OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 4683Likes
post #1261 of 22070 Old 05-13-2014, 04:05 PM
Mike3010's Avatar
Originally Posted by smacrae View Post
Does the optical connection on the 8550 pass dts audio?
depends what you mean by DTS... If you mean DTS neo 6 then yes (simulated 5.1 from a two channel source). If you mean DTS HD then no, but no device out there had ever supported DTS HD over optical.
Mike3010 is offline
post #1262 of 22070 Old 05-13-2014, 04:09 PM
al210's Avatar
Quoted: 221 Post(s)
Liked: 103
Originally Posted by Ahzari View Post
On the other hand my HU9000 is having really bad distortion and vibration coming from the panel at every audio setting when using the internal speakers - I'm pretty sure i have a bad set as no one else is complaining about this so ill likely be asking Amazon for a replacement soon. I do have mine wall mounted, thought the mount might be putting unnecessary pressure on the back panel causing the audio problems but that can't be right, right?
Ahzari. I think you don't see more complaints because a lot of people don't use the internal speakers like myself.
LG 65EF9500 OLED -- Samsung K8500 4K Blu-Ray Player
Denon X4200W AVR & Rogue Audio Atlas Tube Amp
Vienna Acoustics Mozart Grand SE Speakers--B&W HTM62 Center--Axiom QS4 surrounds
PSB Imagine XA Atmos Speaker Addons -- SVS PB-1000 SUBWOOFER
Sony XBR43X800E 4K LCD - bedroom tv
al210 is offline
post #1263 of 22070 Old 05-13-2014, 04:42 PM
Ahzari's Avatar
Quoted: 86 Post(s)
Liked: 56
While that may be true, the reviews have touted how excellent the internal speakers for the HU9000 are - I don't use the internals when watching movies, but when casually watching TV i don't like going through turning my amplifier and sub on (thats just me). In any case I figure for the price this TV the sound issue shouldn't be normal.
Audio: Yamaha A-S3000/ Kef Reference 1/ JL Audio e112 (x2)
Video: LG 65E7P OLED/ Oppo BDP-205/ Apple TV (4K)
Analog: Pro-Ject RM5.1SE/ Pro-ject Speed Box II
Cables: Wireworld/ Pangea/ Blue Jeans Cables
Power: Furman PST-8 Power Conditioner
Ahzari is offline
post #1264 of 22070 Old 05-13-2014, 05:48 PM
tigerfan33's Avatar
Quoted: 358 Post(s)
Liked: 169
I use internal speaker and notice no vibration.
I rarely get higher than 30 on the volume.
tigerfan33 is offline
post #1265 of 22070 Old 05-13-2014, 06:12 PM
HD Rookie's Avatar
Quoted: 13 Post(s)
Originally Posted by Tj8xp View Post
Don't know if it was said already but the set has built in 4k demo.
Again if this was said forgive me just throwing it out there.
tj8xp.........
Thanks, I hadn't noticed that. Unfortunately when I attempted to use Store Mode, I was warned the picture settings would be reset, so I skipped the demo.
BTW, I've noticed several comments in the last few days about jutter. Initially, it was driving me crazy, but after applying the base settings that were listed earlier in this thread (then again around page 30), I haven't noticed jutter on any of the hockey or baseball I've been watching through my Comcast box.
HD Rookie is offline
post #1266 of 22070 Old 05-13-2014, 07:02 PM
PeterDoubt's Avatar
Quoted: 13 Post(s)
Well, my Netflix app stopped working and resetting the time manually didn't work. I reset the TV and it works, but when picture is in Standard mode it dims drastically after a couple of minutes. If I change to Natural and slide to Standard it's bright again. Then dims after a couple of minutes again.
Any ideas? Only does it on Standard...I've got to re enter my picture settings and I had some simple ones using Standard I'd like to work.
Thank you!
PeterDoubt is offline
post #1267 of 22070 Old 05-13-2014, 07:05 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
Thank you!
Turn off eco mode
doctorwizz is offline
post #1268 of 22070 Old 05-13-2014, 07:12 PM
PeterDoubt's Avatar
Quoted: 13 Post(s)
Originally Posted by doctorwizz View Post
Turn off eco mode
It's off...
Again, it's only doing it in Standard mode. Weird.
post #1269 of 22070 Old 05-13-2014, 07:16 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
It's off...
Again, it' sonny doing it in Standard mode. Weird.
Maybe try another reset.
post #1270 of 22070 Old 05-13-2014, 07:45 PM
PeterDoubt's Avatar
Quoted: 13 Post(s)
Turns out Eco isn't universal...checked while in Standard and the Eco sensor was on. Odd that reset would set it that way. Wasn't like that out of the box. Thanks a lot!
post #1271 of 22070 Old 05-14-2014, 06:30 AM
hossta's Avatar
Quoted: 37 Post(s)
Originally Posted by cydiamante View Post
I have the hu7500 euro version and it has vertical banding frown.gif. Its only visible when watching football and the there is panning and when watching home videos during scenes where there is blue sky. 4 equally spaced faint lines about 2-3 cm wide. Contacted Samsung and waiting for them to get back to me. Does anyone know it this can be fixed? Im afraid if they offer to fix i will decline because i dont wants any other problems like clouding to arise.
Has anyone else noticed vertical banding on the 65" HU7500 (HU8550 in US)?
Two problems that many have reported with this set are Motion Handling (i.e judder) and problem with UHD-Dimming kicking in at weird times. Does anyone have a set that doesn't have any of these problems?  I'm seriously thinking of getting this set (or perhaps the curved version), but all thees reports are making me wonder why I should bother when my 65" F8000 is almost perfect (No clouding/bleeding, no Motion Blur or Judder, very faint banding)?
hossta is offline
post #1272 of 22070 Old 05-14-2014, 07:24 AM
al210's Avatar
Quoted: 221 Post(s)
Liked: 103
I have the HU9000 and don't have any motion/Judder issues. I do have a minimal amount of light clouding in the lower left corner but I am still experimenting with settings.
al210 is offline
post #1273 of 22070 Old 05-14-2014, 07:42 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 3026 Post(s)
Liked: 3216
That is odd for sure........
Cleveland Plasma is offline
post #1274 of 22070 Old 05-14-2014, 08:03 AM
akashyap's Avatar
Hello All,
I received my UN65HU9000 this Friday 05/10. Picture is great and very clear and I am very happy with it. However, I seem to have issues connecting to my HTPC. When connecting via DVI-to-HDMI cable, TV says "No Signal" (check Cables and Source). When I start the PC, all of the screen shows until Windows 8.1 welcome screen. There, sign-in notification shows up and then screen goes blank. I have tried booting into safe mode and TV displays at 800x600@75 Hz (why did it select 75 Hz not 60 Hz). Also starting windows 8.1 with low resolution mode does not work. Under Normal mode, not sure what is causing NVIDIA to select a resolution that is too high i.e. 4 K 3840 x 2160 @ 60 Hz (which HDMI won't support).
I have a Marantz receiver with scaling. I have tries fixing the output to 1080P (Downscale) and still no luck. I believe it has to do with resolution of the graphics card. It worked great with my old TV a LG 1080P TV before and connected to Marantz with no issues.
I am stumped on what to do. Should I return the TV or update the Graphics card (4K card)? I thought the TV will upscale a 1080p signal. NVidia has a max resolution of 2500x1600.
Any help is appreciated. Thank you in advance.
akashyap is offline
post #1275 of 22070 Old 05-14-2014, 08:23 AM
hpp8140's Avatar
Quoted: 280 Post(s)
Liked: 87
Originally Posted by akashyap View Post
Hello All,
Umm...Nvidia is choosing 4k the native resolution of the TV. Set windows display to 1080.
http://windows.microsoft.com/en-us/windows-8/get-best-display-monitor
or
through Nvidia control panel
LN55C630, PN64F8500, Definitive SSA-50, GE Supercinema 3D Array X, Paradigm Millenia CT
hpp8140 is online now
post #1276 of 22070 Old 05-14-2014, 08:28 AM
amgme's Avatar
I'm joining the club. Just purchased the hu9000 and hope it doesn't disappoint me. I'm upgrading from a 10 yr old plasma 50" Sony. Thanks to the members who have posted their settings . Will be applying those when I get it.
Are there any defects I can check/look for when I get it?
amgme is offline
post #1277 of 22070 Old 05-14-2014, 09:23 AM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
Hello All,
What video card are you using?
Have you tried connecting directly to the TV?
post #1278 of 22070 Old 05-14-2014, 09:34 AM
al210's Avatar
Quoted: 221 Post(s)
Liked: 103
Just be careful not to remove the styrofoam on the screen until the stand is installed. There is a big note when you unpack it about the stand installation. I put padding (I think it was the wife's kitchen chair cushions biggrin.gif) and towels down on the floor to keep the TV high enough off the ground to install the stand.
dr0z77 likes this.
al210 is offline
post #1279 of 22070 Old 05-14-2014, 09:35 AM
hossta's Avatar
Quoted: 37 Post(s)
Judging by what others have said, look for clouding/bleeding in the bottom corners, and see if you can spot any Motion Blur or Juddering when watching sports, like Soccer or Hockey..
I read in a review that the one-connect box has a noisy fan, & despite this gets seriously hot.  let us know if this is the case with yours.
Good luck & hope you have a fault-free set.
amgme likes this.
hossta is offline
post #1280 of 22070 Old 05-14-2014, 09:58 AM
Mattopotamus's Avatar
Quoted: 1792 Post(s)
Liked: 1539
Mattopotamus is offline
post #1281 of 22070 Old 05-14-2014, 11:22 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
The lower left corner on the 9000 is notorious for clouding from what I've seen. I wonder why the other three corners fare better?
jbug is offline
post #1282 of 22070 Old 05-14-2014, 11:25 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
I've heard of delivery folks turning the set upside down to attach the stand and not remotely following the instructions on the box.
jbug is offline
post #1283 of 22070 Old 05-14-2014, 11:49 AM
jimbotron's Avatar
My 8550 is the same way. Not enough to ruin the experience, but it's visible.
jimbotron is offline
post #1284 of 22070 Old 05-14-2014, 01:57 PM
al210's Avatar
Quoted: 221 Post(s)
Liked: 103
dr0z77 likes this.
al210 is offline
post #1285 of 22070 Old 05-14-2014, 02:02 PM
Oalaego's Avatar
....my HU9000 is having really bad distortion and vibration coming from the panel at every audio setting when using the internal speakers - I'm pretty sure i have a bad set as no one else is complaining about this so ill likely be asking Amazon for a replacement soon.
I had similar speaker rattle / vibration in a HU8550 along with a bright little "worm shaped" 3/4" imperfection in the screen...also crashed the OS (after I had deleted all channels from channel list and tried to add four back) so that it wouldn't completely boot into the system leaving me without menu control and no way to fix even with tech support. So I traded in and fixed all. This time I deleted all but the handful of channels I wanted.
Oalaego is offline
post #1286 of 22070 Old 05-14-2014, 02:11 PM
tl2k2's Avatar
Quoted: 45 Post(s)
Liked: 38
i havent noticed any clouding on any corner of my hu9000 yet. i hang my tv as soon as i unlocked the four clip, lift the box up then put on the hanging bar while its still on the bottom part of the box.
TV: UN65HU9000FX/ZA TS01 Panel W/OCB 3500U/ZA | Receiver: AVR-X7200WA | Speakers: B&W CM10 S2 |Wirings: All Audioquest Carbon HDMI and Speaker wire Audioquest Castlerock Bi-amp wires with dbs v.72
Harmony Ultimate Remote | Media Player Intel NUC5i7 With Openelec Kodi and Nvidia Shield TV | Panamax M5400 Power Conditioner | PS4 Destiny White Bundle
tl2k2 is offline
post #1287 of 22070 Old 05-14-2014, 02:36 PM
Oalaego's Avatar
I recently got the HU 8550 and after a week of setting it up and having to do an exchange — quite a hassle given limited availability in my area. However, after it all I am very happy with it.
The panel definitely needs to be calibrated to lose the "soap opera effect" using settings as noted on this site and tweaked a bit for each 'mode' and input, and my color tastes. Now HD television, Netflix streams, Apple TV, and Blu ray disks look great... and even regular DVDs look reasonable. Regular television and 'cheating' HD channels — not so good. 3D Blu rays look as good as any 3D I've seen including IMAX. At distance over 18" grain of pixels can't be seen, being effectively "retina". I have to disagree with those reviewers who say HD panels are practically speaking just as good as 4K — perhaps if you are sitting over twenty feet away or your eyes are not so good. I certainly appreciate the almost photographic print quality of the image when 6-12 feet away.
Joneszilla likes this.
Oalaego is offline
post #1288 of 22070 Old 05-14-2014, 02:56 PM
huddadudda's Avatar
Quoted: 26 Post(s)
My Samsung UN55HU8550 was delivered today for my home office. What picture settings are you guys using? I saw the CNET calibration settings posted for last years model but has anyone posted anything newer?
huddadudda is offline
post #1289 of 22070 Old 05-14-2014, 03:14 PM
Liked: 1539
No doubt the PQ is great, but aside from 4k content having it side by side next to a plasma everything looks a little foggy and more flat.
post #1290 of 22070 Old 05-14-2014, 04:01 PM
Mike3010's Avatar
not sure that I understand your comment. How can the pq be "great" but also be "foggy and more flat" ... Either it's great or it isn't?
Mike3010 is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , un55hu9000 , un65hu9000
