OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 4650Likes
post #1201 of 21967 Old 05-11-2014, 11:58 PM
Mike3010's Avatar
Originally Posted by jimbotron
Even in dark environments, I don't like Movie mode. It gives the screen a 'foggy' grayish look. No matter how much I adjust the colors and white balance, the colors seem muted and cloudy.
Are you viewing the screen at an angle? What does it look like when you are square on?
Mike3010 is offline
post #1202 of 21967 Old 05-12-2014, 12:22 AM
jimbotron's Avatar
No, it's dead on from about 7 feet back. I like the black level in Natural, so I'll stick with it.
I've also found I need to set the audio to a 60ms delay. I thought maybe it was because of passing the video through an AVR, but the gap exists even when I plug my BD player directly into the TV.
jimbotron is offline
post #1203 of 21967 Old 05-12-2014, 12:29 AM
CBdicX's Avatar
Quoted: 1095 Post(s)
Liked: 221
Hi Jimbotron,
thanks for this setup list, i only prever color at Cool and like you i like Natural ;-)
I will try this setting and see if this will change also the motion hickup the tv has sometimes.
Thx.....
CBdicX is offline
post #1204 of 21967 Old 05-12-2014, 01:06 AM
Ahzari's Avatar
Quoted: 52 Post(s)
Liked: 50
Originally Posted by CBdicX View Post
Hi Jimbotron,
Thx.....
ditto i prefer the natural setting with some adjustments over the movie mode, which seems a bit dull and lifeless..
Audio: Yamaha A-S1000 Stereo Amp // Kef LS50s // Dual JL Audio e112
Analog:Pro-Ject RM5.1SE Turntable // Pro-Ject Tube Box II SE Phono Amp // Pro-ject Speed Box II
Video: Samsung 65' HU9000 UHD // Oppo BDP-105 // Apple TV (4G - 64gb)
Power: Furman PST-8 AC Power Conditioner
Ahzari is offline
post #1205 of 21967 Old 05-12-2014, 03:46 AM
teerexx52's Avatar
I have a new 55" HU8550.  Netflix has been giving me problems.  I get a message that says that it cannot play the content and to try again later.  After several calls to Samsung and chats with tech they can get it to work for a bit but ultimately it goes back to the same message. My connection tests out fine and Netflix works fine on my Apple TV. Has anyone found a way to fix this?  Thank you
teerexx52 is offline
post #1206 of 21967 Old 05-12-2014, 04:11 AM
BBBB1111's Avatar
 Netflix Broadcasting 60 fps streams along with 10-bit color
But how Samsung HU9000 with 8 BIT Panel  broadcast  10 bit color?
the company has stated that it will eventually support 60 fps streams along with 10-bit color."
http://hdguru.com/4k-content-a-status-report/
BBBB1111 is offline
post #1207 of 21967 Old 05-12-2014, 05:50 AM
Mattopotamus's Avatar
Quoted: 1458 Post(s)
Liked: 1103
B.c netflix supports more than just samsung. Other panels with 10+ bit will take advantage.
Mattopotamus is offline
post #1208 of 21967 Old 05-12-2014, 06:03 AM
BBBB1111's Avatar
I did not understand what the connection to my question?
Stupid thing to buy screen that no gives me the color of UHD
PANEL 1080P provides me 10 BIT and UHD no ?
this stupid Why buy UHD?
 panel Samsung not  quality  enough
BBBB1111 is offline
post #1209 of 21967 Old 05-12-2014, 06:42 AM
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
Let me guess that samsung or netflix have never heard of this problem?
My 8550 was doing the same along with amazon prime. After a couple of resets it seems to have gone away..........for the moment anyway.
tigerfan33 is offline
post #1210 of 21967 Old 05-12-2014, 07:09 AM
GerryWaz's Avatar
Quoted: 25 Post(s)
New review of the HU9000. Includes their calibration settings.
Note: Reviewer is not a big fan of curved panels.
GerryWaz is offline
post #1211 of 21967 Old 05-12-2014, 08:34 AM
rgg14's Avatar
I need help my 65HU9000 is set with my receiver and the settings for audio are "receiver" the problem is that every time I turn my TV on the settings changed to TV speakers so I have to go to settings and changed again to receiver. Samsung service just told me that is normal that a Samsung TV has to be change to external sound every single time you turn it on. This is my fist TV Samsung, perhaps the last, I can't stand this is stupid. Settings must remain in the way the OWNER want it.
rgg14 is offline
post #1212 of 21967 Old 05-12-2014, 08:39 AM
doctorwizz's Avatar
Quoted: 720 Post(s)
Liked: 215
Menu, system, scroll to Anynet+ (HDMI-CEC). Turn Anynet off.
doctorwizz is offline
post #1213 of 21967 Old 05-12-2014, 08:41 AM
doctorwizz's Avatar
Quoted: 720 Post(s)
Liked: 215
Also press tools button and make sure it is set to audio out.
post #1214 of 21967 Old 05-12-2014, 09:13 AM
rgg14's Avatar
If I turn Anynet off ARC don't work and the audio from Netflix is gone. I checked in tools set to audio out and set to receiver.
rgg14 is offline
post #1215 of 21967 Old 05-12-2014, 09:17 AM
doctorwizz's Avatar
Quoted: 720 Post(s)
Liked: 215
Its the only way I know to fix it.
You could use an optical for the apps. I do. You lose DD+ on NF. You would only get DD.
post #1216 of 21967 Old 05-12-2014, 09:56 AM
Lostonmountain's Avatar
Quoted: 41 Post(s)
Liked: 32
I presume they do this to reduce the number of  "I can't hear my TV" complaints.  It would be nice if they had an extra "leave it this way" option instead of this annoyance.  Guess I'll just use the apps on my PS4 (but I can't stream 4k so it doesn't matter not getting it from the TV).
One thought: get a universal remote that can be set to send the codes to switch the audio every time you turn the TV on.  Would need a blue-tooth like a Logitech (though I understand some of these TV's come with an a second remote if it's an IR remote  any programmable remote should work like a Universal RF-20).
Lostonmountain is offline
post #1217 of 21967 Old 05-12-2014, 10:52 AM
twssas's Avatar
Quoted: 31 Post(s)
Liked: 24
I have the 65 inch 8550, and really impressed with a number of its attributes.....I have been playing with it a couple days now, and really struggling with the auto motion plus.....example: watching a recorded version of the new season of 24 the other night.....lots of fast action, my eyes just could not keep up...looked very jerky, and lots of soap opera effect. played with the settings didnt seem to change much.....example 2: was watching a live broadcast of a bicycle race on NBC sports....as the bikes went by the trees, the trees looked blurred, and sometimes the faces of the riders were blurred as well.
On the other hand, was watching dirt bike racing (looking for something with fast action), it seemed to be ok......NBA basketball game looked good....and then watched Amazing Race last night on clear setting, it seemed to be ok....
Net results are all over the place, and I really want to like this set, so I am wondering what the general consensus is with regard to auto motion plus......and by the way I do not game with TV so those issues dont effect me.
OFF
Clear
Standard
Smoothing
Custom (if so what settings?)
LED motion plus setting?
I have read these threads, and saw that some folks disabled digital clean view and mpeg noise filter. Sharpness at zero. and then custom with blur only (dont know which setting), while others have different values. I know this is a personal thing....but looking for a bit of guidance.....
Lip sync, tv through cable is good, blu ray is good, net flix house of cards not so good.....and guidance on adjustments for netflix?
twssas is offline
post #1218 of 21967 Old 05-12-2014, 11:10 AM
doctorwizz's Avatar
Quoted: 720 Post(s)
Liked: 215
I think the best results for auto motion plus settings are: Custom, Blur reduction - 10 Judder Reduction 10. The other motion settings don't seem to do enough.
LED motion plus off. That makes a lot of flicker. Not watchable.
And if you are not used to it, you may get the soap opera effect. I got that at first, but I am used to it now. And I love it. This is my 3d week with the 65" 8550.
The only thing that I don't like is some facial judder in 24P Blurays. It is not the whole frame that judders, just a face when it turns or moves fast. I don't know if judder is the correct term. I don't notice it on DishTV yet. I don't watch much TV.
It seems like it happens when you see a face blur when you do a frame by frame. I was trying to figure out what causes it by doing slow motion and frame by frame.
It's just minor annoyance to me.
Edit:
Setting judder to zero seems to have got rid of the facial artifacts.
post #1219 of 21967 Old 05-12-2014, 11:52 AM
jimbotron's Avatar
Hi Jimbotron,
Thx.....
I tried Cool for a little bit, but given how so much material has that teal/orange push, many movies don't need any help in that department. I just switched to Warm1, and if I like it, I'll stay there.
post #1220 of 21967 Old 05-12-2014, 11:55 AM
jimbotron's Avatar
I'm on the fence about LED Motion Plus. The only difference I see is that it makes the screen darker. When it's off, I do set Blur Reduction to 10, however Judder Reduction is 0 because it creates the soap opera effect. I occasionally switch it to 10 to show others how much it messes up movies. smile.gif I want movies to retain that 23.976 look. However at the same time, I want baseball games to not have any blurring or strobing.
post #1221 of 21967 Old 05-12-2014, 12:37 PM
x3sphere's Avatar
Quoted: 222 Post(s)
Liked: 129
For movies/TV, I agree. That said LED Motion Plus seems to help a great deal with blurring in fast motion games, almost completely eliminates it. The option isn't available with the input renamed to PC unfortunately though so there is a tradeoff between that and higher input lag.
x3sphere is offline
post #1222 of 21967 Old 05-12-2014, 12:53 PM
jimbotron's Avatar
Right now I have everything going through my AVR, so everything is plugged into HDMI1. I suppose I'll give my BD player a separate input, and put everything else to HDMI2 with the same settings, but with anti-judder on.
I haven't really looked at the anti-judder feature for video games yet. If it can make 30fps games look like 60fps without looking unnatural, I'm all for that.
So switching the input name to PC removes lag? Is that better or worse than turning on Game Mode? I set an input to PC mode once when using BD/cable, but the TV knew if it wasn't receiving a PC signal, so it was set back to Natural/Movie without any decrease in lag.
post #1223 of 21967 Old 05-12-2014, 01:08 PM
Pxtreme's Avatar
Hi there
In the UK I had trouble with the motion plus settings, the best way to solve the problem is to switch game mode on (if you can). You do loose some options and you are stuck with standard picture mode but it works a charm
Pxtreme is offline
post #1224 of 21967 Old 05-12-2014, 01:09 PM
x3sphere's Avatar
Quoted: 222 Post(s)
Liked: 129
Well, turning the anti-judder up for 30FPS games doesn't work too well, introduces a lot of motion artifacts (you can usually see a blurry outline on anything that is moving). But the judder settings are disabled anyway when LED Clear Motion is on.
Also yeah, input renamed to PC offers the lowest input lag in my experience. A few more settings are disabled with the PC input like Smart LED, but can't say I noticed much of a PQ difference over Game once the brightness, contrast etc values were properly tuned.
x3sphere is offline
post #1225 of 21967 Old 05-12-2014, 01:13 PM
teerexx52's Avatar
Actually Netflix spent tons of time with me trying to fix the problem.  Ultimately a reset has worked so far.  Not sure if it will last or not.
post #1226 of 21967 Old 05-12-2014, 01:17 PM
Pxtreme's Avatar
Originally Posted by Pxtreme View Post
Hi there
Sorry, new to the forums, what I was trying to say was I use game mode for all my sources, including my cable tv box. It stops almost all motion judder. It does limit some of the picture settings but stops the judder, for example on the ticker on a sports channel, fast moving movies, football (soccer!) etc.
Pxtreme is offline
post #1227 of 21967 Old 05-12-2014, 02:23 PM
twssas's Avatar
Quoted: 31 Post(s)
Liked: 24
I looked, but could not find the game mode
twssas is offline
post #1228 of 21967 Old 05-12-2014, 02:31 PM
Pxtreme's Avatar
Menu>system>general>game mode
Don't know why they hide it !
Pxtreme is offline
post #1229 of 21967 Old 05-12-2014, 02:40 PM
Liked: 1103
I may be wrong, but I think game mode severely hurts Picture quality.
post #1230 of 21967 Old 05-12-2014, 02:40 PM
tl2k2's Avatar
Quoted: 45 Post(s)
Liked: 38
i want to share my experience about the input lag with who care about this issue, when i first bought this tv i tried game mode and also rename my input to game though i didn't notice any significant lag but its does lag a little compare to my previous tv "d8000". but after the may 8 firmware, at first its still the same but then i reset the tv then use same setting again i noticed the input lag is way better, i fell like its the same with my previous tv.
TV: UN65HU9000FX/ZA TS01 Panel W/OCB 3500U/ZA | Receiver: AVR-X7200WA | Speakers: B&W CM10 S2 |Wirings: All Audioquest Carbon HDMI and Speaker wire Audioquest Castlerock Bi-amp wires with dbs v.72
Harmony Ultimate Remote | Media Player Intel NUC5i7 With Openelec Kodi and Nvidia Shield TV | Panamax M5400 Power Conditioner | PS4 Destiny White Bundle
tl2k2 is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
