec's Avatar
Quoted: 200 Post(s)
Liked: 102
85hu8550 panel type
So I just did the online chat thing with 3 Samsung representatives and asked whether 85hu8550 has 8-bit or 10-bit panel.
1st representative: The TV 85hu8550 has 10-bit panel.
2nd representative: UN85HU8550FXZA has 8-bit panel. (this person was the most confused about the whole concept)
3rd representative: TV UN85HU8550FXZA has 10-bit Ultra-Clear panel.
What gives?
bcec is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
