OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 4654Likes
post #2431 of 22000 Old 07-01-2014, 12:41 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Originally Posted by TAZMOJ View Post
I couldn't agree more. The picture is stunning, the curve does add depth and I haven't seen a better picture for the dollars on anything. I waited a while to purchase the 9000 and am very satisfied with my decision. These forums are to explore functionality, experiences and coach each other. I think many mis-interpret the comments as negativity (which there is some) as opposed to objectivity. One can find "fault" with anything if they look hard enough with prejudice.
My 2 cents worth
Agreed.
Mrorange303 is offline
post #2432 of 22000 Old 07-01-2014, 07:37 PM
fdunayer's Avatar
Sorry if this has been answered but I'm not sure i know what search phrase to to use to get the answer....
Does the source selection have discrete codes or does it only scroll through the available sources like my older Samsung and Sony? Scrolling only makes macros very difficult because the number of times you have to "press" source can be variable.
fdunayer is offline
post #2433 of 22000 Old 07-01-2014, 07:39 PM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 230
I use discrete codes for inputs on a JP1 remote for a 8550.
doctorwizz is offline
post #2434 of 22000 Old 07-01-2014, 09:38 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2178 Post(s)
Liked: 2353
Originally Posted by NickB123 View Post
So if I buy a TV from you I'm considered by Samsung to be the first owner (for warranty purposes)? I'm just curious, I don't understand the nuances of authorization!
Absolutely, no question on that.
People have been getting confused about authorization for years on here..........
lgroveman likes this.
Cleveland Plasma is offline
post #2435 of 22000 Old 07-01-2014, 11:22 PM
Roberyu's Avatar
Quoted: 18 Post(s)
Liked: 24
My UN75HU8550 just came in earlier than expected, so I returned the loaner 65" 8550 and got the 75 up on the wall. At a 12' eyeball to screen distance, the extra size works just about right for me. So far, this panel appears to be as good as the 65" was. No noticeable flash-lighting or clouding. Impressive for an edge lit set. I might keep this one. haha
sikclown likes this.
Roberyu is offline
post #2436 of 22000 Old 07-02-2014, 03:35 AM
ggw2000's Avatar
Quoted: 539 Post(s)
Liked: 207
Please give us your thoughts after having the set a few days and making adjustments, etc.. I have been reading some on problems with motion/judder on samsung sets. I would really like to go with a 75" but might have to drop down to a 70" something if there is a problem in this area. Also if you use sat/cable could you comment on upscaling capabilities of the set. I watch dishnetwork about 90% of time and amazon/netflix the rest of time. Thanks, Gerry
ggw2000 is online now
post #2437 of 22000 Old 07-02-2014, 05:46 AM
Liked: 0
I want to get a HU9000, I was thinking about the 55". Does anyone think/ or have any advice about whether they think the 55 inch would be worth it, mainly for the curve. Also does the 55" have all the same updates as the 65"?
Brotherho0d is offline
post #2438 of 22000 Old 07-02-2014, 07:10 AM
Bassplayer6's Avatar
Quoted: 418 Post(s)
Liked: 110
Folks,
I have been reading a lot of posts, mainly between sony x900b/950b and Samsung hu8550.
As I got a good discount on the 75" hu8550, I decided to give it a try (came in yesterday).
My first impressions are:
1) the screen (ts01) is very uneven
2) some leds at the top seem to be creating a "shadow" when light yellow/blue color are displayed
3) light bleeding from bottom corners
Is this expected from a 75" display?
From I gathered, some sonys also have the same issues, but it seems panel contrast is better overall.
Thoughs?
Bassplayer6 is offline
post #2439 of 22000 Old 07-02-2014, 11:13 AM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
Question I am hoping owners of the HU8550 can answer for me.
1. Are there connections on the back of the set for all of the inputs, or are they all on an external box?
2. Does the external connection box disconnect from the set or is it hard-wired in?
3. How long is the cable to the external box? Can it be extended if needed?
"Read Less, More TV." - Dr. Gregory House
"That which can not be questioned, can not be trusted." - Me
The Metropolis Home Theater
Blue Smoke Entertainment Systems - Affiliated
PeterS is offline
post #2440 of 22000 Old 07-02-2014, 11:16 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Originally Posted by Vilthemon View Post
Hey guys
As a new "contributing" but long time reader, just wanted to share my views on actually both the 65HU8550/7500 and recently 65HU9000/8500.
Initially I purchased the 8550 believing that the "curve" is a gimmick and the differences in other tech specs with 8550 would not make a significant difference. When the set was delivered I was very happy with the quality of the upscaled picture (1080i broadcast) coming from a 55'' Samsung 1080p led. For info it was the European model with IS01 panel which I understand is manufactured by Sharp.
However one of the most disturbing ever issues happened when I actually tried to watch some World Cup games - the dreaded vertical banding!. I never had or have seen such an issue before and reading some other forums I was led to believe that this is somewhat a "normal" phenomenon on large TV's. Unfortunately for me it was the only thing I could ever see while watching the games. This was not all and there was a significant light leakage of 10-15cm of length and 0.5cm of width at the right side of the screen (not flashlight or clouding).
Just to make sure it was not an isolated incident I inspected another IS01 panel at the retailer's display and to my surprise banding was visibile and acknowledged by the salespeople. Similar to one of the forum members I checked at the same time a 65HU9000 with TS01 panel which was completely free of any banding whatsoever!
Not happy especially with the banding and despite the fact that I chucked away the box, they agreed to reimburse it. Not willing to take the risk of getting a panel with banding I decided to bite the bullet on the 65HU9000.
Long story short, this TS01 panel HU9000:
1) Has virtually "zero" banding and if it has it is not noticeable at all - night and day difference
2) The picture quality is similar but the motion seems to be slightly better. Just note that I am using the standard preset with no real adjustment apart dialling down a little the backlight.
3) The reflections are definitely higher in my setup and due to the nature of the curve they are bit weird to be honest
4) Finally the curve, you dont really notice it during movies or sport but fire up google from your HTPC and then it becomes really noticeable. But all in all it did not bother me as much as it would
All in all I am very happy with the HU9000 so far and hope that I don't run into any major issues going forward.
I had exact same experience like you, purchased 65HU7500 - vertical banding. The store unit also had it. Exchanged it for 65HU8500, very happy.
vddobrev is offline
post #2441 of 22000 Old 07-02-2014, 12:03 PM
sikclown's Avatar
Quoted: 1382 Post(s)
Liked: 702
Originally Posted by Bassplayer6 View Post
1) All in the back
2) External box is in theory for next year upgrades and it will connect via special cable connection on the back
3) Someone that has one today will have to answer that, but hopefully is longer than the power cable (~3 feet)
Yes the HU8550 has all inputs on the back of the set whereas the F9000 and HU9000 have a One Connect box which connects with an 6 foot proprietary cable. The HU8550 has a One Connect connection which will be used for the 2015 UHD Evolution Kit. I have installed the 2014 UHD Evolution Kit on my F9000 and the cable is about 6 feet and rated for in wall. It doesn't look like they are going to make a longer cable available.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #2442 of 22000 Old 07-02-2014, 04:42 PM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Help with Digital/Optical
Hi,
I;m trying to run a optical line from my TV (HU8550) to my Denon X4000 so I can get Dolby Digital 5.1 through netflix or vudu. That way I can stream UHD 4K. I've assigned the optical #1 on my Denon input Aux2. I'm not getting any sound from my Denon....only from the TV. I get video but no sound from my Denon. I've changed the optical line just in case and it's still not working.
Any help would be appreciated
Jerry
Lyons07 is offline
post #2443 of 22000 Old 07-02-2014, 05:19 PM
Latinoheat's Avatar
Quoted: 1111 Post(s)
Liked: 871
Originally Posted by Lyons07 View Post
Hi,
Jerry
Optical from tv - optical 1 TV audio in receiver.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #2444 of 22000 Old 07-02-2014, 05:36 PM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
I found out the problem and I had not one but two bad optical. I just went and bought another one and it's working..
Thank you
Lyons07 is offline
post #2445 of 22000 Old 07-02-2014, 11:06 PM
Styphin's Avatar
Samsung now has 85" hu8550 on their store?
Was this just added recently? For $10K that's a much better price than the 85" S9.
Styphin is offline
post #2446 of 22000 Old 07-02-2014, 11:30 PM
Ahzari's Avatar
Quoted: 57 Post(s)
Liked: 55
... Well you would only save $30,000 over the S9, dunno if thats a great deal
Audio: Yamaha A-S1000 // Kef Reference 1 // JL Audio e112 (x2)
Analog:Pro-Ject RM5.1SE // Pro-Ject Tube Box II SE Phono Amp // Pro-ject Speed Box II
Video: Samsung 65' HU9000 UHD // Oppo BDP-105 // Apple TV (4G)
Power: Furman PST-8 AC Power Conditioner
Cables: Wireworld, Pangea, Blue Jeans Cables
Ahzari is offline
post #2447 of 22000 Old 07-03-2014, 01:09 AM
Kenneth Tong's Avatar
Picking up the 85" HU8550 today in the Afternoon. Any thoughts? Upgrading from my LG 84" LM9600...
Kenneth Tong is offline
post #2448 of 22000 Old 07-03-2014, 04:39 AM
Stereodude's Avatar
Quoted: 3157 Post(s)
Liked: 2305
It's also not exactly going to have the same picture quality of as the S9 since it lacks the full array local dimming the S9 has. Then again, to save $30k something is going to have to give.
Stereodude is online now
post #2449 of 22000 Old 07-03-2014, 05:52 AM
jkhome's Avatar
Quoted: 91 Post(s)
Liked: 51
Anyone here use one of the Oppo players with their set? I need a player with analog outputs, now using a cheap Panasonic unit. Thinking about a Oppo 103D for my new HU9000. If you do, which is set (for BD playback) to do the upconverting, the player or the TV?
jkhome is offline
post #2450 of 22000 Old 07-03-2014, 05:56 AM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
TV, always!
vddobrev is offline
post #2451 of 22000 Old 07-03-2014, 06:00 AM
rlb
rlb's Avatar
Quoted: 1728 Post(s)
Liked: 1381
I use the OPPO 103D with the F9000 (with 2014 UHD kit--basically same processing as the HU9000).
With the original one connect I found the OPPO upconversion to be marginally better than the F9000 and definitely appreciated the Darbee processing.
With the new one connect (same processor as in the HU9000) I was amazed at the improvement in the set's upconversion. I definitely now prefer to have the OPPO output "native" and allow the one connect to do all the upconversion. With the increased contrast/depth of the new upconversion, I also don't miss the darbee processing (not available on OPPO 103D when using native).
If I were doing it all over at this point I would just buy the OPP0 103 and use native output with this set. But, I do love the OPPO as a great "transport" (no processing of any kind).
rlb is online now
post #2452 of 22000 Old 07-03-2014, 06:05 AM
jkhome's Avatar
Quoted: 91 Post(s)
Liked: 51
Thanks guys, I was also going to ask about going "Darbee vs non-Darbee". Seems some folks like the Marvel chip in the non version better. Plus it's cheaper
Love the Oppos, had an 83 before the Panny, much better built, and pic quality.
jkhome is offline
post #2453 of 22000 Old 07-03-2014, 07:12 AM
lgroveman's Avatar
Quoted: 80 Post(s)
Liked: 29
You mentioned that your F9000 is upconverting much better now that you have the new evolution box. Are the processors for the upconversion on the one connect box? And does it seem reasonable if one purchases an 8550 that the 2015 evolution kit will include at least the quad core plus that will provide better upconversion like the 9000. I thought the evolution kit primarily provided the newest smart platform. And in your case HDMI 2.0.
lgroveman is offline
post #2454 of 22000 Old 07-03-2014, 07:57 AM
baddceo's Avatar
Quoted: 38 Post(s)
My guess is that its doubtful they are going to make any changes to the 8550 line. Samsung is clearly trying to make the 9000 purchase more enticing by adding the extras and that goes away if they offer all of those features on the line directly below it... Personal opinion.
baddceo is offline
post #2455 of 22000 Old 07-03-2014, 08:01 AM
Phrawst's Avatar
Quoted: 104 Post(s)
Liked: 33
So finally got my 75HU8550 out of the box and mounted on the wall only for an issue to happen about 5-10 minutes after turning the TV on. (See attached photos).
That stripe flickers and does not go away once it starts.
Anyone know why this may have happened (beyond it just being faulty) want to make sure it's not due to improper mounting, or something else I'm not thinking of. Hopefully getting a replacement today or tomorrow.
ID:	146586   Click image for larger version
Phrawst is offline
post #2456 of 22000 Old 07-03-2014, 08:16 AM
Stonedcl's Avatar
Quoted: 51 Post(s)
Can I ask you guys about how far do you guys sit from your 8550 and what size do you have?
I also want to know if anyone used / uses the tv for gaming? It seems like the TV has bad input lag so I am wondering how gamers like there TV?
Stonedcl is offline
post #2457 of 22000 Old 07-03-2014, 08:25 AM
baddceo's Avatar
Quoted: 38 Post(s)
I sit about 9 feet away from my 60". Haven't gamed on it but am curious what input lag you are experiencing and what the actual effect of that lag is.
baddceo is offline
post #2458 of 22000 Old 07-03-2014, 08:27 AM
Quoted: 418 Post(s)
Liked: 110
75.
Sit about 8-9 feet.
I have played a little of bit of Battlefield on PS4, Uncharted on PS3 and COD on XBOne and it was Ok.
The lag got better after the latest firmware update (830Mb!). I think a reviewer stated it was around 70 and now ~50 (PC input)).
Still not great but around what other 4K sets will produce (Sony 65X900b ~42)
post #2459 of 22000 Old 07-03-2014, 08:37 AM
Industry Insider
Liked: 2353
I am sure you will have many thoughts........ Let us know what you think .
post #2460 of 22000 Old 07-03-2014, 09:31 AM
ToddD's Avatar
Turn it off and let it fully cool down, then try it again. I'd time how long, if ever, it takes for that strip to come back. But I have to think the set is defective.
ToddD is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
