OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 4674Likes
post #2461 of 22061 Old 07-03-2014, 09:36 AM
Phrawst's Avatar
Quoted: 118 Post(s)
Liked: 39
Set is already packed up. The strip would appear after 5-10 minutes of the tv being on. If you turned it off and on again right away the strip would appear instantly. Letting it sit for a bit would result in it not appearing for the normal 5-10 minutes.
Getting a new one this evening. Fingers crossed it has nothing to do with the room/mounting and that the set was defective.
Phrawst is offline
post #2462 of 22061 Old 07-03-2014, 12:00 PM
Glenee's Avatar
Quoted: 117 Post(s)
Liked: 93
I think your doing the right thing. I also think the next one will be perfect. Once you get this straightened out, you are going to love your Purchase.
All the Best Buddy.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is online now
post #2463 of 22061 Old 07-03-2014, 01:32 PM
mobileES's Avatar
Quoted: 67 Post(s)
Liked: 45
Saw the 65" 8550 in the store and was blown away, looking to pick it up this fall, coming from a 55" Samsung 6300 series. Does anyone remember if Samsung included any of the 4K sets in their week-long Black Friday sale last year? I remember prices being up to 30-35% off.
mobileES is offline
post #2464 of 22061 Old 07-03-2014, 04:37 PM
Musta10000's Avatar
Quoted: 21 Post(s)
Originally Posted by jkhome View Post
Anyone here use one of the Oppo players with their set? I need a player with analog outputs, now using a cheap Panasonic unit. Thinking about a Oppo 103D for my new HU9000. If you do, which is set (for BD playback) to do the upconverting, the player or the TV?
OPPO 103 - having the OPPO upconvert for now. To be honest I have not had much time to do comparisons as I just got my TV a little while ago. Once I play with it I may end up changing.
Samsung UN78HU9000
Parasound Halo C-2 & Halo A-51
B&W 805D L&R & HTM4 D Center with Canton Karat 920 RR and LR, Velodyne FSR-18
Oppo 103, DirectTV H24-700, Apple TV, SONOS Bridge and Connect
Office: Sony KDL60-720NX & Energy PowerBar Elite, Den: Samsung PM60F5300 & ZVOX 580, Bedroom: Samsung UN50EH5300, Bathroom: Samsung UN46EH5000
Musta10000 is offline
post #2465 of 22061 Old 07-03-2014, 05:23 PM
Quoted: 20 Post(s)
Liked: 1
Hey guys
Anyone wall mounted the 65inch hu8550 (flat) on he wall?
How many important connections are stupidly facing back? And what angled adapters do u recommend
I'm planning on mounting it 15-20mm from the wall and worried that too many things will protrude over this including the thickness of the adapters
The four things I would need to connect are antenna, 1 or 2 hdmi, foxtel/cable and optical audio out
Any input would be greatly appreciated
Cheers
JonyB is offline
post #2466 of 22061 Old 07-03-2014, 06:16 PM
jkhome's Avatar
Quoted: 98 Post(s)
Liked: 65
Thanks, ordered the 103 (non-Darbee version) today. Will be in the same day as the TV delivery. Talk about a learning curve...
jkhome is offline
post #2467 of 22061 Old 07-03-2014, 06:34 PM
Roberyu's Avatar
Quoted: 18 Post(s)
Liked: 24
Originally Posted by JonyB View Post
Hey guys
Cheers
Unfortunately, the most important connection is facing the back, and that is the ARC HDMI port. However, that may not impact you as I see you want to run an optical cable for audio, which I presume is to carry audio from the TV to the receiver. That optical output is facing the side inside the main connector pocket on the back. For me, I rally want to run ARC, so I bought a thin Redmere cable (these are awesome!) from Monorice, and a 270 degree adapter, so it'll clear most wall mountings this way even though the ARC HDMI faces straight out the back.
The lan cable is also straight out the back as well, but the wifi work so well on my 5 ghz band that I may never hook it up to the cat6 network I have in place. I never thought the wifi would work this well, so that's a nice surprise.
Roberyu is offline
post #2468 of 22061 Old 07-03-2014, 07:47 PM
Quoted: 20 Post(s)
Liked: 1
Thanks for you're help Roberyu
Not sure if I wrote down the right thing before (I'm not very tech savy, but do want good tv and decent sound) (ps I don't really have room or $$ for good surround sound which will prob come later)
For now I'm planning on hooking up a Canton musicbox m to it via the digital optical cable
Was that facing back or side wards/downwards
Ps I'll prob get killed for asking this but what is the arc hdmi port and will I be needing this with what I've mentioned
Thanks in advance
JonyB is offline
post #2469 of 22061 Old 07-03-2014, 08:14 PM
Dr.Shankenstein's Avatar
Quoted: 489 Post(s)
Liked: 425
Any 50" HU8550 owners here? I have a defective F9000 if Samsung won't take care of issue may be looking for replacement. I am looking at the 50" how is motion, black levels,etc...?
Dr.Shankenstein is offline
post #2470 of 22061 Old 07-04-2014, 01:44 AM
Quoted: 26 Post(s)
Liked: 7
Originally Posted by doctorwizz View Post
Yes I am aware of DD 2.0. But everything that is listed as 5.1 in NF is playing in 2.0. Even though the AVR's input graphical display shows 6 blocks meaning 5.1 channels of input. But the only channels that are playing are the FL and FR. I have tested the same movies on other devices like WD TV live, and Fire TV. They played in proper 5.1. There is definitely a problem. I found out that if you long press on the NF icon, it brings up a submenu where one of the choices is report problem.
Whats more interesting is that Netflix website says that the HU8550 will stream 5.1 even though it is not an audio option within the app.
https://help.netflix.com/en/node/2250
Zacasaur is offline
post #2471 of 22061 Old 07-04-2014, 02:02 AM
R0CK632's Avatar
Quoted: 43 Post(s)
Has anybody figured out a way to get the netflix App in the smart hub to play in dolby digital?
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2472 of 22061 Old 07-04-2014, 04:35 AM
Bob_Houston's Avatar
Quoted: 70 Post(s)
Liked: 32
After starting the Netflix (or any SmartHub) app, use the Menu function for the TV to change the sound settings to Dolby Digital.
It appears to cache these settings per App - because when I change between optical and HDMI ARC for audio output, it appears I have to do this for each app - and after that, the sound appears to stay at Dolby Digital for those apps.
Bob_Houston is offline
post #2473 of 22061 Old 07-04-2014, 06:53 AM
Phrawst's Avatar
Quoted: 118 Post(s)
Liked: 39
How do you get ARC to work. I have my 75HU8550 connected to my onkyo receiver but can't seem to get the smart hub apps sound to come out of anything but the TV. I've dug around in the settings there is a speaker setting with a bunch of options but receiver is greyed out.
Phrawst is offline
post #2474 of 22061 Old 07-04-2014, 09:52 AM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
I'm having the same problem, when starting the smart hub, it only comes through the TV speakers. Went into TV settings and it says DD. The only way I got it to work is, come straight out of the TV optical to Denon optical and then it works. Was hoping I didn't need to do that, but at least DD is working that way.
Jerry
Lyons07 is offline
post #2475 of 22061 Old 07-04-2014, 09:54 AM
rlb
rlb's Avatar
Quoted: 1770 Post(s)
Liked: 1448
"Dolby Digital" would normally be what you use to stream "5.1". Unfortunately the Netflix app (4k version) currently is outputting sound only on fr and fl.
rlb is online now
post #2476 of 22061 Old 07-04-2014, 10:46 AM
baddceo's Avatar
Quoted: 38 Post(s)
The arc on my 60 8550 does exactly what it should do. Pass sound to the receiver and its DD as long as you go back into tv sounds after you turn on netflix and switch it. You should be turning the speakers on the tv off and selecting the correct arc source on your reciever. It should all work together. If not ive heard resetting the apps sometimes helps.
baddceo is offline
post #2477 of 22061 Old 07-04-2014, 10:52 AM
Liked: 0
PQ is most important to me and I need to upgrade to a 70+in TV. The HU8550 was recommended to me after I said I was interested in the F8000 (non-4K TV). In stores with default factory settings the F8000 seems to blow away the PQ of the HU8550 when viewing HD CBL/SAT sources. The 8550 picture looks soft with less sharpness and detail and has poor black levels with a washed out picture. The 1080p TV looked sharper with inkier blacks when viewing the same non-4K source in store. Do you find that after calibration the picture quality is as good or better than a 1080P TV when viewing CBL/SAT sources? I would like spend a little extra money to future proof my TV and buy a 4K TV but not if it can't upscale 720p/1080i content well. I mostly watch cable TV and blu-rays but I would like to watch 4K blu-rays once they are available. I would really appreciate any opinions in this matter as I'm not convinced the PQ is as good as a 1080p TV unless you are viewing 4K content. Thank you.
SansoneDPM is offline
post #2478 of 22061 Old 07-04-2014, 11:09 AM
R0CK632's Avatar
Quoted: 43 Post(s)
My Problem is I CANNOT change the settings in the TV Sound Menu, All it gives me is PCM, Dolby is grayed out. How can I fix this? I am connected through HDMI ARC.
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2479 of 22061 Old 07-04-2014, 11:31 AM
sikclown's Avatar
Quoted: 1396 Post(s)
Liked: 708
You have to change it in a movie, TV show, etc. Otherwise it is grayed out.
UN65F9000AFXZA + SEK3500u/za firmware version 1461
Denon AVR-X7200WA, Apple TV, UBD-K8500, PS4, Xbox One, Nvidia Sheild Pro, PC
(2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA, (4) RP-140SA, (1) SVS PB12-Plus
Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000 firmware 1132,Denon x4200w, Apple TV, Panny BDT460, PC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is online now
post #2480 of 22061 Old 07-04-2014, 11:43 AM
R0CK632's Avatar
Quoted: 43 Post(s)
I Was watching a show and it still didn't allow me to change it. Tried multiple channels as well.
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2481 of 22061 Old 07-04-2014, 11:45 AM
tontondavid's Avatar
Quoted: 90 Post(s)
Liked: 26
Has anyone had any problems with the Netflix app not starting with black screen?? I keep on having this issue after the new firmware 1140!! I had to reset the TV like 5 times and it works once or twice then it never starts again!
Help. I am thinking of exchanging the TV if this is a defect.
By the way, I have the un78hu9000 model..... thanks.
tontondavid is offline
post #2482 of 22061 Old 07-04-2014, 12:11 PM
sikclown's Avatar
Liked: 708
How is your cable box set up to output sound in it's sound menu?
post #2483 of 22061 Old 07-04-2014, 12:14 PM
sikclown's Avatar
Liked: 708
I have not had this happen. If you start Netflix and then it goes to a black screen, how long does it stay there? Does the App crash? Does it just stay there until you turn the TV off or can you exit out via remote? Did you reset Smart Hub (not the TV reset)?
post #2484 of 22061 Old 07-04-2014, 12:23 PM
Quoted: 90 Post(s)
Liked: 26
It never recovers. It stays black forever until I select another input. Even after smarthub reset. The only way to get out of this is full tv reset.
post #2485 of 22061 Old 07-04-2014, 12:43 PM
R0CK632's Avatar
Quoted: 43 Post(s)
I had the same problem... Did a TV Reset through the self diagnosis and luckily haven't had the problem since. The netflix app blows as I can only get stereo for some reason no dolby.
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2486 of 22061 Old 07-04-2014, 12:57 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
You gotta do what's best for you man. Spend the money on a set that's beginning the final stages of its formats life or the infancy of another.
My opinion is always go future proof when able.
Perhaps when you see native 4k content your happy.
Maybe not. No one can tell you that will work out.
Research, research and research some more.
Good luck.
Mrorange303 is offline
post #2487 of 22061 Old 07-04-2014, 01:44 PM
Yoshimi's Avatar
Quoted: 48 Post(s)
Hey guys, HU9000 owner here. I love the set with one MAJOR exception and I'm hopeful someone on here has an answer:
The judder on sports through Direct TV is so bad, it's unwatchable. The image constantly shakes when there's any movement. I have the settings on Blur Reduction: 10 and Judder Reduction: 0 - but, it's done no good. Blurays look great, movies, etc.
My questions are:
1. Is anyone else experiencing this?
2. If so, any solutions?
3. Is it possibly a Direct TV thing. I would switch to cable if it eliminated the problem. It's that bad.
Yoshimi is offline
post #2488 of 22061 Old 07-04-2014, 02:03 PM
Bassplayer6's Avatar
Quoted: 418 Post(s)
Liked: 110
My questions are:
The only way i found to eliminate the issues while watching the world cup was renaming the source to pc or engaging "game" mode.
None of the motion options, even off, was able to solve the issue.
Bassplayer6 is offline
post #2489 of 22061 Old 07-04-2014, 02:04 PM
R0CK632's Avatar
Quoted: 43 Post(s)
My Cable box is set to audio output - Dolby Digital ON...I don't get it. I even switched it from ARC and its now setup with optical and same issue.
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2490 of 22061 Old 07-04-2014, 02:15 PM
Quoted: 20 Post(s)
Liked: 1
Originally Posted by Bassplayer6 View Post
Folks,
I have been reading a lot of posts, mainly between sony x900b/950b and Samsung hu8550.
As I got a good discount on the 75" hu8550, I decided to give it a try (came in yesterday).
My first impressions are:
1) the screen (ts01) is very uneven
2) some leds at the top seem to be creating a "shadow" when light yellow/blue color are displayed
3) light bleeding from bottom corners
Is this expected from a 75" display?
From I gathered, some sonys also have the same issues, but it seems panel contrast is better overall.
Thoughs?
Thanks bassplayer6 for the review
I've been set on getting a 8550 as I want to mount it flush on the wall
I've gathered from this forum that the panels ts01 & th01 are the two equal best with fewest problems
My question and biggest concern is did you notice any verticle banding with this screen?
Because I'll be going out of my what at the shop to hand pick a panel starting with T
Thanks in advance
JonyB is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv
