OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 4681Likes
post #2521 of 22070 Old 07-05-2014, 12:30 PM
sikclown's Avatar
Quoted: 1507 Post(s)
Liked: 751
Originally Posted by R0CK632 View Post
I Have optimum cable (Cablevision) I have the cable box going into the Sat/Cable in of receiver via HDMI and from the Out of the Receiver going to the HDMI Arc 3 port of the 1 connect box. I tried using optical as well and same issue.
Your Cable Box is outputting it's sound to your receiver so you would use that to control Dolby, etc. Your TV isn't getting any sound. We have the same setup, PCM or DTS Neo 2.5 are my only options because the TV is not handling the sound. My receiver is. Look at your receiver, I would bet it is on Dolby unless you have to manually change it which is the case sometimes.
LG OLED 65C7P, Denon AVR-X7200WA, Apple TV, Oppo UDP-203, PS4, Xbox One
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000, Denon x4200w, Apple TV, Panny BDT460, HTPC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is online now
post #2522 of 22070 Old 07-05-2014, 12:33 PM
R0CK632's Avatar
Quoted: 43 Post(s)
Ive tried switching it from Auto Surround and chose specifically dolby digital on the receiver and I am still get stereo I believe.. I am getting no bass. Is there another setting I should try on the receiver?
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2523 of 22070 Old 07-05-2014, 12:35 PM
Ahzari's Avatar
Quoted: 86 Post(s)
Liked: 56
Originally Posted by Yoshimi View Post
Yet another dumb question:
If you did a system reset, what is affected? Would it just be settings that can all be manually set back on the TV itself or would any of the work that Best Buy did connecting it to the receiver and universal remote have to be redone?
Well.. everything goes back to factory default (so any AV settings you made will go back to default) except your wifi will still be intact and connected. I think I had to do it twice early on because first my Netflix app wouldn't download, then next time I had some AV setting greyed out for no reason.
Audio: Yamaha A-S3000/ Kef Reference 1/ JL Audio e112 (x2)
Video: LG 65E7P OLED/ Oppo BDP-205/ Apple TV (4K)
Analog: Pro-Ject RM5.1SE/ Pro-ject Speed Box II
Cables: Wireworld/ Pangea/ Blue Jeans Cables
Power: Furman PST-8 Power Conditioner
Ahzari is offline
post #2524 of 22070 Old 07-05-2014, 12:36 PM
sikclown's Avatar
Liked: 751
What speakers are you using? Is it a 5.1/7.1 setup with a powered sub? Are you getting bass from other sources connected to your receiver?
post #2525 of 22070 Old 07-05-2014, 12:37 PM
R0CK632's Avatar
Quoted: 43 Post(s)
I have Onkyo Speakers, 5.1 with sub... Ps3 blu ray plays surround sound fine
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2526 of 22070 Old 07-05-2014, 12:40 PM
x3sphere's Avatar
Quoted: 222 Post(s)
Liked: 129
Not sure if it's been posted, but I noticed in hdtvtest.co.uk's HU8700 (HU8200 for UK) review, they measured the input lag at 40ms, which puts it in the same ballpark as the Sony XBR:
http://www.hdtvtest.co.uk/news/ue55h...1406123803.htm
Seems a recent firmware update input lowered the input lag by a good amount. Not sure if this also applies to the HU9000, but I assume it would for the HU8550, since that's basically the same TV just without the curve. Perhaps someone with a Leo Bodnar can re-test these units with the updated firmware.
x3sphere is offline
post #2527 of 22070 Old 07-05-2014, 12:42 PM
sikclown's Avatar
Liked: 751
Wink
So is it every channel? Premium movie channels would be your best bet to test, they output surround. Not all channels are created equally. It is likely a cable box setting or something in Receiver.
post #2528 of 22070 Old 07-05-2014, 01:06 PM
R0CK632's Avatar
Quoted: 43 Post(s)
Its all the channels I have selected... I don't currently have any premium movie channels..Iam going to try and buy an on demand movie later and see if that works.
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2529 of 22070 Old 07-05-2014, 01:10 PM
Yoshimi's Avatar
Quoted: 48 Post(s)
Cool, thanks!
Yoshimi is offline
post #2530 of 22070 Old 07-05-2014, 01:43 PM
sikclown's Avatar
Liked: 751
Looking at your cable provider it says all HD channels will be Dolby 5.1 so as long as you are on HD channels you should be getting Dolby surround. It could be cable box issue if you aren't getting surround and you have your receiver set to output surround. You could also try outputting the sound via optical to the receiver and changing the sound output to optical in your receiver for TV. Might be an HDMI issue but usually an HDMI issue would be no sound at all or no video or both.
post #2531 of 22070 Old 07-05-2014, 02:56 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
Really? Wow - OK, will try it. Any other side effects of changing the source name to pc?
Degraded picture quality.
doctorwizz is offline
post #2532 of 22070 Old 07-05-2014, 02:59 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
I see the Neflix app was updated July 3rd. Still no proper Dolby D.
post #2533 of 22070 Old 07-05-2014, 04:56 PM
baddceo's Avatar
Quoted: 38 Post(s)
Go into your receiver settings and change the speaker setup to small fronts and the crossover on your sub to 80 hz. That should fix it.
Sent from my iPad using Tapatalk HD
baddceo is offline
post #2534 of 22070 Old 07-05-2014, 04:59 PM
yikes21k's Avatar
Quoted: 21 Post(s)
hello
I just bought my wife a 55 in 8550. what type of connector is that for the audio out in the back of the tv. it doesn't appear to be toslink or rca type. unfortunately I already mounted the tv on the wall and im trying after the fact to run the audio output. as you can guess...I cannot see the connector and only know the area its in. the manual only says audio out. any info would be appreciated.
thanks
yikes21k is offline
post #2535 of 22070 Old 07-05-2014, 05:03 PM
baddceo's Avatar
Quoted: 38 Post(s)
Originally Posted by yikes21k View Post
hello
thanks
If you are not using ARC it is toslink.
baddceo is offline
post #2536 of 22070 Old 07-05-2014, 05:09 PM
R0CK632's Avatar
Quoted: 43 Post(s)
I'll give it a try when I get home thanks
Samsung UN65HU9000
Pioneer VSX -524 -K
Sony PS3
R0CK632 is offline
post #2537 of 22070 Old 07-05-2014, 05:14 PM
yikes21k's Avatar
Quoted: 21 Post(s)
thanks for the reply. as you can probably tell, im not very technical. my question is, are there more than 1 type of toslink? the one im using doesn't seem to fit in the connector, which is the reason why I thought it wasn't a toslink.
thank you
yikes21k is offline
post #2538 of 22070 Old 07-05-2014, 05:15 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
thank you
There is a jack labled "Audio Out". Looks like a little headphone jack. But a small headphone plug won't go in very far. I don't know what type of plug that is.
post #2539 of 22070 Old 07-05-2014, 05:19 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
The manual shows it as a headphone type jack. Looks different from the picture.
post #2540 of 22070 Old 07-05-2014, 05:25 PM
yikes21k's Avatar
Quoted: 21 Post(s)
baddceo says its a toslink, however its not a toslink connector that ive ever seen before
yikes21k is offline
post #2541 of 22070 Old 07-05-2014, 05:28 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
The Toslink is on the side. This audio out is below the IR out.
post #2542 of 22070 Old 07-05-2014, 05:37 PM
baddceo's Avatar
Quoted: 38 Post(s)
Sorry misunderstood. I am not in town so not near my tv and cannot confirm.
baddceo is offline
post #2543 of 22070 Old 07-05-2014, 05:38 PM
yikes21k's Avatar
Quoted: 21 Post(s)
thank you. the diagram in the manual is tiny for that area. even with a magnifying glass I didn't see it. only saw the audio out.
yikes21k is offline
post #2544 of 22070 Old 07-05-2014, 06:24 PM
Yoshimi's Avatar
Quoted: 48 Post(s)
Has anyone here watched baseball? Check it out right now, it's on Fox.
Please let me know if you're also seeing the awful judder.
I have not seen it on anything other than live sports - but, baseball continues to be the worst. Can't imagine I'm the only one experiencing this.
Yoshimi is offline
post #2545 of 22070 Old 07-05-2014, 06:25 PM
Yoshimi's Avatar
Quoted: 48 Post(s)
Also, another question:
The guys at Best Buy that did the install have everything going through HDMI 3. Direct TV, Apple TV and PS4 are all going through HDMI 3.
Could that have anything to do with:
-the judder
-the fact that I can't switch Game Mode on
Yoshimi is offline
post #2546 of 22070 Old 07-05-2014, 06:36 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
I don't see any judder on the Boston Game on fox.
post #2547 of 22070 Old 07-05-2014, 06:39 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
-the judder
HDMI 3 is the input with ARC.
What receiver do you have?
post #2548 of 22070 Old 07-05-2014, 06:56 PM
Yoshimi's Avatar
Quoted: 48 Post(s)
Pioneer Elite
Yoshimi is offline
post #2549 of 22070 Old 07-05-2014, 06:57 PM
Yoshimi's Avatar
Quoted: 48 Post(s)
Wow - then something's clearly either wrong with my set or the way it was set up.
Yoshimi is offline
post #2550 of 22070 Old 07-05-2014, 07:01 PM
doctorwizz's Avatar
Quoted: 740 Post(s)
Liked: 236
There may be some video processing on in that AVR causing judder. Turn off the processing if is on.
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , un55hu9000 , un65hu9000
