OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 181 - AVS Forum | Home Theater Discussions And Reviews
 4657Likes
post #5401 of 22009 Old 09-23-2014, 09:56 AM
rx3
rx3's Avatar
Quoted: 82 Post(s)
Originally Posted by pg_rider View Post
Just ordered a 75" 8550 from Cleveland Plasma, so now the waiting begins!
Word of warning -- I went through absolute hell with my credit card company (Capital One) trying to complete the transaction, through no fault of Cleveland Plasma. If you order a TV using your Capital One credit card I suggest first calling their fraud department to let them know the charge is coming, then 3-way call Chris at CP and do the transaction real-time to make sure it goes through.
This is exactly why I cancelled my Capital One card years ago. It was embarrassing at the checkout lines every time they refused the transaction.
rx3 is offline
post #5402 of 22009 Old 09-23-2014, 10:50 AM
grizzledbiker's Avatar
Quoted: 2886 Post(s)
Liked: 1328
It's an understandable safeguard. Large unusual and out of state transactions are always scrutinized. I'm glad they're watching.
sent via HTC ONE M7
grizzledbiker is offline
post #5403 of 22009 Old 09-23-2014, 10:52 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2275 Post(s)
Liked: 2488
Declined cards Seams to happen more and more on high ticket items. The new credit card issues seemed to trigger some new alcra rhythms they say that leads to new declines.
MatiPlaneteer likes this.
Cleveland Plasma is offline
post #5404 of 22009 Old 09-23-2014, 11:53 AM
pg_rider's Avatar
Quoted: 75 Post(s)
Liked: 33
Originally Posted by pilotart View Post
My user manual makes a point about a special "Wall Mount Adapter" that is provided with the 75" model.
I also think it would need to consider the washer and thickness of the VESA Bracket, perhaps their "C (mm)" length is for below the bracket's face... Such a critical factor for the installation to not drop or damage the TV.
There was a Review on Amazon that said finding the correct length 8M's was difficult and he finally found them at ACE Hardware.
I must say this is all a bit disconcerting, but hopefully much ado about nothing. Can anyone confirm whether or not the 75" 8550 can be mounted with any old wall mount and not require additional hardware?
I bought a typical slim mount from Monoprice that seems very straightforward. Per the manual that comes with the mount, it looks like I'll want to use the included plastic spacers:
If anyone has mounted the 75" with a non-Samsung mount, please chime in!
LSA One Monitors, LSA LCR Center, LSA On Wall surrounds, dual Hsu VTF-3 subs, Denon AVR-X4000, Adcom GFA-6000 amp, UTurn Orbit turntable, Samsung UN75HU8550
pg_rider is offline
post #5405 of 22009 Old 09-23-2014, 12:05 PM
sikclown's Avatar
Quoted: 1388 Post(s)
Liked: 702
Originally Posted by Pendragon2014 View Post
Thanks for the heads up, I thought that was what the ARC option was supposed to fix, I guess I will rethink it, worst case I can enable the lipsync on the Onkyo and adjust accordingly once I see if there it any delay caused by the Quad core processor
Don't worry about lip sync issues. Your AVR has the ability to correct that. In order to get the best sound, run everything through your receiver and then Connect it to the ARC port on the One Connect. Test that out (some people have issues with ARC disconnecting) and if you are having issues getting sound from TV Apps just run an optical cable from the TV out to the Receiver optical in for the Apps.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #5406 of 22009 Old 09-23-2014, 12:05 PM
WheelHoss1's Avatar
Quoted: 171 Post(s)
Liked: 74
So, I wanted to comment a little on my set. I had one primary reservation about my 8550 (and the 9000) after having it home for a few days, and though I still think this factor is an issue, it seems to be getting better.
I was hesitant about bringing this up, because I didn't want rain on anyone's parade. But when I first got the 8550 home, the set just looked a little more LCD-like and washed out than it had in the store. I could tell because when I would watch the same program on both my 8550 and my good old LNA650, the 650 had better flesh tones (something else I've heard people say). I wondered if this had to do with not having Pur Color, but when I went back to Best Buy, I noticed the same issue with the 9000.
So, I tried really hard to look at all factors, and here's what I came up with: I feel like the Gorilla Glass they use isn't as thick as it used to be, resulting in a brighter but also a less inky image. In terms of the glass, this is a fact. I can just feel that the 650 has a thicker Ultra Clear Panel. It seems that they are building these TVs lighter (and maybe a little cheaper) than they used to. Even the plastic on the back seems less sturdy on the 8550. When I plugged in a stereo cable to connect my TV's sound to my sound bar, it felt like the back was flimsy plastic compared to the sturdy plastic on the back of the 650. The build feeling slighter may also be a result of making these TVs thinner and thinner, which is obviously a positive.
But, I'm happy to report that the 8550 has started to look more like the 650 in terms of color saturation. It still isn't as rich with flesh tones, but it's damn close, and with the huge difference in detail, the 8550 now blows away the 650. The thing is, it didn't right out of the box. My fiancé actually liked the 650 better until the last few days.
Thoughts?
Samsung UN60HU8550
Samsung LN46A650
WheelHoss1 is offline
post #5407 of 22009 Old 09-23-2014, 12:05 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
I am awaiting my order of the SS UN50UD8550 from BB (since Amazon does not ship to Hawaii) ...
A couple of questions...
I see that a number of people are having issues with the newer firmwares. Do you recommend not upgrading the firmware? What are the advantages/disadvantages of this?
Do you enable the clear motion function? If so, what is the best setting?
What about the backlight level?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #5408 of 22009 Old 09-23-2014, 12:09 PM
rlb
rlb's Avatar
Quoted: 1739 Post(s)
Liked: 1403
Originally Posted by thebignewt View Post
I don't know what the "one connect box" is. But you should connect all the stuff (BD, Cablebox, Direct V box, AppleTV, whatever) directly to the AVR and the AVR to the ARC HDMI on the TV. Don't sweat lip synch, that can be adjusted if needed. Lip synch is overrated IMO.
It is "overrated" if you are using HDMI and all your components are HDMI 1.3a or above. In that case, it's automatic lip sync (the display "tells" the AVR it's standard video processing time--which the AVR adjusts for and normally gets you close enough that you don't notice any problems).
rlb is offline
post #5409 of 22009 Old 09-23-2014, 12:24 PM
jasonjm's Avatar
AU panel worth it to save 33%?
buying this TV and according to seller
Hu8550 in 55 inch
AU panel is $1400
TH whatever panel is $2100
that is a major price difference.
I am tempted to buy at $1400, and I would be happy if the tv at $1400 is 90% as good as the $2100 panel one
any comments or insights? I searched for hours on google but the threads are too messy to find any real info.
jasonjm is offline
post #5410 of 22009 Old 09-23-2014, 12:44 PM
rx3
rx3's Avatar
Quoted: 82 Post(s)
sent via HTC ONE M7
Disagree. Capital One's "safeguards" are way too aggressive. Been with Wells Fargo since I cancelled Capital One and they are nowhere near as bad. When I complained to the Capital One rep, they agreed and said they were working with their security department to lighten up their security software that automatically declines transactions.
rx3 is offline
post #5411 of 22009 Old 09-23-2014, 01:43 PM
Quoted: 13 Post(s)
Liked: 1
Thanks that was going to be my next question if the one connect box doesn't support 5.1 or 7.1 how do you get Dolby from Netflix and Amazon, but optical will work
Pendragon2014 is offline
post #5412 of 22009 Old 09-23-2014, 01:46 PM
Quoted: 13 Post(s)
Liked: 1
I'm thinking that I can get rid of my DVDO Iscan duo that I purchased for my HD projector a couple of years ago, I doubt that I will need it
post #5413 of 22009 Old 09-23-2014, 01:46 PM
x3sphere's Avatar
Quoted: 222 Post(s)
Liked: 129
Cable length seems to be a factor when passing HDMI 2.0 video signal at 60Hz. With a 25ft cable (Amazon Basic brand - rated for 3D), I was getting small white sparkle effects on the screen. Was very subtle, didn't notice until I brought up a fully black BG.
I tried another cable - same brand but 15ft, and the sparkle effect was gone. Maybe there are better quality cables that would work at 25ft+, not sure, but just throwing this out there.
x3sphere is offline
post #5414 of 22009 Old 09-23-2014, 02:03 PM
sikclown's Avatar
Liked: 702
Ok here is where most people get confused:
Using ARC to provide sound from TV Apps you will receive Dolby Digital 5.1/Dolby Digital Plus or DTS 5.1 depending on the App and your selection in the Sound Menu. Optical is capable of the same (I believe, there are varying opinions on ARC vs Optical) although I am not sure about the DD+ part on that one.
Now if you have the TV set to PCM or DTS Neo2.5 it will only output 2 channels audio so you defnitely want to make sure you choose Dolby or DTS when they aren't greyed out in the Sound menu. Once you choose Dolby once in the Sound menu in an App it should remember your choose the next time.
Last but definitely not least, if you do plug your Bluray player into the Once Connect you will only ever get Stereo sound as the TV cannot pass through 5.1 or 7.1 sound from an HDMI Device, only 2.0. If you absolutely had to have it plugged into your TV I would run an optical cable from your Bluray player to your receiver to get better sound but HDMI carries the best sound.
Toadus likes this.
sikclown is offline
post #5415 of 22009 Old 09-23-2014, 02:05 PM
sikclown's Avatar
Liked: 702
For longer cable runs you would want to look into a cable with Redmere Tech built in.
sikclown is offline
post #5416 of 22009 Old 09-23-2014, 02:06 PM
pilotart's Avatar
Quoted: 427 Post(s)
Liked: 299
Hu8550 in 55 inch
AU panel is $1400
Google your "Seller".
It looks like a Classic "Bait and Switch" they're trying to pull on you, Low Ball you with a 'too-good-to-be-true' price and then have one of their 'experts' up-sell you.
The price controls apply to "Advertised Prices" and You can "Deal" with one of the Reputable Dealers like Cleveland Plasma, who happens to be a sponsor of this forum.
I wish you the best of luck.
pilotart is offline
post #5417 of 22009 Old 09-23-2014, 02:10 PM
sikclown's Avatar
Liked: 702
Yeah I doubt you would need it as well. Projectors can be a pain in the rear with lip sync/lag issues.
sikclown is offline
post #5418 of 22009 Old 09-23-2014, 02:40 PM
jasonjm's Avatar
yeah that occurred to me
If i have to pay $2100 or whatever I would just walk into best buy, no way I would agree to be "upsold"
thx
jasonjm is offline
post #5419 of 22009 Old 09-23-2014, 03:30 PM
thewayacts92's Avatar
Quoted: 96 Post(s)
Liked: 38
Thoughts?
May be. I know my C8000 was aluminum or some kind of metal on the back and not plastic.
thewayacts92 is offline
post #5420 of 22009 Old 09-23-2014, 06:06 PM
Quoted: 13 Post(s)
Liked: 1
I originally purchased it for its upscalling capabilities and the fact that I had total control over the gamma, brightness and contrast settings, I think the HU9000 will be a quantum step forward for me
post #5421 of 22009 Old 09-23-2014, 06:14 PM
Quoted: 13 Post(s)
Liked: 1
My reasoning for plugging the Bluray into the one connect is two fold, firstly I should be able to control the BR from the tv and visa versa since the BR is a Samsung BD-F7500, I had also read somewhere that there is something strange that happens between the 9000 series and the F7500 both of which can perform upscaling to 4K apparently the resulting image from the combination is better than either one separately, I have no idea why or how, but since I had planned to purchase a new Bluray anyway I figured I could do worse than going for the combination of the two. I will take your advice and connect the BR to the AVR via an optical cable or by HDMI from the second output port on the 7500
post #5422 of 22009 Old 09-23-2014, 07:03 PM
sikclown's Avatar
Liked: 702
Definitely use the 2nd HDMI port for sound if your Bluray has it. As for the Bluray and 9000 upscaling at the same time, it doesn't work that way. If the Bluray upscaled it to 4k then the TV is receiving a 4K image and it does no upscaling (because none needs to be done, it is already 4k).
Toadus likes this.
sikclown is offline
post #5423 of 22009 Old 09-23-2014, 07:14 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
If you use SoundConnect to pass sound from the 9000 to a compatible Samsung sound bar, does it pass full Dolby Digital or DTS or does it only pass 2.0 like HDMI? And does using Optical pass full Dolby or DTS?
Citivas is offline
post #5424 of 22009 Old 09-23-2014, 07:23 PM
Quoted: 13 Post(s)
Liked: 1
In that case I'll turn off the upscaling on the BR and let the 9000 do its best, I cant imagine a $200 BR doing a better job of upscaling than an $8000 TV
Toadus likes this.
post #5425 of 22009 Old 09-23-2014, 07:45 PM
sikclown's Avatar
Liked: 702
Not 100% sure on this but isn't Bluetooth Stereo only? SoundConnect is just Bluetooth so I think the restrictions apply. Most soundbars usually just attempt to simulate 5.1 anyway.
sikclown is offline
post #5426 of 22009 Old 09-23-2014, 08:04 PM
david(dallas)'s Avatar
Quoted: 135 Post(s)
Liked: 41
Hu8550 in 55 inch
AU panel is $1400
Forgive my ignorance, what is a "AU" and "TH" panel?
david(dallas) is offline
post #5427 of 22009 Old 09-23-2014, 08:18 PM
Quoted: 47 Post(s)
Liked: 5
I have a few of curious questions to ask.
1) right now I am currently running my cable through the ANT and was just wondering if I would get any better performances through a STB box with HDMI outputs? If so are there any recommendations for a good one that has a built in PVR?
2) I am having my tv replaced on thursday due to updating issues and I know updates are model specific and was wondering what firmware are other 50 in. HU8550 owners are currently on?
Any info is greatly appreciated. Thank you in advance.
gosse7dn is offline
post #5428 of 22009 Old 09-23-2014, 08:25 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Is the ts01 panel still considered the best version of the 8550? Or even better than any other?
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
post #5429 of 22009 Old 09-24-2014, 02:01 AM
Liked: 1328
Thoughts?
I agree there was nothing wrong with my LNA750. Still a great picture. (and at times prefer it and my smaller Haier over the 9000) I certainly do not need another television. But I wanted one and am enjoying it. But it takes up too much precious time. And none of my very important chores are getting done. It's like a drug and I do not have the willpower to resist sitting on my ass in front of it. No self discipline. Once I plop myself down on the couch after work, that's it, I ain't moving for the next five hours. Is there help for me?
post #5430 of 22009 Old 09-24-2014, 06:16 AM
rlb
rlb's Avatar
Liked: 1403
Thoughts?
Those issues are mostly a factor of how the displays are calibrated. You can't accurately compare two sets unless they are calibrated to the same specs by a professional. Any display can be calibrated to look "horrible". However, even someone with a "little" knowledge can use a calibration disk and adjust the user settings in a couple minutes to a point where you would think it was very good picture and probably even a totally different set.
rlb is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
